06-28-2017, 07:57 PM
2012 27' Flying Cloud
W
, New England
MicroPulse dead - no response from Catcon...
So - on our last trip - the MicroPulse monitor showed the black tank full when it clearly wasn't. Eventually, the black tank stopped registering entirely! Two emails and one phone call in to Catcom over the past two weeks and still not a single response from them!
Today, the entire monitor is dead. No readings at all on tanks and battery - though the pump still works.
Is this a problem with the panel on the wall or is it something else? Really wish Catcon would return my emails and phone calls [emoji35]
06-28-2017, 08:02 PM
2004 30' Classic Slideout
Fenton
, Missouri
They were responsive to me, but that was several years probably 2008. What was interesting was that the guy I talked to told me the master panel had a 5 year warranty and sent me a complete new panel. He didn't even ask for the defective one back. You may still be in warranty dependent upon your purchase date.
This is the most current contact info I can find.
Catcon Products Inc.
7709 Sand Street
Fort Worth, TX 76118
817-590-8718
817-590-8756 Fax
sales@catconproducts.com
Link to their contact screen below:
https://www.shop.catconproducts.com/...3plqscsfapp006
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
06-28-2017, 08:16 PM
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
http://www.shop.catconproducts.com/M...0-10050-20.htm
or just order a new board .
Have your tried killing all power to the coach then firing it up again?
Laurence
06-28-2017, 08:27 PM
Seattle
, USA
The black tank monitors seemingly NEVER work.
But again...what's the purpose of them? You can easily tell when you're close to full when you flush the toilet.
The MicroPulse black tank monitor is WORTHLESS.
The little battery LED strip isn't accurate either...you need a real digital readout.
The fresh and gray monitors I can see as useful, but these actually usually DO work...but again are never REALLY accurate.
06-28-2017, 08:31 PM
W
, New England
Thanks Jack. I've now sent my 4th communication - let's see what happens.
06-28-2017, 08:33 PM
W
, New England
Originally Posted by LAWBC
Yes. I've had the coach completely disconnected for two weeks. Fired up tonight to get ready for the weekend. The entire panel is black now. No readings on anything - though the pump still works....I'm cornfused!
06-28-2017, 08:39 PM
Seattle
, USA
Nothing to be confused about. The pump wiring is separate from the panel wiring; just because the switch is mounted on the panel doesn't mean it is part of the panel electrically.
06-28-2017, 08:48 PM
GVA
, British Columbia
Just guessing here but wouldn't the board for the sensor be different from the pump which is basically a relay switch. In other words you still could have the pump working but that part of the board which runs the senors could be kaput.
Laurence
06-28-2017, 08:52 PM
GVA
, British Columbia
RareSteam , I'm thinking great minds thinks alike eh. I just types slower.
Laurence
06-28-2017, 09:02 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We replaced the dying Micro Pulse tank monitor system with the top model SeeLevel system in our 2014 Classic twp years ago. The 2015 23D came with the basic SeeLevel system and it still works fine.
06-29-2017, 08:18 AM
W
, New England
Either they read the forum or someone must have notified them I was whining here - just got an email from Catcon...
Testing instructions and black tank sensor replacement instructions for almost every model AS but mine. We'll see....thanks for all the input.
I'm very tempted to upgrade to the SeeLevel but the mothership quoted me something like $2500 if I remember correctly...since I can tell when the FW is full by the overflow of the filler neck, the toilet when it's up to the flange, the gray when it comes up to the shower and the battery with a voltage meter - it's not a crucial fix worth that kind of dough....
06-29-2017, 08:24 AM
Fenton
, Missouri
Well if your panel is shot will they cover under the 5 year warranty? I know Airstream won't supply the labor for free but Catcon will supply the panel if you are in that 5 year window. Check to see when you bought your trailer. I'm assuming you bought it new.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
06-29-2017, 12:23 PM
Washington
, Missouri
Hey SSM, Blue has been at the dealer for awhile for end of 2 year warranty punch list. The monitor was on that list.
During our last trip to Paso Robles it started to get erratic...black reading empty, (just emptied it) check...2 hours later 50%. Looked down the throat...MT. 30 minutes later MT reading in the BW again. Same erratic behaviors followed in the FW & GW tank readings. We use the shower for storage and the drain heads up isn't always a good plan.
Talking with the dealer, all punch list work was long done except the Monitor. Seems they ordered a new one and parts were on the way. Seems the "parts" ordered was a new monitor.
Ours is a 2014 bought new 5-2015 so just two years old. Someone mentioned a 5 year mf'r warranty.
Good luck on your resolution.
bob
06-29-2017, 12:24 PM
2001 36' Land Yacht XC Diesel 300 hp w/slide
Woodbury
, New Jersey
If you're interested in SeeLevel, you can check it out at
https://www.garnetinstruments.com/pr...-tank-monitor/
Garnet will also help you find a good installer if you're not handy and/or if your tanks are difficult to access.
06-29-2017, 01:23 PM
W
, New England
Originally Posted by windfallsp
Thanks - just sent them a message - let's see what this might run me...I think I'd rather do that than fix the MicroPulse. It was never my fave anyway....
06-30-2017, 02:03 PM
Washington
, Missouri
SSM, FWIW I attempted to puck up the TT today with an end of warranty punch list including the MP monitor. Apparently mine has being replaced but they had trouble communicating in a timely manner with Catcon. The dealer service guy indicated they are going out of business/getting out of the business.
If you're out of warranty, this may a time to jump to the sealevel.
06-30-2017, 02:25 PM
2005 30' Classic
Burlington
, Ontario
The micropulse in our trailer has always been useless - at least in icorporates a swicthto trn the water pump on and that works!
Frankly I don't see much need for one, and don't think I'd bother replacing it with a ore reliable system even if one was given to me!
Seems like just another electronic gadget that is a frustration when it doesn't work.
Guess my wife is right - I must be getting to be an old curmudgeon! But I can do without unnecessary annoyances!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
06-30-2017, 02:36 PM
2008 20' Safari SE
Charlotte
, North Carolina
We had a similar sounding problem a few years ago. I eventually discovered that a gunked up connection to the black tank sensor was causing the whole monitor to go haywire (except for the pump, which was unaffected). Disconnecting that sensor's wire at the control unit brought the panel back to life. We never bothered to replace the black sensor or its wiring after that, but just left it unplugged. Have not had a problem since then.
06-30-2017, 09:21 PM
2008 25' Classic
Full Time
In my 25fb near the water pump under the fridge the sensor wires come up from the floor. The are connected to the wires from the monitor panel with RJ11 connector for each sensor. You may want to check these connectors.
Kelvin
06-30-2017, 10:13 PM
2006 19' Safari SE
Anacortes
I gave up on Micropulse
I installed a Seelevel system a few years ago and it has functioned perfectly ever since.
http://www.airforums.com/forums/f444...-a-129739.html
It is not a difficult system to install.... well not TOO difficult for the average person.
George
