Old 05-18-2018, 01:59 PM   #15
2017 27' Flying Cloud
Lake Forest , Illinois
I have 2017 FC... mounted SkyPro WIFI unit on roof with 30LB VSB tape etc. (nothing is pulling that off!), routed combined ether/power wire down through roof vent for fridge/freezer (did not need to remove at all, just price up the grill on top of vent and into the compartment above fridge freezer and connected to wifi router there... then fished router 12v cable back into void being fridge/freezer and connected to 12v block for fridge. Easy peasy. One very small hole in back of cabinet was all that was required and install cannot be seen from inside. Helps to have two people but I pulled the fridge forward a bit to get good access for wire fishing (which was the hardest part). Hope this helps.
kjbishop2 is offline   Reply With Quote
Old 05-19-2018, 06:54 PM   #16
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I wonder if the suction cup mount on the side of the Airstream could cause some separation of the nearest sealant joint for the panel you attach to given how much the wind moves the antenna mast some days.
I use the Flagpole Buddy attached to our Fiamma rack in the back of our 25 rear bed Airstream and tie it into the Satellite Antenna connection on the side of the Airstream.
I could see using a plate on the ground and drive a tent stake through it to keep it from moving. Then attach the mount similar to the Flagpole Buddy's to the front A-frame.
Here is what I have:
http://www.amazon.com/gp/product/B00..._detailpages00
Wilson Electronics 700-2700 MHz Wide Band Directional Antenna with F Female Connector $53
http://www.shop.flagpolebuddy.com/16...6016AL-Kit.htm
Flagpole Buddy 16 ft Aluminum Pole & 2.0 Mount Kit $170
http://www.verizonwireless.com/home-...er-with-voice/
Verizon 4G Broadband router with voice + wifi Free with 2 year contract
6Gb Data Plan + Access for 1 device = $80/month
Router is powered by a CUI, Inc. PYB20-T & PYB20-U 12 volt DC to 5 volt DC Inverter:
http://www.cui.com/product/power/dc-...pyb20-t-series
DHT Electronics RF coaxial coax cable assembly SMA male to F female 6''
DHT Electronics RF coaxial coax adapter RP-SMA male to F female
http://www.amazon.com/Reecom-RA-1601...ilpage_o01_s00
Unique Reecom RA-1601 Weather Alert Radio External Antenna $42
Here is an example of the plate that one could drill a hole or two in for tent stakes:
Name:	Bambi at Temperance.jpg
ID:	311430   Click image for larger version
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 05-23-2018, 01:25 AM   #17
2014 28' Flying Cloud
Boca Raton , Florida
Mounting antenna
I have mounted my antenna on a extended boat hook pole (West Marine- extends to 16’) using metal pipe hangers (Lowe’s). I used 4 of them- 2 attach to the tongue jack and 2 attach to the pole with SS threaded bolt material in between. Very easy and inexpensive.
Joohntooth is offline   Reply With Quote
Old 05-24-2018, 06:25 AM   #18
wareaglewalt's Avatar
Bushnell , Florida
Would love to see pictures when convenient. This sounds good.
wareaglewalt is offline   Reply With Quote
Old 05-26-2018, 03:05 PM   #19
Install WeBoost
Here are some pictures of how I mounted my WeBoost antenna to my AS and how I brought the cables into the trailer. I drilled a 2 1/2” holes thru each skin and mounted electrical input doors on each side with closed cell foam in-between to push the cables through.
ID:	312060   Click image for larger version
ID:	312062   Click image for larger version
Old 05-26-2018, 04:18 PM   #20
2017 28' International
Baileys Harbor , Wisconsin
The suction cup works well. I use it and put the cup on the windows. I then route the wire through the storage compartment and under the bed. I don’t have to drill any holes, and when I’m done I shut everything up tight. Before you decide which side of the AS you put it on walk around AS with phone and figure out the best reception.
Daquenzer is offline   Reply With Quote
Old 05-27-2018, 10:48 PM   #21
2018 30' Flying Cloud
Gig Harbor , Washington
The window is a good idea! I'm taking it you have a front bed and run the cable through the storage compartment behind the battery compartment? How many suction cups do you use?
Hoagy
hoagy_007 is offline   Reply With Quote
Old 05-29-2018, 10:49 AM   #22
Bushnell , Florida
This pole setup you have is along the lines of what I'm envisioning although I'm wanting to mount the pole on the front Jack. I'm hoping that short distance between the base at the tongue and just under the jack motor would be enough to support the pole. The length of the antenna pole for the Weboost RV 65 model will cause storage challenges for us. I'm also thinking of getting the omni directional antenna instead of the one you have to point towards the tower. Any input on using a maximum 16 foot pole with omni directional antenna would be great.
Old 05-29-2018, 10:54 AM   #23
Bushnell , Florida
What size pole do you use with these brackets? This is exactly what I want to do. Someone else posted about a 16' aluminum flagpole so I'm leaning that direction too. Did you get the hardware at just a local hardware store?
Old 06-01-2018, 08:33 PM   #24
2018 30' International
Boulder , Colorado
Originally Posted by Tarcoola View Post
Great advice in previous posts for antenna location. What/where is the best way to bring the cable into the AS with minimal drilling or screen cutting. Also internal location of equipment. Thanks.
Has anyone tried using the coax satellite input (2018 30RBQ) on the exterior of the rig for the antenna wire and the other end inside to the booster? I'm new to the Weboost idea and am assuming it uses coax between the outside antenna and the inside booster.
motozen is offline   Reply With Quote
Old 06-01-2018, 11:41 PM   #25
2016 26' Flying Cloud
Bastrop , Texas
Hey Motozen, really interesting point you made about the coaxial outlet on the outside of the AS. I presume it connects to the TV inside.
Could you use the outside coaxial access point to connect to the antenna, and connect the TV end to the router? Therefore you could use existing AS infrastructure to enable the wifi.
This would probably mean that you couldn't have TV and wifi at the same time, but maybe a switch could unable you to go between each one easily.
Thoughts??
Tarcoola is offline   Reply With Quote
Old 06-02-2018, 05:49 AM   #26
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You can use the TV coax for WiFi. It will work very poorly. WiFi is up at 2.4 or 5 GHz. The loss in the coax will be a killer ....
Old 06-02-2018, 06:42 PM   #27
Boulder , Colorado
Thoughts??
Our rig is in the shop getting all the niggly punch list items warrantied, otherwise I would just go out and find the other end of the Sat cable. It should come out over near the Blu Ray player, and is intended to plug into a Sat receiver. The post after this one states that the signal degradation would be huge, but that post also mentions WiFi and I thought we're talking about a 4G/3G cell phone signal booster. I'm not an electronics guy, so maybe he's right and this is a no go. Sure would make the install easier and cleaner if it worked using the Sat coax.
Old 06-03-2018, 04:47 PM   #28
BoscoMN's Avatar
The Weboost or cellular hotspots are using cell phone frequencies around 700 MHz to up to something a little over 1 GHz. While the standard coax inside the Airstream is not the best solution it has been working for me.
One could get the right, low loss cable and run that inside the
Airstream to gain back some dB lost but until I have the time to string the coax through the cabin to an appropriate area to host the equipment the existing wiring works well enough.
Spending the money on better than standard big box store RG-6 coax to go from the external antenna to the Sat/Cable connector on the outside of the Airstream would be worth the money/effort. Just make sure that you match up the impedance of the antenna, Airstream coax and device you are connecting it to - probably all are 75 ohms. Some antenna and devices are 50 ohms. The outside cable run is at least 3 times the length as inside the Airstream so it is 3x more important.
2018 F-250 6.2L Gas
missing mast and antenna for 67 TW retrocar66 Audio, Video & TV 1 06-01-2018 07:30 AM
Mast recommendations for exterior 4G antenna joshjack Computers, Internet & Satellite 13 03-15-2017 05:21 PM
WeBoost Roof Antenna dougtuck Working on the Road 18 11-12-2016 07:49 PM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 09:50 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 06:08 PM
