08-17-2007, 09:03 PM
1978 28' Ambassador
Kenton
, Ohio
Which Winegard Antenna?
I am looking to replace my old antenna with a Winegard antenna. What are the recommendations for the strongest signal...the Sensar Batwing or the Roadstar Omnidirectional?
Thanks.
Tom
1978 Ambassador.
08-17-2007, 09:50 PM
Retired.
, At Large
Thanks.
Tom
1978 Ambassador.
I got a Sensar III (batwing) and am very happy with it. Sometimes, simpler is better.
08-17-2007, 10:03 PM
More than one rivet loose
Los Alamos
, New Mexico
The newer Airstreams come with the adjustable batwing. The omnidirectional as simple as it seems does not allow you adjust for maximum signal.
Pick what you want Simplicity or maximum singal.
Michelle TAC MT-0
Sarah, Snowball
08-17-2007, 10:28 PM
Retired.
, At Large
What she said...
08-18-2007, 02:50 AM
Liberator
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie
, Alabama
Holy Carp
Get a clothes hanger and some tin foil before you get the Omni.
Omni = every way you park = no signal
A Frizbee with a coax cable attached will work better.
Bats are the best
08-18-2007, 06:53 AM
1978 28' Ambassador
Kenton
, Ohio
Thanks for the input. I kind of thought that would be the case. A strong omnidirectional seems to good to be true. I have searched the forums and read everything I could find on the replacement process. It sounds straight forward except for running the coax cable. I contacted Jackson Center and they quoted me $800 - $900 dollars to do the job...I think I will do it myself.
Tom
08-18-2007, 07:00 AM
Retired.
, At Large
Tom
Our local dealer wanted $400 for the install. Now that I've got it in, I have found you can get adapters that will go from the new 75 ohm coax to the old 300 ohm flat cable, so it would be even easier.
Something I found is the batwing is longer than the old clothesline antenna, it would be a good idea to offset the mount slightly so you don't have to worry about the edge of the antenna rubbing a hole in the air conditioner shroud. Don't ask how I found this out...
08-18-2007, 10:40 AM
1978 28' Ambassador
Kenton
, Ohio
Do you loose much signal strength using the old flat 300 ohm wire instead of running coax the whole length? It also looks like the easiest way to run it would be along the roof and down the frig vent.
Tom
08-18-2007, 12:41 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
amplified bat wing is the way to go.
john
you call them ferrets, i call them weasels.
08-18-2007, 01:54 PM
1964 22' Safari
Foresthill
What are you planning to do with your old antenna?
I'm looking for a 60-70s one. The pole type with 4 arms that fold out.
I know they are worthless as an antenna...just cute
Walter
08-18-2007, 02:58 PM
1978 28' Ambassador
Kenton
, Ohio
Walter,
I might not have the time to make the switch until spring. I am in the middle of a major house remodel, which according to my wife is more important than the Airstream at the moment. But I work on the Airstream when I need a break from working on the house so I might get to it this fall yet. When I do get rid of it you are more than welcome to it.
08-18-2007, 11:15 PM
1964 22' Safari
Foresthill
Thanks, When you are done with the old one please let me know.
What a concept: working on the house instead of the toys.
Don't let that idea get around.
08-19-2007, 04:58 PM
Los Alamos
, New Mexico
Coax has much lower loss. Most Modern Televisions only have coax.
Michelle TAC MT-0
Sarah, Snowball
08-19-2007, 05:14 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Antennas
Hi Walter,
I’m not sure which one you mean. Both my ’67 Trade Wind and my ’83 Excella have the same Braund model. Also, they work great!
Link to photo:
http://www.airforums.com/photos/show...0&userid=17830
And no, the telephone pole and streetlight are not part of the antenna. They crank up poorly.
Vaughan
08-19-2007, 06:34 PM
Retired.
, At Large
Tom
It does lose strength, but is certainly easier than ripping ceiling panels out. Ours had the cable running down the main long ceiling panel, after removing the a/c and vents, it wasn't too bad to get apart. A helper is mandatory.
08-21-2007, 09:20 AM
Devils Lake
, North Dakota
What is a batwing antenna??
08-21-2007, 02:53 PM
Los Alamos
, New Mexico
Michelle TAC MT-0
Sarah, Snowball
08-26-2007, 12:42 PM
Devils Lake
, North Dakota
Thanks............... Gonna git one of dem.
08-26-2007, 03:21 PM
Liberator
1972 Argosy 24
Heart of Dixie
, Alabama
Air Waves
They still make those?
Sure looks like would pick up great.
08-26-2007, 03:25 PM
Liberator
1972 Argosy 24
Heart of Dixie
, Alabama
Bat Wing =
