06-15-2008, 09:12 AM
1972 23' Safari
Dearborn
, Michigan
Comments about Satellite Internet
I haven't tried on the road satellite systems, but we had it for almost 2 years at our house in Reed City. I had HughesNet and installed their better line of units with a 1M dish (too big for AS mounting).
First, it is pricey. The download performance is pretty good but sometimes varies a lot. It was still much better than dial up, our only other option.
With the big dish and 2W transmitter, weather usually didn't bother it too much except when the dish got 2 inches or more snow on it, then it quit. We also had to make sure the trees didn't block its view of the sky.
With the satellite, there is a good 1.2 second delay in packets reaching their destination and getting back (600 mS each way). Phone systems such as Skype work OK. TMobile with its Blackberry WiFi connection works but there is the delay issue which is real weird when you think you are talking to someone normally on a cell phone, you tend to talk over each other.
There are several vendors that sell mobile satellite systems but Hughes does not appear to directly support that configuration. I was enough dissatisfied with the fixed system not to explore the mobile version.
With the data capabilities of Cell phones and the AirCards, I don't recommend it except for people spending extended periods too far from a cell tower. Although for anyone that far out of touch, I would highly recommend getting your ham license and running WinLink 2000 to get your email. It would also provide backup communication if there were an emergency.
Tom Bray
06-15-2008, 02:16 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Tom Bray
Interesting Idea Tom, Thanks for the pointer. I am trying to work out what to do for next summer. I can tell you that the cell card just isnt getting it done for me on the road this summer. I hope to be working as I travel so internet is a requirement.
06-15-2008, 07:26 PM
1972 23' Safari
Dearborn
, Michigan
Unfortunately, ham radio and revenue generating activities don't go together. For the normal family status and keeping in touch, amateur radio is great. Also if you get in trouble the radio is a great way to get help.
If you are making money (or at least attempting to), you need to use one of the commercial systems. Hams and the government get real upset if they catch you using Ham Radio for business purposes.
Satellite isn't cheap but it does work with its limitations. Using it in a business setting should allow writing off the expense should help. I wouldn't host a conference call over satellite.
My daughter had one of those Blackberry Curves that found the household WiFi that was connected through the satellite. The audio quality was normal cell phone, but there was the 1 second time lag between us when we were talking. Once I realized what was going on, I could deal with it but the general public would probably have no idea what to do.
Another option is that truckers have systems that allow them limited internet capability on the road including email but it doesn't include conventional web browsing.
You may want to see if there is a satellite enabled phone that you can plug the computer into.
If you are at all near civilization, you could try one of those wired amplifiers that you plug your phone into and have an antenna on the roof. I think Wilson has products that do that along with several other companies. It gives you essentially the same capability as the old bag cell phones that put out several watts.
At our house in Michigan I had a cell phone repeater that went to a yagi antenna outside. That got the signal through the dense trees to the cell tower but it required pointing the antenna fairly accurately. The system I had only repeated the 800 MHz signals, Nextel and the Sprint / Cingular systems didn't go through the system. Newer repeaters deal with all of the different systems.
I have found that just having an outside antenna plugged into the phone really helps coverage, but it isn't magical. The low power of a standard hand held phone really limits its range.
Hopefully this helps. I am sure there are others out there that can offer other options.
Tom Bray
06-15-2008, 10:34 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
Sometimes we are surprised by the cell service we get in some of the most out of the way places.
A Verizon or other Air Card might be your solution. We have friends who live too far out to get DSL, too far out for cable, so got a Verizon air card. They use it when in their motor home as well as at home.
06-16-2008, 05:26 AM
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville
, Tennessee
Internet usage/access
Tom Bray
Tom,
I don't know if this is going to be any help to you, but I use the new internet card from Verizon, It firsts connects by cell service, if not available it then looks for WiFi connection. I have used this in all my travels and have never had a problem with connection even out in the remote areas, However I have not had the chance to use it my AS yet. Verizon has the best service of all services and I have all them and always come back to Verizon, As far as the AS I was recently watching an episode of RV TV (rvtv.com) and they discussed this issue and showed a new system through wilson that increases your cell signal and gives you an outside antenna to help, and then partners with a wireless router so you are unplugged and I am going to be investing in one of these to put in my AS for next year.
As for the various cell services, I can tell you this for a fact, with all the recent buy outs of different companies Verizon has the largest antenna coverage, Verizon has taken the Cell internet access to the next level, Cingular/AT&T has the best programs as far as roll over minutes etc, Sprint/nextell/Embarq have been named the worst of all and everybody I know has dropped them.
Hope I have given you some info that helps
Sarge
06-16-2008, 10:50 PM
1972 23' Safari
Dearborn
, Michigan
I haven't needed a real mobile solution yet, although I am trying to get work to pay for a mobile solution for me.
It seems that we manage to find either a fast food place or a coffee shop with internet so we can check our email. Plus the truck, at least for another year, has OnStar in addition to amateur radio equipment. The AS will also have a radios installed so if I get disparate I can talk to someone, even if they are on the other side of the country.
For cell service, we currently have Alltel. It was the only choice where we lived in Michigan if we wanted anything approaching reasonable service (although I noticed that the OnStar phone in the truck always seemed to work).
Where we live now, Alltel again is the only one with reliable service at the house. The other popular provider here is TMobile and it isn't on any near by tower.
Sometime this summer I need to get a new phone and I will make sure that at a minimum I can plug my computer into it. I may also pick up a new repeater to put in the AS so the phone doesn't have to be tethered to an antenna.
Tom Bray
06-17-2008, 06:25 AM
2002 27' Safari
Churchville
, Maryland
Air Card
I tried the AT&T air card and the results were less that satisfactory.
Web browsing was not possible as pages timed out before completely down loading. Salesman said it would get better when G3 is rolled out everywhere. I cancelled the service.
06-17-2008, 09:11 AM
Austin
This post is about satellite internet, not cell air cards.
06-17-2008, 09:51 AM
1977 27' Overlander
1963 19' Globetrotter
Naples
I need someting like that at my place in the hills of ohio,my option is take computer about 2 miles down the road to the top of a hill to use it ,then it is sooo slow.Maybe some kind of an antenna I could mount in a tree ,on top of one of my hills.At least while I was waiting for something to happen,I could have a cool one,and not worry about Ohio`s finest. Dave
PS Didn`t Verizon buy Alltel ?
06-19-2008, 10:26 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
Any reason not to?
In looking at the material that Maxwell satellite puts out and from checking around, it appears to me that of the $1650 they charge for equipment, about $400 of it is the cost of a one location system and the rest is for mobility. Again, as far as I can tell, the mobility comes down to the tripod, the aluminum arm, and aiming device. As I understand it, there is freeware aiming software out there. So here is my question: what is the argument against having the aluminum arm fabricated and getting ones own tripod then getting service direct from Direcway (the same provider you would have anyway)?
06-19-2008, 02:37 PM
_
...With the data capabilities of...AirCards...
hi tom
the aircard, booster and antenna approach makes even remote or fringe usage possible...
and this view is from a user who does NOT carry a cell phone, just the air-card...
and it is SO MUCH quicker to use than satellite, not to mention available while IN MOTION...
altel was recently purchased by verzion, so the borg expands.
yes there are regions still off the cell grid,
but IF camping in those spots,
u will still likely need to go get water and food occasionally...
and access may exist when getting provisions, or a local library or senior center or dry good merchant may have access...
i was recently in a very remote/hidden from cell towers spot and still go a weak connection.
and the local 400 sq ft 100 yr old 'store' had free wifi...
right next to the dried buffalo jerky, shovels and expired dried beans....
i am SO glad not to have purchased ANY of the obsolete out of the box sat systems...
cheers
2air'
06-19-2008, 04:53 PM
1975 31' Sovereign
Searcy
, Arkansas
2air'
lol
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
06-19-2008, 05:44 PM
1972 23' Safari
Dearborn
, Michigan
Somehow I knew when I started this thread that it would evolve into a different discussion.
What I was hoping for was that someone would come up with some other suggestions related to using satellites that I hadn't found.
I also find it amazing just how important the internet has become. For us, the Internet is far more important than TV. We found we could easily live with 2 or 3 over the air network TV stations and be happy (especially when we found out we could get HDTV better than traditional signals). Dial up was driving us nuts.
Tom Bray
06-19-2008, 05:58 PM
2006 19' Safari SE
Tucson
There's a great book by Airstreamer Rich Charpentier (member name "gadgetat") called The Digital RV that will answer many of your questions and give you alternatives...to anything having t do with getting "digitally wired" while one the road. It's a great book written for an easy read that just about anyone can understand the technology he discusses... You can get it at his blog site ( Gadget's Airstream Chronicles - Documenting my Airstream Safari and what I do with it! ), at Airstream Life magazine shop ( Airstream Life magazine store - Books and CDs )..as well as other places...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
06-19-2008, 06:04 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Tom Bray
What sort of suggestions were you thinking of Tom? I too have been looking at sat service pretty closely and need to make the leap before next summer. I hope my comments didn't move your thread off topic.
06-19-2008, 06:18 PM
1972 23' Safari
Dearborn
, Michigan
I was hoping that there was some nifty commercial service that had popped up since the last time I did serious searching two years ago.
If there were reasonable alternatives, I could also justify doing some of my work on the road instead of being office bound.
My gut feeling is that the best on the road service is going to be plugging a blackberry into the computer. I just have to get more comfortable with idea of carrying around a PDA for phone (I chucked my PDA about 8 years ago).
Tom Bray
06-19-2008, 06:40 PM
2006 19' Safari SE
Tucson
Have you checked out "Internet in Motion"? Internet In Motion, mobile internet access It's a solution that might work for you and is not as expensive as a regular satellite connection.
When I was doing this sort of research for myself because I wanted to be able to work while on the road, I finally decided on the air card option because I didn't want to invest in all the electronic equipment ($$) that is likely to be obsolete in a matter of a few years. When my air card contract runs out I will re-think the topic to see if things have changed enough to warrant another direction...
I am a graphic designer and have to move large files and I have found that between email attachments (albeit with some limitations in file size) and the use of FTP sites for transferring larger files, I can get along nicely while on the road and work seamlessly...as long as I can get a cell signal. Clients don't even know I'm in an Airstream "studio" while dealing with their needs unless I tell them. Our style of travel has not left us in too many places where the air card doesn't work and if that becomes a issue, then the booster antenna option is still out there.
I realize the thread is about satellite connectivity, but no discussion of satellite would be complete without including info about air cards options. After all, the end goal is getting connected.
AirForums #21900
PastPrez, 4CU/WBCCI
06-19-2008, 07:43 PM
1999 23' Safari
Perrysburg
, Ann Arbor
The problem is that there are still LOTS of boondock areas where there is NO cell signal ... and lots of areas down in low areas (like near trout streams!!!) where there is no horizontal line of sight that might be useful with a big-time booster antenna, but such sites often have perfect "up" line of sight. So I too have been looking - with marginal success for some sort of reasonably-priced satellite up and down link service. Seems that the technology just isn't mature for that yet. And given that MOST areas do have cell link available, so that aircards will work there, there's not a lot of economic incentive to develop new systems.
06-19-2008, 08:35 PM
Dexter
, Missouri
I am using the Verizon usb card in a mobile router. I have an amp and a Wilson Trucker antenna mounted to one of my solar panel frames. I have only lost signal twice for shot distances, both out west in the desert. We do a lot of remote boondocking and I have a beam antenna that I can use if needed. So far I have not had to use it. I had planned to use the satellite set up but in the last 12 months the Verizon setup has come a long ways. Certainly there are places the card is not going to work, however I have no buisness that deep into the wilderness.
Dan
06-19-2008, 08:58 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Tom Bray
Tom, I may have a line on just that. The service would be (I think) through direcway/hughes though, which I think you said you didn't care for. If I can get it worked out I may set up a system later this summer or fall. I will keep everyone posted with what I come up with.
