Originally Posted by wave man
Ok folks looking to put internet into the trailer, I see the plug outside.... but where does the plug inside reside? Can’t seem to put eyes on it.... anyone please!!!
Thanks in advance
Plug outside? On a 2018? Are you talking about one of the coax plugs in the Furrion port near the main shore power inlet? If so, and if you have coax cable-modem service where you're parking the trailer, you could put the cable in on the satellite port and there's coax for it somewhere behind your bluray player in that cabinet. You could put the cablemodem in the cabinet and run ethernet from there, or put a wifi router there (or your cable provider may give you a wifi cablemodem combo device.)
If you want both video and data from the cable company, you probably need to split the line before entering the trailer and hook up to both of those coax inlets, and if your cable provider is like most current ones you'll need some sort of converter box at your TV(s).
If you're not talking about those coax inlets, I don't know what you mean.
