Old 08-19-2007, 06:34 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by tlavergne
Do you loose much signal strength using the old flat 300 ohm wire instead of running coax the whole length? It also looks like the easiest way to run it would be along the roof and down the frig vent.
Tom
It does lose strength, but is certainly easier than ripping ceiling panels out. Ours had the cable running down the main long ceiling panel, after removing the a/c and vents, it wasn't too bad to get apart. A helper is mandatory.
Old 08-21-2007, 09:20 AM   #16
Devils Lake , North Dakota
What is a batwing antenna??
Sundance is offline   Reply With Quote
Old 08-21-2007, 02:53 PM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Replacement Elevating Crank for Winegard® Batwing Antenna - Camping World
Michelle TAC MT-0
Sarah, Snowball
Old 08-26-2007, 12:42 PM   #18
Thanks............... Gonna git one of dem.
Old 08-26-2007, 03:21 PM   #19
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Air Waves
They still make those?
Sure looks like would pick up great.
klattu is offline   Reply With Quote
Old 08-26-2007, 03:25 PM   #20
Liberator
klattu's Avatar
1972 Argosy 24
Images: 834
Bat Wing =
Old 08-26-2007, 04:09 PM   #21
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
one little matinence tip about bat wings new or old. make sure the tips of the wings do not touch the roof of your trailer when folded.
they can saw nice little slots in the aluminum in short order.
usually this is because they get bent or one or more of the little rubber feet are missing.
john
you call them ferrets, i call them weasels.
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
TV Antenna lead fdx753 Audio, Video & TV 14 04-27-2004 08:45 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
