Ah, cool, thanks. Excellent shots on Instagram.
BTW, I figured out how to put my iPhone into "Field Test" mode, which is what we'd use to see how the 3/4G signal changes with boost.
The photo above nicely shows how you pulled wire from the internal wifi antenna via the FF after mounting it to the ceiling. Cool.
The photo in the following post shows one simple way to mount antennae to the TV antenna mast and bring the wires in via the FF. Looks like it would work with anything you can mount to the TV mast.
http://cdn.airforums.com/forums/atta...6&d=1185589434
