Old 05-11-2018, 08:06 AM   #15
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Originally Posted by wareaglewalt View Post
Without the AC adapter it takes a LOT longer!
The AC adapter is nothing but a USB charger. Read the label on it to get the amp rating. Buy a 12V to USB adapter with the same or higher rating. Even the early AC adapters that were shipped with the old iPhones and Pads have a lower output current.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-11-2018, 09:21 AM   #16
San Jose , California
There are variations in frequency of the AC supply when using a Inverter. The high frequency components of the AC are not filtered out by iPad charger and DC ground level also get shifted.
So now we can get to the basics of how capacitive touch works. Capacitive senors works on principle of capacitive coupling which takes human body capacitance as an input and senses it and there is a change in flow of current through the capacitor. So in all its a capacitor which works on Principle of DC charging and discharging. So when it detects an AC noise passing through it gets totally messed up allowing all the noise component of current to pass though it and giving out some erratic response. Hence what you are seeing.
SanJoe is offline   Reply With Quote
Old 05-11-2018, 03:36 PM   #17
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
One thing to note is that iPads are known to have their touchscreens act up when not being powered by an Apple power supply. This is very noticeable if the iPad is fully charged and left plugged into a non-Apple power supply while you are typing. I had an evening of frustration until a lot of Googling discovered a number of threads on this design sensitivity.
Since then I only operate the iPad while using an Apple power supply off of 120 volts or using the Airstream's built-in USB ports when less than 90 percent charged. I've given up on ever using inexpensive chargers.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 05-12-2018, 02:06 PM   #18
BoscoMN's Avatar
I forgot to mention that the issue is exasperated if the iPad gets to 100% charge and you leave it on a charger that is not an Apple charger. Mine kept giving me multiple repeat characters for each keystroke.
2018 F-250 6.2L Gas
Old 05-21-2018, 12:17 PM   #19
2011 22' Sport
Portland , Oregon
This is an odd blanket statement, I've personally never encountered it and don't use _any_ Apple branded chargers as they are all overpriced and underpowered. I use 3rd party high wattage 12V to USB adapters, and 3rd party 120V to multiple-USB port adapters as I don't want to use 4 power outlets to charge 4 devices...when I can do it with a single adapter
YMMV I suppose, but it could just be that you are using low quality 3rd party adapters?
SilverHouseDreams is offline   Reply With Quote
Old 05-22-2018, 06:32 AM   #20
BoscoMN's Avatar
I believe that you are correct that it was probably caused by poor quality power supplies. My iclever power supply never causes a problem - even when I do a software update the iPad/iPhone finds this supply ok.
2018 F-250 6.2L Gas
12 volt
weird weird weird. 12v goes dark. click. wulfraat Batteries, Univolts, Converters & Inverters 8 10-10-2016 01:14 AM
Weird 12 Volt Issue Art Culinair Electronics & Connectivity 37 09-01-2012 02:36 PM
An App For The iPad That's Worth Getting The iPad (almost) murreywalker On The Road... 13 08-21-2011 08:19 AM
Act of Kindness 53flyingcloud Off Topic Forum 7 04-17-2004 06:44 PM
Monsoon, act II Pahaska Our Community 11 10-25-2002 07:34 AM
