Old 07-06-2015, 05:55 PM   #15
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
I found that the Winegard "Satellite" Antenna Crank Handle RK-Hand I found on Ebay works and looks a lot nicer than the handle that comes with the "TV" Antenna. Its way stronger and folds up for a clean look. It will screw on the existing set up that you have. You can not buy just this part from Winegard so Ebay is your best option... Hope this helps!!!
ID:	242358   Click image for larger version
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 07-06-2015, 07:14 PM   #16
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Any ideas why it failed? Bad casting, machining?
NavyCorpsman is offline   Reply With Quote
Old 07-06-2015, 07:49 PM   #17
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My set screw has come loose a couple of time causing the handle to drop down the shaft. Last time I put a drop of blue Loc Tite on the threads. So far so good. It seems very cheaply made and prone to easy breakage.
MICHAEL
Old 07-06-2015, 08:08 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The plastic split down the 'thread' of the handle, in line with the set screw. This is the forth one.
I 'tighten' until it makes contact with the 'shaft', then juuuuuust snug enough to hold the handle on under 'spring tension'....
I even filed a small 'groove' in the shaft so that the screw did not have to be run too tight and could still hold on under the spring tension..
Maybe I just keep getting their 'bad batches'....
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-07-2015, 05:24 AM   #19
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I second the satellite crank suggestion.... Looks like it should be in the Airstream
Old 07-16-2015, 10:22 AM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The new Hand Crank arrived, sans screw and nut. Fired note to Winegard and they are mailing replacement.
It is far beefier than the original... Thanks for the tip!
Channing
WBCCI# 30676
Old 08-13-2015, 10:15 AM   #21
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Winegard made good! In place and working great!!!!!!
Old 09-10-2015, 06:39 AM   #22
vinstream's Avatar
Im glad the new handle I suggested worked out for you!
www.VINSTREAM.com
WBCCI # 1962
Old 04-03-2016, 07:09 AM   #23
Missouri Valley , Iowa
My '02 Classic has the original Winegard TV antenna. It has some wear and is in need of replacement or repairs. Has anyone replaced the exterior gear / interior crank parts? It seems that would be easier than the whole unit since it's only the up / down mechanism that is bad. I have no leaks so hesitate to replace the entire unit.
Dan
Farmer Dan is offline   Reply With Quote
Old 04-03-2016, 07:21 AM   #24
1973 Dodge Cayo Motovator
Outbackga's Avatar
Dahlonega, GA & Maggie Valley NC , Georgia
I use my antenna for free HD digital TV. Free local news when traveling.Did I mention free?
Dave
Outbackga is offline   Reply With Quote
Old 04-03-2016, 07:59 AM   #25
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There is a note around the crank to lubricate twice per year.
Where do I lubricate?
What type of grease/oil?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-03-2016, 11:19 AM   #26
1998 30' Excella 1000
Livingston , Texas
I've bee using dry silicone spray, up top, thinking that I don't want to attract dirt/dust to that mechanism. It's been working for 15 years.
Siegmann is offline   Reply With Quote
Old 04-03-2016, 12:29 PM   #27
m.hony's Avatar
2013 30' Classic
Where do you spray the silicone?
Will it be obvious?
TAC #MS-10
Airforums #70955
Old 04-03-2016, 01:50 PM   #28
Livingston , Texas
Will it be obvious?
Your antenna is likely different from my old one. But mine actually has a label and a plastic access plug. But you could just go up there while you have someone rotate and raise and lower it. Look for where two surfaces move past one another.
Replacing the Crank-up Winegard with New Omnidirectionl Model interstateflyer Electronics & Connectivity 24 11-21-2014 04:16 PM
Bad Cable from Power Amp to Winegard Roof Antenna tntom Audio, Video & TV 3 06-24-2008 08:09 PM
Which Winegard Antenna? tlavergne Audio, Video & TV 20 08-26-2007 04:09 PM
