Old 08-13-2018, 10:04 AM   #1
2016 30' International
Florence , Alabama
Details on 2019 Classic tech specs
I wonder if anyone has been able to get more details on the new connectivity package included in the 2019 Classics. It states it has a built in WiFi booster with 4G LTE backup internet through AT&T and comes with 1 year.
To me that really sounds like a CradlePoint IBR900, but there are some other products out there that would do similar.
My big reason for wondering is - if it's something fairly standard I should be able to switch it over to Verizon instead of AT&T once my year runs out - or better yet I could use both and failover to the better connection.
joshjack is offline   Reply With Quote
Old 08-13-2018, 11:44 AM   #2
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I'm wondering also. I have an AT&T hotspot already. Don't need to duplicate it. There is a charge for a yearly subscription. AS said about $350
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 08-13-2018, 11:57 AM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I just downloaded the Airstream smart rv control app. It does not allow you to see the buttons, but it does talk about the process in the "FAQs" area. Looks like you get the first year free ($360). It also has a "Getting started" guide with 4 pages of details.
Get started!
Old 08-13-2018, 12:00 PM   #4
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Looks like you get a physical key to turn off and on the router in the cabinet. That certainly is unique!
Old 08-13-2018, 12:02 PM   #5
turk123's Avatar
2019 30' Classic
Canfield , Ohio
From what I am reading, it looks like it will pair with any hotspot. I'm guessing there is a Weboost or similar that may connect an outside antenna with the interior hotspot. It's not clear on this. I will look further into the electrical schematics.
Old 08-13-2018, 12:09 PM   #6
Florence , Alabama
WeBoost is just WiFi boosting.
The documentation clearly mentions a 4G LTE router built in, so Im assuming something like a Pepwave or Cradlepoint that will pickup and boost WiFi in addition to having a built in LTE modem.
Old 08-13-2018, 12:36 PM   #7
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I have a weboost that I kept from my old trailer. Can I assume that it just amplifies the signal from the cellular outdoors bringing it indoors and that my Netgear hotspot will pick up that signal inside? My cell phones worked great, but the Netgear hotspot did not seem to use that internal signal. Why?
Old 08-13-2018, 01:41 PM   #8
Florence , Alabama
No, cell signal is a different frequency range.
Old 08-13-2018, 02:55 PM   #9
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Maybe you misunderstood me. Here is what WeBoost said:
If all else fails to boost your hotspot, you may need a cell phone signal booster. A booster provides a strong, reliable cell signal for your hotspot, ensuring your devices that depend on Wifi have the data connectivity you need.
If youre using a hotspot in your home or office, any weBoost indoor cell signal booster will work well for this purpose. Place the hotspot as close as you can to the indoor (device) antenna so it receives the strongest possible signal.
I think my hotspot is not showing the proper bars. It is always on 2 bars no matter what. Works well though.
Old 08-13-2018, 03:04 PM   #10
Florence , Alabama
Originally Posted by turk123 View Post
Maybe you misunderstood me. Here is what WeBoost said:.
Fair enouGh, however based on what is known Airstream is including ATT access with this package. So I find it hard to believe they would strap a basic MiFi puck to a WeBoost and sell it. I think were looking at a real router meant for vehicle use.
Both PepWave and Cradlepoint support WiFi as WAN plus 4G LTE. That means a dedicated outdoor antenna will bring the campground WiFi in and protect you with a firewall from everyone else as well as letting your devices only have to remember the name of your internal WiFi network.
Old 08-13-2018, 03:14 PM   #11
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Just took a look at the cradlepoint gear. Do you really think they would spend $1500 for that type of router plus antenna? I only hope!
A weboost and a Netgear is more AS style. We will see.
Old 08-13-2018, 03:28 PM   #12
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Here we go! Guess they can be a bit cheaper. This looks very possible.
Name:	Amazon_com__Cradlepoint_COR-IBR650B-LP4-NA_4G_LTE_w_3G_Fallback_Router__Indoor_Enterprise_AT_T__.jpg
Old 08-13-2018, 04:32 PM   #13
Florence , Alabama
The IBR900 is $899 at 3Gstore. That means $600 wholesale or better.
Old 08-13-2018, 04:56 PM   #14
mojoe7009's Avatar
Green Cove Springs , Florida
I beg to differ. WeBoost 4G-X is a cell booster, not a WiFi booster. I have had one installed for almost 2 years and it significantly improves my cell signal in our Classic.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 08-13-2018, 07:33 PM   #15
Florence , Alabama
I stand corrected! But it still requires you to bring your own hotspot - and the AS docs clearly mention having a 4G LTE router built in.
Old 08-13-2018, 08:47 PM   #16
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The Classic does have a 4G router built in.
Service is through AT&T.
Current price is either $25/month for 5GB, or $360/year for unlimited.
The free year is accessed by purchasing a year for $360, then submitting the proper forms to Airstream, who will mail you a check.
Old 08-14-2018, 05:06 AM   #17
Florence , Alabama
Yes we knew that. The question is specifically what router did they use and could it be changed over to Verizon - or even support Verizon and AT&T simultaneously.
A number of these vehicle routers will support multiple LTE modems.
Old 08-14-2018, 05:15 AM   #18
1993 21' Sovereign
In that case, rather than asking the forum, it would be a better idea to give the people that designed and built it a call, and ask them. Then you can report back, and tell the forum what they said.
Old 08-14-2018, 05:39 AM   #19
Florence , Alabama
Well, I was checking here first to see if either someone had already done so; or someone from AS with knowledge might say something.
Old 08-14-2018, 06:58 AM   #20
mojoe7009's Avatar
A WeBoost 4G-X coupled with a Wilson Flat Plate Indoor Antenna will boost the cell signal for all cell devices without requiring a separate Hotspot. However, if you have device such as an iPad that does not have cell capability then a Hotspot would be required or you could use your phone as the Hotspot. Obviously, pre-2019 information since the technology will be included on the new units. Have no idea what brand of equipment they intend to use.
Ordering a 2019 Classic 30 thoughts/advice Maineiac 2016 - Current Classic (all lengths) 221 05-01-2019 12:34 PM
2019 classic 30 foot twin specs Docv 2016 - Current Classic (all lengths) 40 10-01-2018 03:36 PM
2019 AF Classic 33ft? jgoss 2016 - Current Classic (all lengths) 4 06-21-2018 03:00 PM
details,details az-streamer General Repair Forum 0 05-29-2018 10:10 AM
Cabinet specs - any specs out there KariRich Cabinets, Counter Tops & Furnishings 0 02-23-2016 11:58 AM
