*Wasn't sure where to put this, so here it is.
Since we're full-timing and working from the road, I wasn't happy about wires wrapping around the kitchen dinette. And didn't want wires running up between it and the wall. As it'd be difficult to pull them out when needed.
So I installed a 2 inch cable management grommet in the table.
First thing I did was tape off the area to be drilled out with 2inch blue painters tape to prevent any splintering of the laminate. And then drilled my hole.
After that, vacuumed up, removed tape, installed grommet. Done.
Probably going to add a
Cordie next.
