Originally Posted by Smoky I'm at an rv park that has good high speed internet. I have two computers and a router in my trailer. I want to network the two computers. I'm fairly certain I know how to share an internet connection...so one computer accesses the internet through the other one. I'm wondering if I could use my router to somehow connect to the rv parks router. In other words I would like to network my two computers so they connect to my router....and then have my router access the internet via the rv parks router. Is this possible? |
OK, I will play this straight.
Your question has multiple issues that need to be addressed.
First, yes, each of your computer(s) can each access your router.
What I am trying to understand, is why you would have a router IF you have your two computers "tied" together to access the network. If you are doing this, one of your computers is acting as a router already. A router is really not needed if you are doing this.
So, assuming that your question is legitimate, I will respond.
Each of your computers can connect with your router. This does mean that they can no longer be "networked" together.
The real issue about your router connecting to wifi in an RV park (or anywhere else, for that matter) is totally dependent on the firmware that is running on your router. I am not aware of ANY router that is shipped by a manufacturer that allows IP addresses to be obtained by way of DHCP when the router is configured to operate as a repeater.
Based on my experience, all of the router manufacturers hardware is configured with firmware that requires a hard coded IP address when they are configured to operate as a repeater. What does this mean?
A router can be configured to operate in numerous way. One of them is to operate as a repeater. A repeater does, very simply, what it's name implies. It connects to another router and "repeates" the signal from that router. So, in an RV park (or any other wireless type of encounter) the RV park has a router that broadcasts a wireless signal. Anyone within range of the signal can connect to it.
For purposes of this conversation we will NOT discuss the type of connection the broadcasting router is configured to offer; secure (pass-worded, or not pass-worded) or not secure. If your computer is in rage and can receive the signal you can connect.
Your router, set up as a repeater, can also connect to the a broadcasting router and "repeat" the signal. The key here is that your router MUST be configured ot operate as a repeater. AND, it must be able to obtain an IP address via DHCP. If you cannot obtain an IP address by way of DHCP, you must have a hard coded IP address; this means that the person in charge of the wifi network you are connecting to can provide you with an IP address; this is not going to happen.
Once again, I am not aware of any firmware that comes with a router from any manufacturer that allows the router to be configured to operate as a repeater AND obtain an IP address via DHCP.
BUT, there is a solution if you have a piece of hardware that is supported by some public domain firmware that can be installed on your router that replaces the factory installed firmware. This is DD-WRT.
IF your are technically inclined, installing this firmware on your router, IF it is in fact supported by the DD-WRT team is not too difficult. But, this is NOT for the technical novice. It is VERY easy to "brick" your router - this means that it will never work again!
I am guilty of making a somewhat LONG post in respose to another wifi question here:
Why does my wireless come and go?
I suggest that you peruse this thread for additional information....
