Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 08-01-2008, 11:30 AM   #1
Traveler
rd tighe's Avatar
Profile:  2007 25' International CCD FB
midland , Michigan
Question installing sirius radio in 07 international f b
I would like to install sirius radio in my 07 international fb. When i look for a way to run the antenna I get a bit nervous I can get behind the radio and see the insulation and when i look on the roof i can see were the radio antenna is. Now all I half to do is get the satellite receiver up their putting a hole in the roof and running a cable to the radio doing this with out a leak in the roof a not tearing up the in side,the insulation or the out side easy? would love some guidance.
rd tighe is offline   Reply With Quote
Old 08-01-2008, 11:58 AM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you are not crossing a rivet line, indicates framing under the skin, between the antenna location and the place where you are putting the radio you should be able to drill a hole in the roof, from the outside, and "Fish" a stiff wire down through that hole to a hole in the inside skin behind the radio. Fishing take a bit of skill and patience. If you go Fishing tie a string to the end of the wire and once you have found the inside hole pull the wire and string into the trailer. Now use the string to pull your antenna wire up to the roof. When attaching the string to the antenna wire make several clove hitches along the antenna wire and with electrical tape tape the string to the end of the antenna wire so it is a smooth tapering of the electrical tape. This will reduce the likely hood of catching end of the antenna wire in the insulation as you pull it through.
The newer trailer use 2 sided foam to mount the skin to the horizontal framing on the sides of the trailer. I do not think tape has replaced the rivets above the windows so check out the rivet lines to know where the framing is.
If there is a rivet line between the 2 locations I would say short of removing the inner skin or drilling all the way through and running the wire on the inside of the trailer it is out of the question.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 08-01-2008, 01:33 PM   #3
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Yep, no inner skin in the upper endcaps in the FB models. I'd say drill an appropriate hole directly adjacent to the FM antenna in the end cap, thread the antenna wire down to the radio and call it a day.
Chris - Boerne, TX / Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 08-01-2008, 02:28 PM   #4
Roadtoaster's Avatar
Profile:  2006 28' Classic
Byhalia , Mississippi
Not sure if this will work for you, but one of the members here mounted the antenna on his Fantastic Fan, just above the screen, in the corner if I remember correctly. Said the reception was fine and no hole in the roof.
Greg
(formerly known as ptrvr)
Roadtoaster is offline   Reply With Quote
Old 09-02-2008, 10:48 PM   #5
DandB^2's Avatar
Profile:  2007 16' Bambi
Reno , Nevada
I looked at many methods and found the simplest to be to attached the antenna to the frame next to the jack. I ran the wire up the front and in through the front window. From there it goes directly into the front cabinet where the stereo is located. But thats on the 16' bambi. The only noticeable wire is about 1 foot from in the front of the rig. It was very simple and has been working with no problems for over a year.
Doug
DandB^2 is offline   Reply With Quote
Adding Sirius to JVC KD-HRD1 on '07 Interstate avid Sprinter and B-van Forum 0 07-16-2008 08:55 PM
The Ham Radio Station at Bozeman, MT International Rally airedale Phone, CB & Ham Radio 74 06-06-2008 05:24 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 13 09-21-2007 07:46 AM
Installing XM radio in a 1999 30' WB Tin Diesel Computers, Internet & Satellite 2 04-03-2007 09:24 PM
Sirius Satellite Radio jordandvm Audio, Video & TV 16 07-13-2005 04:14 PM
