Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-15-2007, 02:41 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
It Won't Stay Up
I have an original antenna on a 71 Overlander. When you crank on it the leading edge raises about 8 inches but then it suddenly drops back about 5 inches. Crank on it again and it does the same thing.
Any ideas as to what's causing my problem.... Thanks.
Old 06-15-2007, 02:45 PM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
What a thread title!
So many many jokes I can't make on a family forum.
Don't worry someone who is not a wise acre like me will give you a usefull answer.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 06-15-2007, 02:53 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Yes, the title of the thread is an eye catcher!
The antenna crank is attached to a worm screw which inturn drives a gear that raises the antenna. I suspect that the gear is stripped at the location where it fails. You might want to invest in a new bat wing antenna rather then look for parts for the one you have. At least it doesn't leak!
Richard
azflycaster is online now   Reply With Quote
Old 06-15-2007, 03:16 PM   #4
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
you can find the plastic gears at any Airstream dealer or
at Vintage Trailer Supply - Vintage travel trailer parts and supplies!
$10 plus shipping.
garthbf is offline   Reply With Quote
Old 06-15-2007, 03:18 PM   #5
Central , Mississippi
If the design is the same at the newer "Monument to the flying Nun" types, it's an easy and common fix. Almost any RV dealer will have the two plastic parts.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 06-15-2007, 04:25 PM   #6
Silver Mist
LI Pets's Avatar
Riverhead , New York
You need to put a little blue pill in the gears
Old 06-15-2007, 09:10 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Ran out to the c/ground tonight to finish painting the emblems. Quick look at the antenna setup - how do you get to the gears? Do I have to remove it or can I get to them from the inside.
Old 06-15-2007, 11:41 PM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We all have that problem once in a while.
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 06-16-2007, 08:15 AM   #9
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Unfortunately, you can not get at the gears from the inside. You have to take the antenna off the roof and dismantle it. When it happened to mine, I went to a batwing. The amplified version has the amplifier in the head and it therefore much better than the old Clothes hanger type that has the amplifer in the wall of the trailer.
Old 06-16-2007, 08:54 AM   #10
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
I tried it!!!
Now my antenna is up so high the BBC is coming in like it is right next door!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 07-01-2007, 08:43 PM   #11
1978 28' Argosy 28
sarasota , Florida
the old " clothes hanger type " works very well, clean the elements with a brillo pad, eleminate the 300 ohm twin lead, replacing it with RG 6 or better coax and you can forget about needing the amplifier for most reception area's
roy sedgwick is offline   Reply With Quote
Old 07-01-2007, 08:47 PM   #12
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If you change to a new style antenna, remember that the old one is "trade goods."
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-02-2007, 04:37 AM   #13
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Haven't tackled the job yet. I did inspect it and all the fasteners are rusted so I got all new brass screws - stainless wing nuts, etc.. It has coax patched to ribbon cable above the roof and ribbon cable inside. There's no way to replace with all coax - the ribbon runs out of a cabinet - behind the wall then up to the antenna by the vista view.
I think it just needs some tlc and the new gear set (which I have now - thank you all) - but we will see.
Old 07-02-2007, 04:49 AM   #14
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Cute...
AFTER THIS..I nearly broke the handle..it wouldn't come down~!!
THANKS FOR THE SMILE...
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 02-21-2008, 04:30 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Just an update here. I didn't get around to removing and rebuilding the original Braund Skyliner antenna last year. But, it worked out OK. This week we found an original Braund Super Skyliner - the seller said it was new. It came today in the original box. It still has all the parts in the packing bag including a spare gear set, the wall amplifier box and a new aluminum roof support for it to rest on. Sometimes you just get lucky....
Old 02-21-2008, 04:41 PM   #16
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I just checked our worm gear and it seems ok! There is a bit of a kink, is that OK?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-21-2008, 04:41 PM   #17
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
My Braund Skyliner reception wasn't too great until my brother, who does dish installations, put new ends on the cable. Viola! It gets great reception now, even way out in the country! I put new gears in the one on my former trailer & it wasn't that big of a deal to do. The roll pin that was in there was the tuffest part for me to remove. Have fun up there!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-21-2008, 04:42 PM   #18
Becky B.'s Avatar
1964 17' Bambi II
That's really gross!
Becky
1964 Bambi II
1988 Avion 32S
Old 02-21-2008, 04:48 PM   #19
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Actually pretty funny.
Fyrzowt is offline   Reply With Quote
Old 02-21-2008, 04:50 PM   #20
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Must be a guy thing.
Stay hitched or unhitch? starflyte1 Hitches, Couplers & Balls 17 12-11-2006 08:11 PM
Looking for yearly stay in Florida Daisy2 On The Road... 4 10-05-2006 10:32 PM
stay up late for the light show jpurdy Off Topic Forum 8 05-16-2003 02:09 PM
Where to stay - Berkeley, CA pjtaia On The Road... 2 08-17-2002 11:56 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 02:49 AM
