02-08-2011, 09:07 PM
1974 Argosy 26
Morrill
, Nebraska
Can I make it work?
Now here is an area I no NOTHING about. Well! I know a little; just enough to be dangerous and get myself in trouble on occasion.
So here goes.
I have an OLD laptop;with 128MB of RAM and a PENTIUM III processor 850MHz. With Windows Me installed. It has a CD drive and USB ports and a 3 1/2" floppy drive. Like I said OLD. I am connected thru a LAN system to the internet with DSL (I think that's what it's called; a modem with a single pair phone line in and an ethernet cable out).
I am using it to type this in.
I would like to use this laptop when we are traveling to do map quest, Google earth and send and receive emails, perhaps to make campground or RV park reservations and surf the net incase I need a part or something. Maybe find a nice restaurant to take my lovely wife out to dinner.
Will this old timer work for those basic things?
I have an extra slot where my wireless LAN card plugs in. If this laptop will work. What do I need to buy to make it work?
Do I have to sign up and pay a monthly fee to use it for the aforemention service?
02-08-2011, 09:18 PM
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
PIII laptop
I think the machine is going to be overworked. How much time have you got to wait on it????? It will be slow and possible insecure as the Operating system is old . Surfing on air I would want at least XP, or better.
Dave
02-08-2011, 09:43 PM
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands
, Nevada
A different suggestion.....
I don't know how brave you are, but if you are wanting to resurrect that old laptop, and learn some new tricks in the process, you may want to think about just reformatting that hard drive and putting a "light" version of Linux on it. You could have a working laptop for free and Linux would get that running no problem.
Linux is really good at making an old machine work like a newer one. I do agree that this old laptop is probably at the end of its useful life as it sits. But with a shot of memory, pumping it to the max, that old rig could indeed do all that you are needing.
BUT - if you really are needing to upgrade things here is another suggestion - donate that old computer to a needy organization and look for a local "used computer" store near you. For a few hundred bucks, you can buy a refurbished laptop that is faster and has a more recent operating system and more memory. I have had a few friends do this as a way to get up and running for not a lot of $$$$.
02-08-2011, 10:07 PM
New entry level laptops are in the $400 range. How much is your time worth?? With your old rig you are going to be spending lots of time lost in cyberspace.
02-09-2011, 01:40 AM
Retired.
, At Large
Your old laptop probably has USB 1.0 on it, which means the connection may not be fast or powerful enough for plug-in wifi cards. Many programs and those cards will only work with Window XP or newer. If you don't want to give the Linux option above a try, and that still won't fix the slow-speed USB issue, you can get an entry-level laptop, netbook, or iPad that would have built-in wifi, and be a lot more compatible and reliable. I remember Windows ME, and it is an operating system I (and Microsoft) would rather forget. Careful shopping can get you a new laptop for less than $400, and if you keep it as long as your current one, it will amortize out at about $35 a year in cost of ownership.
02-09-2011, 04:50 AM
1974 31' Excella 500
Charleston
, South Carolina
This makes sense.
On the road you have to get your internet through the air. Because you will be moving around and will want internet everywhere you go, your choices are 1. Mobile internet from a cell phone company. Verizon seems to have the best coverage.
The simplest thing is probably a USB modem. It plugs into your USB port on the computer. It has a piece of software to install along with it. The plan is similar to a cell phone plan. I pay $50 a month for 5G of data. I've gone over the limit once in two years.
Simple and convenient.
Whether your USB port is too old (is compatible or not) I have no idea.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
02-09-2011, 08:00 AM
2008 22' Safari
Oracle
You can do all of that with an IPhone and it includes a camera that takes stills and video.
02-09-2011, 08:15 AM
2008 16' Safari
Destrehan
, Louisiana
Your old laptop will work fine for emails and surfing the net. Your software will not cut it. You will need Windows XP to load the drivers for the wireless devices. Also, the memory is too small to support Windows XP. It will run, but very slowly. A memory upgrade and Windows XP will set you back almost as much as a cheap (but new) computer. Check WalMart and Best Buy to find a cheap laptop. All you need is the most basic laptop with Windows 7 installed.
02-09-2011, 08:30 AM
2007 27' Safari FB SE
Full Timers just passing through
, Arizona for a couple of weeks and then on to Utah!
That laptop will make the perfect boat anchor...use it for that and get yourself one of the new laptops mentioned in the posts above. The frustration level alone dealing with ME and a slow computer will add years to you very quickly.
Living life on the Road
02-09-2011, 09:14 AM
1974 Argosy 26
Morrill
, Nebraska
Darn
I don't own a boat so I guess I'll have to find another use for it. Thanks everyone. It sounds like I need to start shopping.
02-09-2011, 09:31 AM
Tub City
, British Columbia
Laptop PIII
I would not throw it away! (I never throw anything away. I try to find a use for it.) It just is not suited for Wireless. As long as you are hard wired it can still be used for many things, especially those sites with little advertising. If you watch the market, use it on a stock program like "Stockwatch", Stockwatch or similar program, along with your newer computor. (Don't do banking on the old one.) It is the advertising and graphics that uses up the capability of these older units. BUT THEY STILL DO NUMBERS WELL.
A second computor comes in handy for many things, including reading instructions while cleaning up virus or other problems on you new machine.
I still have a W98 upgrade from W95 (it would not upgrade to W98se so never got the info to the newer Operating systems, although I updated it to P200) and still use it many times. It will run Stockwatch with no problem.
Dave
02-09-2011, 09:37 AM
1974 Argosy 26
Morrill
, Nebraska
No way
OH! I won't throw it away. It works fine for stuff like this. It's faster than my typing. I'm using it here. I can be on the laptop when my wife is on the desk top. The desk top is really hers anyway.
02-09-2011, 09:46 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Can I make it work?
Greetings TG Twinkie!
Originally Posted by TG Twinkie
I have an OLD laptop - 128MB of RAM
- PENTIUM III processor
- 850MHz
- Windows Me
- CD drive
- USB port
For surfing the Internet, your computer still has adequate power for most situations. If your RAM memory hasn't been maxxed out, adding RAM memory to the maximum that your system will support should significantly improve its Internet performance.
- Will this old timer work for those basic things?
- I have an extra slot where my wireless LAN card plugs in. If this laptop will work.
- What do I need to buy to make it work?
- Do I have to sign up and pay a monthly fee to use it for the aforemention service?
What you propose is possible through use of a wireless modem. A wireless modem does present you with a monthly service plan - - I haven't done much investigation, so don't know whether there are plans that permit you to purchase minimal minutes some months with greater time other months. You would be looking for a wireless modem similar to these offered by Verizon -- see this link.
When shopping for wireless modem service some questions that you should ask of the representative include:
- Will your device work with the Windows Millenium Edition installed on my laptop?
- If the device won't work with Windows Millenium Edition, the probability is that the cost of upgrading your Laptop to permit utilization of Windows 7 is likely going to be cost prohibitive if it is even possible.
- Are there any minimum RAM memory requirements?
- Does your device require USB 1.0, 2.0, or 3.0?
- Your Laptop probably has either 1.0 or 2.0, but may be upgradable - - the cost may be a consideration.
- What plan options are available for your Wireless Modem?
- The cost of plans can vary tremendously as can the minimum duration of the contracts. Sometimes the contracts can be piggy-backed or combined with your existing cell phone plans, but this can vary tremendously according to carrier.
You may find that it makes more sense economically to seek out free Internet hotspots and utilize your wireless antenna. If you find that your computer doesn't have the power to run a needed operating system upgrade, it is possible to buy remanufactured computers from Dell and HP that allow for a comparatively reasonable entry into a newer system.
If the route of utilizing the laptop and wireless modem becomes cost prohibitive, upgrading to a modern cell phone such as a blackberry that supports both Internet browsing and voice communications may be a more economical alternative.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
02-09-2011, 09:57 AM
Trabuco Canyon
I'd also recommend the $450 -500 modern laptop route. To make your current laptop serviceable, I would recommend more memory (512+) and USB wifi adapter. I'd also recommend Windows XP as the earliest supported OS which would run on the laptop (sluggishly). You may get by with Windows 2000 if you don't care about MS updates and the wireless adapter still supports it. The laptop battery also could be on its last lap.
All the effort and cost to bring it up to minimum standard for basic internet use to me isn't worth it when you can get relatively modern $450 laptop at Costco, etc.
02-09-2011, 09:04 PM
1990 34' Excella
Springfield
, Missouri
.......and it's so much fun!!!! Or, go iPad!!!!!
bugnot1
jan
03-17-2011, 09:08 PM
1986 34.5' Airstream 345
Longview
Yeah - if you don't have a boat, it's definitely time to start shopping - especially since you apparently already have a perfectly good anchor!
Here's a suggestion: You ought to be able to set up a wireless network where the new laptop connects with the USB modem and cell service to the internet, and allows "other computers" to access the internet through it - and then access the net wirelessly on the old computer through the new one's internet connection - that way you and the Mrs. can both surf at the same time while your cruise control is set, and safely taking you down the highway...
Oh - wait...
03-17-2011, 09:41 PM
2006 19' Safari SE
Tucson
Oh my goodness....you would be SO much happier not having to dink around with outdated technology...everything is much easier and faster and better. Take the plunge and get a new 'puter or one of the pad options. Save the old one for nostalgia and keeping recipes on in the kitchen or something if you don't have that boat... I still have the first Mac laptop I bought...it runs but I would grow old(er) just waiting for it to boot up these days! (And I'm getting older fast enough as it is.)
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
03-17-2011, 11:02 PM
Tub City
, British Columbia
Laptop
If you want to know the true value of you electronics, just ask your kids or grandkids, if they would like to borrow it for the weekend.
They will give you some insight as to where to put it on the asset list.
Better yet - ask them if they have an old unit you can borrow. Chances are they have thown out higher quality units.
Dave
03-17-2011, 11:41 PM
1974 Argosy 26
Morrill
, Nebraska
Some Success
Well! I took a gamble and upgraded this old unit from 128MB to 512MB of RAM and what a difference. Cost less than $50.00.
I guess that I wasn't clear when I gave the original description of what I have here. I left out the part about having (I think it's called) a PCMK slot; actually there are two.
I have read here in 3 or 4 places that I needed to be hard wired thru a modem for this old timer to work surfing the net.
I have a Linksys wireless-G adaptor plugged into the aforementioned PCM?? slot and am communicating thru a router that is plugged into an ethernet connection via a DSL modem.
My wife has a desktop about 6 years old now; it has XP on it so you know it's not new. If we both push the power on button at the same time; this old timer gets me to the internet in about 90 seconds. The desk top can take 15 minutes at times.
There are still a couple of issues with this old timer though: about one out of 5 times when I power it up, it doesn't activate the wireless card; no icon shows up at the bottom of the screen; and I find myself having to power it down and restart it and it works.
The other thing that happens; Normally I check my email "hotmail" first. When finished with the emails, if I go to surf the internet from my email page and click on a website, which I can readily view; if I go two or three levels into something and then back out to my email page; everything locks up. Get the message "Program Not Responding". "End Task" does not get me out of it. I have to do the old CTRL; ALT; DEL thing and then restore the desktop when it comes back up.
Now it doesn't happen every time, this is very confusing to me. But I'm easily confused.
So I guess I'll take it to a more populated place where there are known "Hot Spots" and see if I can do anything with it.
We live between "NOWHERE and NOWHERE ELSE" We only have cell phone service outside the house and that's if you stand just right and hold one leg up. LOL
Thanks to everyone who chimed in here. My 66th is coming up sooner than I would like, so maybe there will be something that will show up with a 15" or 17" screen; if you know what I mean.
