Old 07-10-2014, 12:36 PM   #1
1980 20' Caravelle
Coeur d alene , Idaho
Winegard Rayzar or Jack OA-8000 ????
Any comments on either of these? Which would pull in the most stations? Thanks, Don
glacierrunne is offline   Reply With Quote
Old 07-10-2014, 12:46 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Where are you going to mount them? The Rayzar is a panel antenna intended for indoor use, and isn't going to do much more than old-fashioned rabbit ears. The OA-8000 is an outdoor antenna intended to fit on the mast of a Winegard Sensar. It will work better than the Rayzar but not as well as the Sensar that your trailer had from the factory.
Old 07-10-2014, 01:18 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Winegard has (at least) 2 Rayzar products now... the flexible window-mount thing you mentioned, and the "Rayzar Air" which is a flat-ish amplified outdoor antenna that mounts on a mast (or perhaps includes one).
I'm curious about your comment on the JACK antenna's performance. I've looked for reliable comparisons between them and haven't really found anything, but I haven't looked in a while. Have you seen a good comparison somewhere?
David
Old 07-10-2014, 02:24 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I have a Rayzar that I use at home in case I lose cable TV in a storm (the cable company might have a power outage even though my home doesn't lose power; it's happened before). It pulls in about 18 stations in the New Orleans metro area. Fewer than my Airstream Interstate's antenna draws in, actually; the Airstream's antenna picks up 22 stations at last count. But the Rayzar is lightweight, and lays flat so it doesn't take up much room to store it, so it makes a good backup to another antenna.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-10-2014, 02:33 PM   #5
aquinob's Avatar
Portsmouth , Virginia
I have the jack antenna that has its own rotating base mount. The original mast was long gone, so I mounted this antenna last month. Really happy with the reception, has an LED strength indicator on the base that allows you to find the strongest signal.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 07-10-2014, 04:38 PM   #6
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I have a like new Rayzar that I never use... Cheap! If anyone is interested
Cochese is offline   Reply With Quote
Old 06-22-2015, 07:49 PM   #7
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I'm going to revive this old thread to ask again... any thoughts on the Rayzar? Specifically the Rayzar Automatic shown HERE.
This product is intended to fit on the top of the RV and replace the old crank-up antenna. As the name implies, Rayzar Automatic, automatically searches for broadcast TV signals. I'm really enamored with the concept and assuming it works think it's the next best thing in broadcast antenna for an RV.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 06-22-2015, 08:44 PM   #8
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I will share about the Rayzar Air HDTV antenna retrofit kit. I have had one for about a year. I also have the directional signal wall plate that beeps and tells me signal strength. Previously my antenna was the batwing with the HDTV nose. The day I installed the Rayzar I noted several more stations. Another benefit is that it is bi-directional so rotation is 90 degrees at most making the rotation issue an easy task. It looks like a fly swatter on the roof but it works well for $50. One major reason to switch is the change in frequency of HDTV that is supposedly happening. The new ones are tuned to the new signal.
The dome type you mention is obviously new. It depends on how much it is and I wonder if it is able to do better being flat on the roof.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-23-2015, 07:13 AM   #9
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Thanks for the reply. I also noticed the Razar Air and it is affordable at $50.
I have an existing Winegard Sensar with the Batwing and it works well except for one thing. Airstream installed my Sensar on a section of the roof that has very little support. There may be a reason for this but it dramatically affects digital TV signal reception when the wind is blowing. When my Sensar is upright and the wind is blowing (even a breeze) the antenna will move as much as several inches. Imagine some flexing in the roof of the Airstream and then project the angle of that deflection up 36" to the Sensar and now the antenna moves quit a bit! I don't see a means to add any support to the base of the existing antenna. I don't want to drill holes. Maybe some external ribs applied with structural adhesive. Arggh!
How is your Winegard base attached? Are there ribs near the antenna? I'm tempted to change to the Rayzar Air but I suspect it will have the same problem with movement - maybe worse since it's a flat paddle in the breeze. Any comments?
Lucius and Danielle
Old 06-23-2015, 07:00 PM   #10
2006 25' Safari
Images: 8
The issue sounds like it would not be resolved with the Rayzar Air as it uses part of the original crank up system - one pole instead of the two for the batwing. If the antenna base is moving around then it would still do so. Mine is also in a mid section and not as sturdy but I have not noticed the movement in wind. The razar WOULD BE a paddle in the wind.
Old 06-23-2015, 08:42 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We replaced the WineGard batwing that was factory installed with the WineGard Rayzar Automatic. We had to relocate the Airstream antenna amplifier to a new location to see it's display. System sure works easier than the batwing and more stations show up.
Old 06-24-2015, 07:20 AM   #12
switz's Avatar
2014 31' Classic
Images: 8
I forgot to mention that the Rayzar automatic came with a roof plate to secure the hole in the roof from the WineGard crankup batwing antenna and a round white ceiling plate to cover where the crank was inside. Since we have a white ceiling in the Classic, one does not hardly notice the disc. For a bare aluminum ceiling, one might want to paint the disc silver.
Old 06-24-2015, 12:20 PM   #13
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Thanks for the reply switz. Based on your comments it sounds like the Rayzar Automatic works as well as, perhaps better, than the crank-up antenna.
I think the Rayzar Automatic would solve my problem with movement in the wind. The three mounting points for the Rayzar Automatic would allow me to have one or two, maybe all three mounts near a rib in the roof of the trailer. Plus the Rayzar Automatic is low profile, has a wide footprint, and therefore would be less susceptible to movement.
I noted in the installation instructions for the Rayzar Automatic that it should not be mounted on metal. I contacted Winegard and asked them about Airstreams and their recommendation was to put it on top the trailer and try it before making a permanent installation.
I'd like your feedback on the items below:
- How long have you had your Rayzar Automatic installed and approximately how many times have you used it?
- Have you been in rural areas or mostly urban areas?
- Did you mount yours directly on top of (or very close to) the old crank-up base?
- Did you attach it to the sheet metal only or were you able to attach it to ribs?
- If you are able to provide a picture of your installation that would be very helpful.
- If I mount the Rayzar Automatic directly on top of the old crank-up base it will be very close to the air conditioner unit - less than 12". Winegard says it's supposed to be to be clear of obstructions but I didn't see a dimension for how close/far it should be from said obstructions. Any comments?
Thanks.
Lucius and Danielle
Old 07-02-2015, 11:22 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Looking at this product also... our original is hurting... Let me know what you think...
I also saw mention of the 'proximity' to other roof items... that makes sense as it would be 'line of sight' with the RAYZAR... not above most items as a 'crank up' would provide. Of course on our 34' there is lots of space between the AC and where I would mount the Rayzar. In fact, mounting in the center of the roof sure seems like the best place... the antenna would be 'level' if trailer is level...
Peace and Blessings..
Channing
WBCCI# 30676
Replace batwing ant. with jack 8000 bearrand Audio, Video & TV 1 01-08-2013 07:04 PM
A&E Imperial 8000 awning help? higgy116 Awnings 5 01-18-2008 10:35 AM
Is an '04 worth $8000? kaman 2004 Safari 9 07-03-2007 09:24 AM
Twink hitting 8000 posts? CanoeStream Off Topic Forum 66 05-06-2007 07:25 PM
