Old 05-17-2018, 02:10 PM   #1
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Install Weboost mast antenna without attaching to body
I want to use the Weboost and telescoping antenna pole but I donít want to attach it to the body of the Airstream. Has anyone installed the antenna mast/pole to just the tongue? We have a 25í Flying Cloud FB so all the electrical stuff is right up front.
wareaglewalt is offline   Reply With Quote
Old 05-18-2018, 12:51 AM   #2
2018 30' Flying Cloud
Gig Harbor , Washington
Looking to do the same. We have a 30' FC Bunk and was thinking to have the wires tucked in towards the front/hitch and set up some sort of support where we could connect the pole when we're parked. The connection point would need to be sturdy with another support further up to extend the full 25'. Following..
hoagy_007 is offline   Reply With Quote
Old 05-18-2018, 12:53 AM   #3
2007 22' International CCD
Consider a steel or aluminum plate big enough to park one or two trailer tires on, with a sturdy, well-braced pipe you can put the bottom of the mast over.
rmkrum is online now   Reply With Quote
Old 05-18-2018, 01:03 AM   #4
Found this which may be a solution and not have to put a permanent mount: https://www.technorv.com/suction-cup-antenna-mount/.
Old 05-18-2018, 01:05 AM   #5
New to this and tried to post a link. There is a suction cup antenna mount from TechnoRV that may do the job.
Old 05-18-2018, 01:29 AM   #6
Surfside Beach , Arkansas
We have a bicycle rack on the back of our 23FB. Mounted a pcb pipe about 2 foot long, cap the end with a plug with small holes so the rain will drain out. Antenna is attached to a paint extension pole. Works great.
old 10s bum is offline   Reply With Quote
Old 05-18-2018, 10:14 AM   #7
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
I use a 20' telescoping flag pole to get my weboost antenna as high as possible. Oftentimes it's height you need to get a usable signal. I bolted a pair of 2" steel "L" brackets at the very top of the pole. The magnetic base of the short weboost antenna snaps to the brackets, the pole goes up and I bungee it at the top and the bottom of the awning bracket of the trailer. 2 mins to deploy, 2 mins to remove. Way better than the under tire type IMO. The bungee approach prevents the pole from banging into the trailer in wind. The unusual antenna draws questions at every campground... an ice breaker to meeting new people.
GammaDog is offline   Reply With Quote
Old 05-18-2018, 10:22 AM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
How much do you watch the wind forecast? High winds are the issue with antenna masts. What works "most of the time" may not work in crazy weather.
Old 05-18-2018, 10:29 AM   #9
silverslppr's Avatar
2006 16' International CCD
2008 25' Safari FB SE
Chicago , Illinois
We just did this this week! We have a 2008 25FB We bought a aluminum flagpole at Harbor Freight. Then we added a PVC pipe to the front hitch and dropped the flagpole (with flag) and ran the cable for the booster through the pole. At the top we have a truckers antenna (looks like a black cylinder) The cable then enters into the bedroom through the storage compartment right behind the propane tanks. Then it goes down the wall DC plug under the television and then the cable continues to run tight along the top of the wall past the shower and past the refrigerator. The "candy bar" receiver is Velcro-ed high above the television in the gaucho area.
Rosie
"SilverSlipper"
Michael & Dyanna
silverslppr is offline   Reply With Quote
Old 05-18-2018, 10:31 AM   #10
CruizinDux's Avatar
Tracktown USA , Oregon
I could not find the specific thread or reference (possibly with an image) but here is the product.
https://www.technorv.com/suction-cup-antenna-mount-1/
CruizinDux is offline   Reply With Quote
Old 05-18-2018, 12:26 PM   #11
2016 26' Flying Cloud
Bastrop , Texas
Antenna Connection to I Internal Modem and Equipment Placement
Great advice in previous posts for antenna location. What/where is the best way to bring the cable into the AS with minimal drilling or screen cutting. Also internal location of equipment. Thanks.
Tarcoola is offline   Reply With Quote
Old 05-18-2018, 12:51 PM   #12
That's the one I was looking at using myself.
Old 05-18-2018, 12:53 PM   #13
Can you share some of the threads as to where the best placement is?
Hoagy
Old 05-18-2018, 01:01 PM   #14
gecko's Avatar
2009 28' International
Pacific Palisades , California
Uncle Bob has it just right. As windsurfers, we travel to high wind areas and I can assure your that telescoping masts will not fare well in winds over 20mph! And bungee cords—yikes!!! Consider the damage of the mast slamming into your beautiful silver bullet!
Please make sure you pay attention to forecasts of wind velocity and direction. If possible, have two available mounts—one at front and one at rear-to make sure the wind is blowing the mast away from your coach!
When flying small flags in winds up to 25 (we fuel tfem after that) , we have learned to create a free standing mount away from the trailer.
If you know you’re in low wind areas, no prob—I especially like the plate with welded pipe over which you can place the mast base. As long as the wind isn’t coming directly over the nose, this should be able to safely handle winds up to maybe 15 mph gusts (not the same as the average wind!!!!)
gecko is offline   Reply With Quote
missing mast and antenna for 67 TW retrocar66 Audio, Video & TV 1 06-01-2018 08:30 AM
Mast recommendations for exterior 4G antenna joshjack Computers, Internet & Satellite 13 03-15-2017 06:21 PM
WeBoost Roof Antenna dougtuck Working on the Road 18 11-12-2016 08:49 PM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 10:50 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 07:08 PM
