Old 06-01-2007, 10:51 AM   #1
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
add XM to audio-video pkg?
When we bought our 07 AS, it came with the audio- video pkg. It did not come with satallite XM radio.
I want to add XM. Has anyone done this to the audio-video pkg? If so, does it plug in directly to the Sony main receiver, or to the black control box?
I have the black control box where I can see it, but there is no place to plug anything extra into except a headset. So, I thought maybe it is supposed to be plugged into the back of the main receiver. I can't see the back of the receiver, but will take it out if anyone knows if that is where XM plugs in.
Thanks for any answers or suggestions.
Pat
starflyte1 is offline   Reply With Quote
Old 06-01-2007, 11:48 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Pat, I don't know about that particular radio, but one option with the XM portables (if that is what you have) is to set it up to broadcast on an FM freq while plugged into your tow vehicle, then simply tune the radio in the Airstream to that freq. Mine will send a strong FM signal about 50 feet. The drain on the TV battery is minimal. Not the best solution, but it does work well.
www.nesa.org
Air No. 6427
Old 06-01-2007, 12:18 PM   #3
OpenHigher's Avatar
2006 Safari SE
Los Alamitos , California
Pat: Sherry and I use XM in both the tow vehicle as well as the airstrream, using the portable XM. We are in So. Cal, so we tune the car radio, or the Sony A/S radio to FM 83.3. I run the magnet antennae out the door, over the bottom portion of the Zip Dee Awning, and attach the magnet to the bolt on near the sway bar. I try to point the front of the antennae south, since that has worked best. One 110 plug goes into 110 power, or if you do not have 110, but you have the inverter, then plug into the 110 plug which is used by the inverter. It is by the door. Of course you have to turn on the inverter switch by the kitchen sink. It uses very little battery power. Last, plug in the small plug into the Line Out female socket which is located inside the cabinet near the radio. You should have your sound now,
Good Luck.
OpenHigher is offline   Reply With Quote
Old 06-01-2007, 12:20 PM   #4
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
Sirius antenna installation
I was researching the exact same thing but with Sirius since it came with our TV and is only $6.99 per month to add it for the 2007 Safari. I figure I can determine where to connect it to the Sony radio but running the antenna is a concern. Does anyone have an idea how to run the antenna from the Sony unit to the roof?
SilverCottage is offline   Reply With Quote
Old 06-01-2007, 12:32 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Many of the new radios come with XM or Sirius capability. You add the appropriate blackbox and it reads on the radio faceplate.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-01-2007, 12:38 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Also keep in mind that the satellite radio market is struggling. From a long term basis it's questionable whether XM, Sirius, or even the merger of these two companies will have sufficient income to save them. The latest financial reports from both companies have been dismal and the retention rate shows an upturn in the subscribers bailing out.
So before you start drilling new holes for that satellite antenna, understand that things might be changing in the not too distant future.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-01-2007, 01:41 PM   #7
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Jack
That is disappointing, because we have a lifetime Sirius subscription for the truck. I guess it was Sirius' lifetime not ours
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-01-2007, 03:53 PM   #8
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
We did it
Pat,
I just plugged the XM module into the back of the Sony. It works great and was easy to do. You will have to make sure your Sony is XM ready and then match up the XM modulefor that model Sony.
-Ken
4CU Charter Member
silverback is offline   Reply With Quote
Old 06-01-2007, 08:36 PM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I seriously doubt Sirius and XM will both go away. Even if the companies go bankrupt, I'm sure someone will pull an Iridium and be back on the air without the debt that XM/Sirius have. (Iridium is a satellite phone network that was started in the early '90s and went bankrupt for a variety of reasons, but of course the satellites were still up there and functioning. So someone else bought out the satellites and was able to start up a successful service using the constellation without the debt of having to launch them.)
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-02-2007, 12:28 AM   #10
AgZep's Avatar
2005 28' International CCD
Las Cruces , New Mexico
The CD changer in a normal car stereo attaches to the back of the head unit, usually with a highly proprietary interface. One company I know of, PIE, makes a device that you plug between the two. That device includes a set of RCA jacks that you can connect to anything. The way it works is that the PIE device detects a signal on the auxiliary input, and switches the interface to take the signal from that side, rather than the CD changer. As soon as the signal drops on the auxiliary side, it switches the feed back to the CD changer. I put a PIE device in my 2001 Silverado so that I could plug an MP3 player or my XM in, while still maintaining all the factory radio functions, like speed sensitive volume. Very cool.
Our 2005 CCD has the factory audio/DVD upgrade package. In 2005, the Airstream factory adopted a similar type of interface (at least on our trailer) so that the stereo could handle the CD changer, TV audio, etc. I just pulled out the stereo head, plugged a stwitchbox and cables to one side of the interface, and now I have the original wiring, plus a box that selects the XM or MP3 when I want them. Very slick, very cheap.
AgZep is offline   Reply With Quote
Old 06-02-2007, 06:51 AM   #11
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Jack
Perish the thought . I love XM, I hope they havent killed it signing up "names" like Opra and whoever that other loudmouth is...
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-02-2007, 11:21 AM   #12
R&SZinser's Avatar
Yorktown , Virginia
I added a XM SkyFi2 to our trailer setup. My wife loves XM and she uses it all the time while we're in the trailer.
Here's the thread of how I ran all the wires & pluged into the stock JVC Head-unit. Adventures in Audio/Video
R&SZinser is offline   Reply With Quote
Old 06-02-2007, 01:47 PM   #13
starflyte1's Avatar
Lady Lake , Florida
I removed the Sony unit from the cabinet, but did not see any place to plug in the XM. What a mess of wires!
So, I just ordered a Belkin Boombox for a RoadyXT. That will replace the older "bow tie" boombox I have had for several years, but no longer works.
I will mostly use the Belkin with a headset or pillow speaker, so really don't need to hook it up to the Sony. Just thought it would be nice, and get rid of some clutter.
Thanks to everone who contributed to this thread and the link to the other thread. It did answer all my questions, and hopefully will help someone else.
Pat
Adventures in Audio / Video R&SZinser Audio, Video & TV 11 08-13-2007 07:32 AM
Grey water waste tanks... Chuck Waste Systems, Tanks & Totes 32 08-11-2005 06:07 AM
Add Running Gear Links Here Action Link Archive 2 09-13-2002 08:01 PM
Dinette - would like to add Diesel Dude Cabinets, Counter Tops & Furnishings 2 08-07-2002 05:08 AM
Add your event to the Calendar! Andy R Forum Admin, News and Member Account Info 0 02-27-2002 09:22 AM
