Old 11-29-2013, 02:49 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Wireless back up camera.. Recommendation
I have just restored a 1960 airstream overlander and I want to install a wireless back up camera. I want it to work well so what are your recommendations.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 11-29-2013, 03:02 PM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
My son-in-law has an IBall. Works great. I'm getting one for Xmas.
DryFly is offline   Reply With Quote
Old 11-29-2013, 03:18 PM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Avoid the yellow one...the black one is a $99 Walmart special.
I got them to help hitching with the Hensley...to be honest, I don't really use it much anymore.
Name:	CAMERA TEST 028.jpg
PFC
but Im the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-29-2013, 03:34 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Brian
Do you want to mount the camera on the back of the tow vehicle, as an aid to lining up to hitch up the trailer, or to mount on the back of the trailer as an aid to backing into a campsite or parking space and to see behind the trailer in traffic? You're likely to get different recommendations depending on which application you intend.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 11-29-2013, 04:23 PM   #5
Lothlorian's Avatar
I want it for backing my trailer up into campsites. Honestly it will be when my kids use the trailer (both are adults). I don't feel confident with them backing up. My fear is they would feel horrible if they put a dent in it and so would I.
Brian
Brian & Adrienne
Old 11-29-2013, 04:59 PM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I am inclined to agree with Bob.
I have the yellow one (Swift Hitch) and even using it to hitch up, the signal often seems to break up.
Even if that does not happen, depending on the time of day /direction of the sun, it can be a bit tough to see the opening in my Hensley hitch as I back up.
I can see the end of the stinger on the truck, but on the trailer end often everything is just a field of blackness and I cannot differentiate the hitch box.
I still continue to fiddle with it to get the best I can out of it and have found a few tricks that do help.
The screen is very small too and that doesn't help.
One trick I have found that helps is to lay a 1" wide bright yellow tape measure on the ground leading to the hitch box and I line the stinger up with that and follow it back!
I doubt very much if it would give you any decent signal at all if the camera were to be at the back of your trailer - unless there is something wromng with the one I have.
I'll be interested to see what other suggestions come up - even though I have this one, I would consider buying a different type if there is one that is highly recommended at a fair price.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-29-2013, 05:12 PM   #7
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
For lining up to hitch I just put a couple small strips of blue tape parallel to each other on the middle of the back window of the TV and the same on the top of the LPG tank housing, line 'em up and backup. DW tells me when to stop. I bought an iBall but returned it before using it.
I am interested to hear about cameras on the back of the trailer. Seems like it would need to be wide angle to be useful.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 11-29-2013, 05:22 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a backup camera on the truck- works great for hitching up- now i want one on the back of the Airstream for backing into campsites...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-29-2013, 08:42 PM   #9
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
A post of mine from a few months ago....
I just finished installing a Magellan Road-Mate 9055 wireless backup camera in my 1995 21ft Sovereign. It was a breeze. Behind the black housing that holds the license plate is all the wiring to hook it up. A white ground wire and a the black reverse light wire, tap in to those wires and you are good to go. Camera comes on when you put the car in reverse and displays on the Magellan. The cam mounts in the two screws that hold your license plate. The only glitch was weak signal strength, I had to let the small two inch black transmitter rest outside of the trailer beneath the black license plate box. I originally had it hidden in the insulation behind the box, but the signal would not reach the Magellan in my tow vehicle.
Now if I can only convince people all the dents in my Airstream were there when I bought it!
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 11-29-2013, 08:47 PM   #10
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Swift Hitch... Any one else using one? I thought they looked pretty good so I put it on the wish list. Want it mainly for hooking up. Any other feedback would be great.
Silverflames is offline   Reply With Quote
Old 11-29-2013, 09:01 PM   #11
dznf0g's Avatar
Oswego , Illinois
Here's my write-up on a rear of trailer backup install. At the time of my parts search, there was no digital camera and monitor available. There is one now...I think it is called Voyager. Digital signals pass through aluminum and longer distances better and don't get interference from bluetooth and wireless modems...but they are expensive. I am still happy with my setup, albeit with some camera unit fix-ups. (A longer story)
http://www.airforums.com/forums/f450...ras-83497.html
-Rich-
Old 11-29-2013, 09:10 PM   #12
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I let my adult children use my T@b, it came with a million sticky notes of instructions including campsite was chosen ahead of time and had to be a pull thru. I am afraid I am going to dent back of my new to me AS so lending out is even harder. They did not travel, more stayed in one plAce, all was ok.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 11-29-2013, 10:13 PM   #13
2002 30' Classic S/O
Banning , California
Talking backup camera
Wingeezer,
I have the inexpensive camera from Sams club that mounts on the truck liscense plate bracket and it works just fine for hitching up to the Hensley. I also had the problem trying to be exact when backing up because everything was dark when approaching the hitch. I solved the problem by painting a 2" or so white mark on the top of the stinger, right on the top end. Then I painted the square around the hitch box white also. Now it's very simple to get it right every time. Hope this helps solve your problem.
Chip
Chipster is offline   Reply With Quote
Old 11-30-2013, 07:45 AM   #14
Thumbs down
I got one, first one junk..sent back, second one junk...sent back.
Third one...
IMHO...don't take the chance.
PFC
RLC
Successful installation of wireless backup / rearview camera longdog Audio, Video & TV 29 08-22-2011 02:51 PM
Wireless Backup-Camera campadk Electronics & Connectivity 31 11-29-2010 09:32 AM
GREAT Inexpensive wireless rearview camera Pete Vermont On The Road... 16 05-04-2008 03:50 PM
Wireless Backup Camera for Your Bambi campadk Electrical - Systems, Generators, Batteries & Solar 39 07-23-2007 08:08 AM
Wireless backup camera gklott Electronics & Connectivity 5 01-11-2005 01:23 AM
