Old 09-05-2005, 10:51 AM   #1
Ohanastar's Avatar
1964 24' Tradewind
Cardiff , California
Which TV antenna?
Hi everybody! I have a '64 Tradewind and a husband that LOVES TV! I'm looking for a replacement antenna (nothing left of ours but the exterior "holding" bar and the connector to the interior wiring.) I've searched online and in these forums, but I can't seem to locate the name of the antenna that I think I see on a few of your units. I was hoping someone might be able to tell me the product name and where you got it...? I'm not looking for the batwing style. Instead, it appears to be a straight "car-like" antenna that would mount on the front beside the window. I appreciate your help!!
Ohanastar is offline   Reply With Quote
Old 09-05-2005, 12:18 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Hmm... Ours had one of those on it when we got it. It is an OEM part, and as far as I know it is not available. It was missing parts, and didn't work, so I removed it, and if I ever put another one on our trailer, it will be a bat wing type. Here is a photo of the front of our trailer, showing the stump of the ariel:
Old 09-05-2005, 12:58 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
My Argosy had a sidemount car type antenna as you describe and the crank-up roof TV antenna. I think car type antenna had something to do with radio, though haven't tested it out. FM reception inside the trailer is just fine. Do I guess AM? I recall that the shell interferes with some frequency and it's obviously not FM. I really wonder if converting that one would give you very much for TV reception.
The crank-up roof TV antennas were a miniature version of a housetop antenna. I'd suggest doing a search on keywords: antenna, batwing. See what you find -- I know this has been dealt with in some detail.
The batwing search just might start you early on some Halloween recipes...
5 meter Langford Nahanni
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
