Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 10-09-2009, 10:33 AM   #1
cammur's Avatar
Profile:  2005 25' Safari
Roseville , California
Winegard Sensar won't swivel (rotate)
While cranking up (or perhaps rotating) my Winegard Sensar Antenna (2005 Safari), the handle, spring, and rotating collar flew off.
I've resembled per Winegard's Operating and Instruction pdf and from the roof I've sprayed silicone spray on the raising gear and between the roof swivel contact points, and in the little lubricating hole on the plate. (This lack of regular maintenance probably led to my problem.)
It now raises just beautifully but will not swivel, when attempted from the inside as intended, or by having someone hold the rotating collar open from the inside and attempting to rotate from the roof.
I would like to dismantle from the roof to get to the rotating gear plates but can't from the manual understand how to do this. I don't want to remove the raising worm gear or break the roof seal if possible. Ideas?
Of course, I can eliminate the need for the swivel by simply hitching up and rotating my trailer, but this is clumsy and doesn't meeting the discipline of many campgrounds.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 10-09-2009, 10:56 AM   #2
kennethowens's Avatar
Profile:  1975 Argosy 24
Malakoff , Texas
It could be max'd out either left or right.
Raise the antenna. Swing it all the way left
and then all the way right. Find the midpoint
of the rotational swing. If no swing, then
take the handle and plate off and locate the
"Binding". It will bind if the antenna is not
all the way up. I did the install on mine and this part
may take you a bit of time to adjust. It sounds like
an adjustment issue. It took me awhile also.
Please be patient
kennethowens is offline   Reply With Quote
Old 10-09-2009, 12:41 PM   #3
2airishuman's Avatar
Profile:
Originally Posted by cammur View Post
...Of course, I can eliminate the need for the swivel by simply hitching up and rotating my trailer, but this is clumsy and doesn't meeting the discipline of many campgrounds.
hi cam
had the same issue and renting 2 spaces 2 rotate the trailer got expensive.
____________
wag, but here is a suggestion...
-RE-remove the crank and rotator knob AFTER the bat wind is UP.
--grab the flat sided/round rod with a pair of VICE GRIPS...
---gently rotate while PUSHING UP on the rod (via the v.g.)
----IF this works, reattach the internal knobs BUT NOT SO FIRMLY to the ceiling, the knob needs a tiny GAP to work...
____IF this doesn't work...
get a view cube or one of these other gizmos...
the newest thing in satellite television!
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-09-2009, 01:18 PM   #4
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
The parts are available at just about any RV store and fairly cheap. When I have called Winegard they were helpful.
Pay no attention to the man behind the curtain- WoZ
Old 10-10-2009, 04:25 PM   #5
cammur's Avatar
Winegard won't swivel - the final solution
Thanks as always for the suggestions. I now have it working (raising and swiveling) and here is what i did:
  • Raising/lowering - As I reported, silicone spray - the first application since probably the factory - now allows me to raise and lower with only the right level of resistance. I'll now spray the topside gear whenever I encounter Resistance, or minimally once or twice yearly.
  • Swivel - I sprayed it seemed like ounces between the swivel plates and also in the oiler hole but could not get it to turn with the force I was willing to apply. I reluctantly bought ($22) something called a Tenna-tool that is supposed to let you adjust the swivel from the inside without risking breaking the seal to the roof; the tool fit, but I couldn't get it to turn. I went back on the roof re-shot more spray (this is now a day or two later) and took channel-locks to the topside mechanism and forced it - it broke free and now swivels happily. (I'll try to return the tool.)
  • crank handle popped off - problem began when excessive resistance and force caused the crank to pop off, firing the handle, rotator, spring, and bearing about the trailer after bouncing off my head. I read somewhere this is a common problem. I bought a replacement bearing (must have swallowed the old), reassembled, and used (removable) LockTite to secure the setscrew. Test-OK. This should do it.
I'm sure my problem developed from four years of weather and no maintenance to these parts - I'll now regularly spray both the raising gear and the swivel plates.
This is a great community - thx again to everybody that provided input.
Cam
2005 25' Safari SS
AIR #8752
Roseville, CA
winegard sensar antenna
Install a Winegard Sensar on 71 TW Lumatic Audio, Video & TV 12 04-14-2009 07:03 PM
Rotate tires? Gen Disarray Tires 10 02-17-2006 10:15 PM
Wanted swivel chair Jimmy Smith Parts Archive 2 04-28-2005 08:38 PM
Swivel Lights nellie the elephant Electrical - Systems, Generators, Batteries & Solar 10 11-07-2003 10:55 AM
