Old 04-25-2006, 07:26 AM   #1
1965 26' Overlander
Acworth , Georgia
Whip antenna help needed
Folks,
I am in process of renovating '65 Overlander. I have purchased a new car stereo (am/fm/cd) for use in trailer, but need help.
Is the original whip antenna any good? How do I test?
Where can I get connectors to marry old antenna with modern car stereo?
Where should I get power from?
PhilMateo is offline   Reply With Quote
Old 04-25-2006, 01:09 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Volt Ohm Meter
Might need a little bit more info here but testing a simple whip antenna is pretty simple. I'll assume you have a shielded cable with a plug on the end. You'll need a volt/ohm meter and a jumper wire.
First check to see if the innner and outer contacts are shorted by holding the tester leads on the inner and outer pin and contact on the side of the plug. Anything other than infinity ohms isn't good.The cable is most likely bad. Next check to see if you have good connection between the outer contact and the body. 0 to1 ohms is OK. Now check to see that you have continuity between the center pin and the antenna. This is were the jumper wire comes in handy as the leads are probably too short reach. 0 to 3 ohms is OK. Lastly check to see if there is continuity between the center pin and the body. Any contact is bad.
Common adapter connecters can be found at Radio Shack and Auto parts stores. As far as 12 volts is concerned I have a 12 volt circuit in the cabinet over the front couch.
Hopefully I guessed correctly on you're lead-in wire, if not post some more info.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is online now   Reply With Quote
Old 04-26-2006, 12:09 PM   #3
1965 26' Overlander
Acworth , Georgia
Thanks...do you know if there is a power line on sameside of trailer to run radio?
Old 04-27-2006, 03:48 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
Not sure on yours. Mine has the two 12 volt wires coming through the cabinet above the front window on the center right, curbside.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Old 04-27-2006, 06:00 PM   #5
...................You can purchase an an antenna from radio shack I believe . The telescoping portion is the "+" or positive part and the shield is the "-" or grounded part . It should work for both Am and FM stations . r66
route66 is offline   Reply With Quote
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
