Old 10-20-2011, 06:09 AM   #15
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I was on my iPhone and not all my post made it.
In short, I meant to say that the each have advantages.
I don't have the omni on my trailer, I have the stock batwing. I have used the at a deer cabin and it has performed pretty good as several have mentioned here.
Good luck with what ever you chose.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-20-2011, 10:26 AM   #16
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
noreen -
topshelf -
thanks to you both for the info.
question - how do you get the signal into the AS and to the tv?
do you hook the omni up via cable thru the cable hook-up on the side of the AS and simply bypass the roof input?
is there any reason why you decided not to permanently attach the omni to the roof of your AS?
thanks
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 10-20-2011, 11:09 AM   #17
Richfield , Ohio
I run the coax from the antenna to the factory cable connector on the side of the trailer. You do need to use the 12 volt amplifier that comes with the antenna. I did not install the antenna on the roof because I like the stock appearance and also did not want any additional holes in the roof. I did remove the original crank-up antenna.
AN AIRSTREAM LOOKS BEST WHEN IT HAS A BOWTIE ON THE FRONT OF IT.
Topshelf is offline   Reply With Quote
Old 10-20-2011, 01:34 PM   #18
Images: 20
thanks all for your input.
if i can't get the crank thingy working i might go ahead with one of these omni units.
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 10-21-2011, 04:45 AM   #19
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Exactly what Topshelf said, except I still have the original antenna hokked to the radio. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
winegard antenna dhe9 Roof 5 10-16-2008 06:55 AM
Winegard Antenna for FM Radio cooney Audio, Video & TV 3 10-12-2008 12:15 PM
Winegard Roadstar Antenna Pfredd Audio, Video & TV 3 08-24-2008 10:57 AM
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 08:09 PM
Which Winegard Antenna? tlavergne Audio, Video & TV 20 08-26-2007 04:09 PM
