Old 08-14-2018, 11:57 AM   #1
GuitarmanFL's Avatar
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
F-150 AT&T modem vis my Verizon iPhone modem??
Hey Folks:
My F-150 comes with an AT&T cellular modem. Apparently it has a greater ability to pull in a cell signal (If I subscribe to it) than my iPhone's tiny antenna.
Question: Would, assuming I use my trucks modem vrs my iPhone modem, it pull in more signal if I subscribe to the AT&T service and my trucks big antenna, big battery (it's an AGM battery), would I see an improvement over my iPhone in remote areas?
Thanks for any thoughts!
Brek D - Orlando, FL
330 watts Renogy solar
Natures Head Composting Toilet
2018 - 7,500 miles Orlando > Huntsville > OK City > Sante Fe > Durango > Gallop > Sedona > Orlando
GuitarmanFL is offline   Reply With Quote
Old 08-14-2018, 12:08 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Properly done, an external antenna sized appropriately for the band is going to outperform the internal antenna optimized for packaging within the device, and the built-in one will have the potential to have a little higher output, but it's not like the old days of big-wattage analog transmitters in the built-in systems. Do you have the option of a "30-day trial" like setting up new service for a handheld device?
I doubt the built-in system does any better than one of the amp-and-antenna systems that use your regular phone and service and just amplify the RF side of things, but it may be simpler to set up.
David
Old 08-14-2018, 02:25 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I have AT&T LTE WIFI in my 2017 truck and also LTE data / hotspot / etc.. on my iPhone. In the real world signal strength doesn't go up with the truck. Rarely if ever have I seen the truck get a signal when my iPhone itself could not. Yes, the truck has an external antenna BUT it is not boosted / powered to improve signal strength, it's simply an antenna.
Nonetheless there would be 2 reasons for you to get the service in vehicle:
1. If your truck has AT&T and your iPhone is Verizon - you can likely get coverage with one network you may have it with the other.
2. With the AT&T service for vehicle hotspots (at least with GM) your data is truly uncapped from a usage and speed perspective. If you use a lot of data this comes in handy. My AT&T account shows X Gigs used of 999 Gigs available each month and speed is never throttled after X gigs of data usage as with traditional line service
Good luck.
wulfraat is online now   Reply With Quote
Verizon and a new iPhone Acheron2010 Off Topic Forum 1 06-22-2018 07:23 AM
Verizon, iPhone use over internet idroba Phone, CB & Ham Radio 7 04-04-2016 08:00 AM
USB Modem using Verizon or AT&T networks zlee Computers, Internet & Satellite 10 04-04-2012 11:04 PM
Finally!!! use your iPhone as a modem for a computer over WiFi Albatrill Our Community 7 05-09-2010 08:08 PM
