Old 07-11-2006, 05:47 AM   #1
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Domed Satellite Antenna
Who uses the TracVision, King-Dome or the Winegard units? Anyone having problems using any of these systems? Which model do you have?
Dwight is offline   Reply With Quote
Old 09-05-2007, 08:58 AM   #2
1985 34.5' Airstream 345
Fishers , Indiana
I just got the new King-Dome today and am putting it on this week. I checked all three out and decided on the King_Dome but all were very similar. I will let you know how it works.
Wayne Olson is offline   Reply With Quote
Old 09-05-2007, 09:15 AM   #3
ScottW's Avatar
Hernando , Mississippi
I looked at all three and decided totally against a permanent roof mounted antenna. If you have a large tree(s) in your line of sight, you will not get a signal. I'm just going to continue to carry my portable tri-pod mounted unit with 200' of coax. It only takes a few minutes, but at least I can get a signal, or maximize my chances of getting one. Just my two cents.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 09-05-2007, 10:23 AM   #4
Stream 1529's Avatar
2004 34' Classic S/O
San Antonio , Texas
I have the King Dome. As stated, trees can kill the reception but that hasn't happened to us all that often. I find the convenience of pushing a button and having reception in less than 2 minutes is well worth it.
One suggestion. There are two LMB ports on the dish. Run one cable to your living room unit, and run another cable to your bedroom unit. With two receivers the front and rear TVs will work independently of each other. Just in case your spouse is tired of football.
__________Tom
Blog: www.travelpod.com/members/wbcci1529
'04 34' Classic S/O lounge, dome king, twin a/c, faux fireplace to keep the wife warm , equa-li-zer, prodigy, 4 birds, dog - no kids allowed!
'05 Excursion 4x4, 6.0 PSD, magnaflow, helwig anti-sway, air lift springs.
Stream 1529 is offline   Reply With Quote
Old 09-06-2007, 02:29 PM   #5
Fishers , Indiana
We finished installing the King-Dome today and it worked the first time. It was an easy installation that anyone can do. Just run the provided wires and plug in as directed. The only real wiring is connecting the 12V wire and ground. King-Dome are set at the factory for DirecTV so no programming or dip switches need to be set. Just press the button and wait 2 minutes.
But, as ScottW said above, trees can be a problem some of the time. We did leave our external cable hookup and plan on still keeping the portable dish onboard for those cases when we can not "have a clear view of the southern sky". But, it will be great to pull in and just press a button most of the time.
We have only one TV but we use DirecTV+ which allows us to record shows to watch later. DirecTV+ uses two LMB connections so that worked out great.
Old 09-06-2007, 02:52 PM   #6
ScottW's Avatar
Wayne;
You make it sound very tempting...again. I just worry about most of the campgrounds here in the south that we end up in. These southern pines are quite tall and abundant. Just not convinced it would be worth the money and only get to use it half or less of the time. Still thinking, but thanks for your input.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 09-06-2007, 03:31 PM   #7
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Fly By
Are these the type that locks on going down the road?
Like my manual one for now, but those are interesting.
Wouls like to hear how they perform.
klattu is offline   Reply With Quote
Old 09-07-2007, 12:46 PM   #8
Fishers , Indiana
Ours can be upgraded to lock on going down the road (InMotion) but we do not need to view while traveling. Eyes on the road!!!!!
Old 09-07-2007, 04:27 PM   #9
'65 Caravel 17'
jlovelady's Avatar
2001 34' Limited
1965 17' Caravel
Lufkin , Texas
King Dome
I have a King Dome on my 2001 34' Airstream.
The original owner installed it shortly after purchasing the unit.
The previous owner grew frustrated with the unit and disconnected it.
I am the third owner of this unit, have resolved the problems, and it works great. Seek and lock on time is often less than a minute.
jlovelady is offline   Reply With Quote
Old 09-21-2007, 07:42 AM   #10
Denis4x4's Avatar
Durango , Colorado
I have a King Dome on my 25' Safari that works great. However, trees can be a problem. I didn't buy an AS so that I could hole up in a nice campground to watch adults pat each other on the butt between commercials! It's more fun to sit in the shade of said trees and read a good book or converse with my spouse.
Denis4x4 is offline   Reply With Quote
Old 09-21-2007, 08:00 PM   #11
2000 34' Limited S/O
Jamestown , North Carolina
Satellite Antenna
I want to install a satellite antenna on my rig and would like some advice on which is the most effecient for the money. Many posts mention the King Dome. What about Winegard? Also, what are the advantages/disadvantages of the crank up dish? Wnegard makes one of those also.
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 09-21-2007, 09:41 PM   #12
Dwight's Avatar
1999 34' Excella
Joshua , Texas
antenna...
Get the KVH R4-SL, you will enjoy the results.
History doesn't repeat itself, people do!
Old 09-22-2007, 06:09 AM   #13
Satelitte Antenna
Dwight,
Is the KVH R4-SL system made by King Dome?
WBCCI #4358
Old 09-22-2007, 06:55 AM   #14
Dwight's Avatar
1999 34' Excella
Joshua , Texas
Kvh....
It is made by KVH, see their web site: TracVision R4 SL Satellite TV Antenna
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
