Old 06-25-2008, 07:47 PM   #1
Zugbug's Avatar
Volcano , California
Dish TV
On a recent trip I took the receiver from the spare room a portable dish 1000 dish and gave it a go. Well no luck I was able to find sat's 110 and 119 but not 129. Also the system gave me a smart card error, even though none of the three units I have installed at home use a smart card. Any suggestions?
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
Old 06-25-2008, 07:57 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
All the Dish Network receivers should have a smart card. If your bedroom receiver was slaved from your main receiver, the system will look for the smart card and not find it.
Also, 119 and 110 should be the two satellites you need, unless you have HD, or some premium channels, in which case you would need a separate dish. We have the 200+, and our Dish 500 dual dish picks up both satellites.
Old 06-25-2008, 08:12 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Our Dish Network boxes don't use a smart card either. There is a slot to put a card, but none is used.
On occasion when on the road, or when I return home I may get that same error message. When the message comes up, I just go do something else for a few minutes and it has always corrected itself. The first time it happened, I called Dish. I gave them my numbers and it came on as I was on the phone with them. Only called them once.
I only use sats 110 and 119. I don't subscribe to high definition so don't use 129.
Old 06-25-2008, 08:18 PM   #4
Well Preserved
1993 21' Sovereign
For whatever reason, ours has one (I'm watching Sci-Fi channel right now), and we occasionally get a "your smart card is not authorized" message when the receiver has been unplugged for hours or days, but it comes back after about 5 minutes of being on.
Old 06-25-2008, 08:22 PM   #5
toastie's Avatar
1955 22' Safari
Great Lake State , .
If the receiver has been powered off for awhile you will get an error. Dish will have to send a signal to the built in card, just call Dish with error number and they will help you right on the spot. However, I would highly recommend Directv. With my Dish Pro 500, I had a good sat. finder, plus algin-a-site, I could find a Sat. but you need to skew the dish to pick all Sat. and that was hard to do, very lucky to get all channels. With Directv all I have to do is hit one Sat. for all channels, no skew.
toastie is offline   Reply With Quote
Old 06-25-2008, 10:02 PM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I use an Accudish base. It comes with thumb screws to replace the hex nuts on the skew and altitude adjustments on your dish. With this base set up, and using a sat finder, I usually get hooked up in about five minutes. The base fills with water for extra weight and has cables attached for "nailing" down. Comes with three stakes and all in a very nice travel case. Supply your own dish.
Love it.
Old 06-25-2008, 10:25 PM   #7
Mexray's Avatar
1978 28' Ambassador
Morada , California
Or you could get a Trav'ler...
Name:	AS JC 5.08 (Medium).JPG
ID:	62880   Click image for larger version
Ray & Pat; Morada, CA
Old 06-26-2008, 09:51 AM   #8
Denis4x4's Avatar
Durango , Colorado
I use a King Dome. The local network channels use a spot beam and are generally unavailable outside your geographical area. 119 has Speed, the cable news networks, etc. and is the only one I bother to dial in. If there are trees in the RV park, I resort to a good book or Serius radio
Denis4x4 is offline   Reply With Quote
Old 06-26-2008, 10:12 AM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Distant Networks
If you are on the road a great deal of the time, you may be able to subscribe to local networks through All America Direct. They use sat 119. We were able to subscribe as we are on the road a lot. We get ABC, CBS, NBC and FOX from San Francisco and Atlanta. Leno at 8:35 in the evening.
We use it at home as well. It's $9.95 per month.
Old 06-26-2008, 10:25 AM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I looked at a roof top sat unit. There were two issues. First is that if you are parked with a tree or other obstacle blocking access to the sat, you have to move. Second, there isn't a space on the roof big enough to put one on our Caravel.
Down side of our unit, you must set it up and take it down each time you want to use it, up side, you can set it up "over there" to get a clear shot at the sat. More than once I have run a cable from the second output on our "Dish Pro" to our friend's sat box because their roof unit couldn't "see" the sat.
It's just a matter of choice.
Old 06-26-2008, 11:51 AM   #11
Zugbug's Avatar
Thanks for the information, any options if you are in a location were you don't have phone reception. Thats not going to work for calling to have them send a signal to the box.
Zugbug
2006 23' Safari
2006 F-150
Old 06-26-2008, 12:03 PM   #12
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Having the dish NOT work because of an error message is by far the exception, and, it has not failed to come on by itself in the past year and a half. We move our dish box at least once a month, and many times we move it lots more than that, and all over the western US.
Not an issue.
Old 09-24-2008, 04:14 PM   #13
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
I've come to the sad conclusion that my husband and I will never go camping anywhere unless he can watch tv. We even bought a cabover camper so we could go places that we don't dare take the Safari (our last trip north of Barstow literally popped rivets inside the coach and loosened the refrigerator vent ). But I digress.
We are Dish500 subscribers and have 1 receiver and 2 dishes (we used to have a 2nd identical receiver in the guesthouse for my late father-in-law). And I just have a few questions.
Can we use the 'house' receiver with the 2nd dish without issues? Most people seem to have a 2nd receiver to use with their dish, but is this necessary? Having had the f-i-l's subscription added to our bill, I realize there is an extra cost for the 2nd receiver.
Is a compass adequate for (quickly/easily) locating the satellites, or does anyone recommend any particular locating gadget?
We will definitely use a tripod, nothing fancy, but not something cheap and flimsy. Once again, any suggestions?
We will have a small generator, but naturally wouldn't want to run it in the evening, especially if others are camping nearby. We have a 12 volt inverter, is it possible run the sat receiver and 15" lcd tv off battery power?
Finally, wouldn't it just be cheaper to trade the husband in for a box of books?
Thanks in advance.
mtpalms is offline   Reply With Quote
Old 09-24-2008, 04:41 PM   #14
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Yes, you can run your Dish Box and LCD TV from an inverter connected to your 12v battery. You will need an inverter that supplies enough a/c watts to run both. The watt draw should be shown on the devices. You will also need an in-line "satellite finder" box to locate the satellite signal. A compass won't do the job.
You will need lots of battery capacity to watch TV for any length of time without running your battery down.
Satellite Dish TLMILLER Electrical - Systems, Generators, Batteries & Solar 31 06-06-2008 01:18 AM
Satellite dish for trailer? FL Bound Member Introductions 6 12-13-2006 12:16 PM
Dish Network vs Direct TV gwsullivan Electrical - Systems, Generators, Batteries & Solar 36 01-17-2005 02:49 PM
Dish Question DaveJ On The Road... 4 10-22-2003 11:43 AM
Sat dish trumpwer Computers, Internet & Satellite 2 04-06-2003 09:38 PM
