08-18-2019, 09:40 AM
#401
2019 30' Classic
Belen
, New Mexico
Originally Posted by turk123
Actually, I think the antenna is the MIMO-3-V2-15 which includes 2.4/5.8GHz MIMO WiFi
Amazon has it on their marketplace for $193
08-18-2019, 10:27 AM
#402
2019 30' Classic
Belen
, New Mexico
Hmmm, I've never had a problem except once recently when we were at JC. I could not get connected remotely with my iPhone, but my wife's Pixel could connect. The tech removed my app, shut the phone off, restarted, downloaded the app, and then re-paired it with the QR code on the front of the Modem box in the cabinet. it worked like a charm.
If you can't get it to work after doing this, I would call Jason to see if he can access your trailer.
Been there, done that, got the T-shirt. Jason had me do the same fix as you and it did indeed work. However, after the 20th or so time, I've decided it just isn't worth it. If they can't get it to work reliably, it's not user-friendly. I'm exploring other avenues now.
Also, I've had my trailer at either storage, my house, or on the road for over two weeks since it spent 5 weeks at the dealer to have 2.5 hours of labor performed on it. The system still reports it at the dealer.
08-19-2019, 08:47 AM
#403
2018 33' Classic
Butler
, Pennsylvania
That's what I did. The panel is on the back of the compartment access to the speaker. You can use its own fuse by adding a 5A fuse to the fuse block and your red and black leads.
My installation is different. They ran a 12v line into the cabinet next to my refrigerator. I'm in a 2018 Classic 33 and it would have been a much more complex installation to run it to my media rack.
Can I just splice into the 12v line and tap off of it? I was thinking of running a splice into the positive and negative and run to the adapter plug of my router per supply after cutting it of the originalpower supply.
Thoughts?
08-19-2019, 10:22 AM
#404
2019 30' Classic
Canfield
, Ohio
Thoughts?
That would be fine. Get it after the fuse or add a 5A inline fuse just for kicks.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
08-19-2019, 05:38 PM
#405
TinCan
2016 30' Classic
Apache Junction
When I first started Airstreaming I dropped AT&T and picked up Verizon. No complaints so far. AT&T is only good for collecting money. This season I mostly have been at KOA's and there internet has been quite good. Not for streaming but I don't do that anyway. When I need to I use my Verizon Jetpack with unlimited data. Works well also.
TinCan
08-20-2019, 07:21 AM
#406
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
I just picked up my 2020 airstream 30 ft classic a few weeks ago. I downloaded the smart app and have no problem controlling/monitoring the onboard systems from my iPhone/IPad. However, I remotely engaged the battery disconnect button from the app and shut all battery power off to the airstream. When I go back to the app and try to re-engage the battery power the app will no longer allow connection to my trailer and simply states that in order to re-engage power I must use the battery disconnect button. When I attempt to do so nothing happens and the blank control screen reads “reconnecting the battery (via the remote)” but no reconnection takes place. I know I’m technologically challenged in many ways and I apologize if this is a dumb question-why can’t I reconnect the battery supply from the app remotely and regain control/monitoring of my onboard systems? If I go to the airstream and physically re-engage the battery switch near the door everything works fine with the app. But for some reason I cannot get the app to re-engage the battery supply remotely to regain control/monitoring of the system through the app. Thoughts?
08-20-2019, 07:23 AM
#407
2019 25' International
Providence
, Senior Electrical Engineer
How long did you wait? The BR-1 modem needs time to reboot, connect, and restart the process. That can take up to a few minutes.
If you try now, does it work?
08-20-2019, 07:29 AM
#408
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
I’ve tried several times over the course of the past few days and have waited several minutes each time.
08-20-2019, 07:33 AM
#409
Providence
Give JC a call and ask for customer service. I'm sure they will know what is going on and can guide you quickly to the answer, they are open now, give them a call.
08-20-2019, 07:40 AM
#410
2019 30' Classic
Canfield
, Ohio
Once you disconnect the battery using the app remotely, you cannot turn the battery back on remotely. It shuts down the systems and I believe the modem.
So don't do that!
Tom & Doty
08-20-2019, 07:46 AM
#411
2019 30' Classic
Belen
, New Mexico
So don't do that!
That shouldn't be the case. The modem is connected to the 24hr circuit controlled by the keyswitch near the modem. In addition, in the front right speaker cabinet is another CZone module that is also on this 24hr circuit. This module is what controls the Remote battery switch. As long as the keyswitch is turned on, the system should be able to be remotely turned on AND off.
That being said, mine used to work and then after the upgrade that Airstream pushed out last month, it refuses to connect remotely. I can still manage things locally, but that sort of defeats the purpose. I could just as easily open the door and push the buttons myself. When I attempt a "remote" connection, it always responds that my trailer is offline even though it isn't.
08-20-2019, 08:00 AM
#412
2019 30' Classic
Canfield
, Ohio
Originally Posted by Ephraim
That shouldn't be the case. The modem is connected to the 24hr circuit controlled by the keyswitch near the modem. In addition, in the front right speaker cabinet is another CZone module that is also on this 24hr circuit. This module is what controls the Remote battery switch. As long as the key switch is turned on, the system should be able to be remotely turned on AND off.
I recently had my entry door panel replaced at JC as the battery disconnect button did not work on that panel at all. I guess I never tried using the app after that. I will try it now!
Wow! It worked!
The problem I had with my entry panel was that the disconnect button did not move at all. It did not feel like the other buttons on the panel.
Tom & Doty
08-20-2019, 09:04 AM
#413
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
So don't do that!
Turk: Thanks so much for your reply. If that's so, and I am certainly not disagreeing with you, why would the remote app have a function selection that allows for reconnecting the battery? My screen specifically states: "Battery disconnected. To reconnect power to all systems, and regain access to your controls, use the Battery Disconnect button". And below that message is a Battery disconnect function which, when pressed, brings me to the control page that has a message at the top stating "Reconnecting the battery (via remote)". That said, the app simply will not allow the remote reconnection for some reason.
08-20-2019, 09:13 AM
#414
2019 30' Classic
Canfield
, Ohio
Our posts must have crossed. Read above yours.
That said, does your battery disconnect switch on the entry pad by the front door work?
Tom & Doty
08-20-2019, 09:15 AM
#415
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
once you disconnect the battery using the app remotely, you cannot turn the battery back on remotely. It shuts down the systems and i believe the modem.
So don't do that!
our posts must have crossed. Read above yours.
yes!
08-20-2019, 09:21 AM
#416
2019 30' Classic
Canfield
, Ohio
There is a way to check if the Czone module in the speaker cabinet is responding to the LCD panel. If the dip switches are wrong, it will not see the module. My Airstream is in storage right now so I cannot check, but in the Czone panel on the wall, there is a way to look at all the button panels and devices and their dip switch settings. Also, see if one is offline.
Tom & Doty
08-20-2019, 01:04 PM
#417
2020 Classic 33
Box Elder
, South Dakota
If you want to dig deeper download the CZONE Configuration tool and then pull the config from the system. There is a CZONE manual for the COI unit which has a USB port. Easy to use a USB stick to do the download following the instructions in the COI manual. Then you use the Config Tool and can see all of the setting information, dip switch settings and the like.
If a module is not responding you will get a warning message on the display panel. In my case I am getting three warnings which remote trouble shooting with Jackson Center have not gotten resolved. Awning LT in bypass, Awning LT short and Display offline. The display is not offline since I am using it.
I'm guessing that the system needs a reset and reinstall of the config file as everything is working with the exception of the Awning Light and two of the buttons on the door panel constantly flashing. Gotta love gremlins.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
08-21-2019, 01:51 PM
#418
2020 25' Flying Cloud
Atlanta
, Georgia
Thanks, all, for this discussion. I've watched it through thirty screens now, and it convinces me that the system is too damn complicated and too error prone. THWI. I'm just going to use my cell phone's hotspot.
Odd that in this day and age Airstream can't figure out a way to make this foolproof.
08-21-2019, 03:21 PM
#419
2019 30' Classic
Belen
, New Mexico
They actually have a good product, but it has some bugs and is plagued by problems with the router they chose. I suspect that peplink sold them on that router's capabilities and they should have gone with the next higher up model. Everything else is fixable with simple software updates, but that hardware is an issue.
08-21-2019, 03:51 PM
#420
2017 20' Flying Cloud
Williamson County
Originally Posted by wulfraat
There is no fine print that it’s an “introductory rate” however mobile providers change their plans all the time. Nothing is guaranteed to be the same package-wise a year from now
Hmmm, just wondering if my GM LTE unlimited data ATT plan really is a fixed rate then. The agent that signed me up claimed the $20/month was guaranteed for as long as I kept a continuous contract which could be transferred to my next vehicle. BTW this seems to work well for us, and much better than iPhone hotspot.
