Old 07-30-2015, 08:55 PM   #1
Air Apparent's Avatar
Northern Illinois , Illinois
XM Satellite Radio Antenna
Our 2008 Airstream came with a Sony radio that is XM Satellite ready.
I would like to install a permanent XM antenna on the roof. Has anyone done this? If so, what antenna did you use and where did you purchase it.
Thanks for the help.
Dave
2008 Classic 34
Dodge Ram 2500 Quad Cab CTD
AIR #7317 WBCCI #1772 TAC-IL 1
Air Apparent is offline   Reply With Quote
Old 07-30-2015, 09:27 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My Interstate came with an XM antenna already installed, so I can't help you on that. But as for what antenna to get, I'd say go straight to the source…
Antennas - Shop - SiriusXM Radio
They have reconditioned antennas that aren't too expensive.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-30-2015, 09:30 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
You should be able to get one directly from Sirius/Xm. Have you tried that? Have the model number of your head unit in hand when you call. We've been subscribers for years and love it. One big negative....their customer support/tech support is ALL offshore now. Drives me nuts. Caveat Emptor
www.nesa.org
Air No. 6427
Old 07-30-2015, 09:46 PM   #4
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I ordered mine from West Marine made by Shakespeare. I believe you will also need a SirusXM vehicle tuner for compatible ready radios.
Steamy1 is offline   Reply With Quote
Old 07-30-2015, 10:03 PM   #5
Got gandkids?
You might also check with these guys: C. Crane Wireless FM Transmitter FM2. CCrane is a great company.
www.nesa.org
Air No. 6427
Old 07-31-2015, 12:54 AM   #6
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I have a marine antenna on mine. Will check and be back with the data.
http://www.westmarine.com/buy/raymar...j2BhoCb6bw_wcB
This is mounted near the front by the factory. Here is a photo, and you will see a small gray projection in front of the antenna which is a lexan branch protector....keeps things from tearing antenna off roof.
https://flic.kr/p/u7aF4X
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-31-2015, 06:33 PM   #7
Thanks for the info.
I will follow-up on the leads you have given.
Ms Tommie Lauer - I couldn't get the flic link to open.
I would like to see the photo.
Dave
2008 Classic 34
Old 07-31-2015, 08:48 PM   #8
Msmoto's Avatar
2007 25' Safari
Images: 135
Both links work for me. Send me a PM and I will email you more info.
Ms Tommie Lauer
Greensboro, NC
AIR #31871 K4MTL
Old 08-01-2015, 08:00 AM   #9
I retrofitted a Sirius in my Airstream. I had to get a new radio as there was no internal tuner available for the radio I had. Any automotive radio will fit and they are easy to install. Pick one that has a Sirius tuner option.
My radio sits in the streetside forward overhead cabinet. The antenna is a regular vehicle outdoor one from Sirius. I drilled a hole in the aluminum skin right above the radio and sealed it with silicone. I wanted to rig the wire through the window frame to avoid drilling but that wasn't feasible. Cost for parts was about $500.
We camp where there is no tv signal available and Sirius radio is nice to have.
handn is offline   Reply With Quote
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 9 03-23-2015 12:43 PM
Satellite Radio Antenna Install HCoover General Repair Forum 5 02-27-2013 04:40 PM
Satellite Radio Antenna Install Toronto_Guy Audio, Video & TV 11 03-06-2009 05:08 PM
Sirius Satellite Radio jordandvm Audio, Video & TV 16 07-13-2005 03:14 PM
Satellite radio antenna mounting & wiring silverback Electrical - Systems, Generators, Batteries & Solar 6 11-14-2004 06:24 PM
