Old 07-26-2018, 12:19 AM   #15
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Originally Posted by advkrewe View Post
Was there anything you had to watch out for in the fridge vent? DId you drill the hole in the upper plywood and then run a snake up from the hole to bring the cable down?
My TV is not recessed and i think i have a double wall right behind the TV thus I cant see how to get through the double wall to where all the TV connections come out. Maybe I have to put a snake in there and see if i can find the bottom. but getting back there from the fuse panel is difficult. thanks I have more exploring to do.
I used a Harbor Freight fiberglass sectional screw together snake and ran it up from the open space behind the outside door to the refrigerator compartment. The snake came up on the street side of the vent close to the skin. I tied my coax to the end and pulled it down into the space. The overhead on the left side of that space is plywood and I measured where I would have to drill a hole to be under where my TV is mounted and the rear side of the overhead locker over the dinette is. The recess for the TV made it easy but if I didn’t have that I would have fished the coax to the side of the locker where the other TV and HDMI cables enter behind where the BluRay player is mounted. I ran the snake from the bottom up but did have to use a bore scope camera to find the snake behind the panel. Good luck with yours.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-26-2018, 12:31 AM   #16
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Advkrewe
“Was there anything you had to watch out for in the fridge vent? DId you drill the hole in the upper plywood and then run a snake up from the hole to bring the cable down?”
Stay to the right of the vent and poke the snake up until you find a passage alongside the condenser coils. Just don’t get too aggressive, you are in a clear channel to the roof or you are not. Keep moving your entry point until you find it.
Old 07-29-2018, 09:04 AM   #17
advkrewe's Avatar
2018 30' Flying Cloud
tarpon , Florida
I am well on my way with this install. Our to far in to stop now. Working from inside out, the fridge, the flu, and a big open space. IAM coming down the flu and will go in the open space through the plug opening. More once I get that far. Pics/video once I get done.
2019 30' Flying Cloud RBQ
2017 F250 Crew Cab 6.7
Facebook page
Instagram
Blog
advkrewe is offline   Reply With Quote
roof antenna routing in 2004 Land Yacht? DreamRoper Audio, Video & TV 0 05-01-2018 03:17 PM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
Original antenna wire routing? spaceghost65 1966 - 1968 Safari 4 06-28-2017 11:20 AM
An update and routing help - Route 81? anniemaine On The Road... 14 11-12-2013 06:30 AM
Routing a XM/Sirius Antenna Wire wolverine Audio, Video & TV 1 05-29-2013 03:29 PM
