Old 12-18-2008, 01:46 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
What is it: Antenna and?
This was behind a PO installed blank plate next to fridge, I assume the yellow wires are for the antenna and the brown and white wire are 12 volts? Please correct me if I am wrong, I don't have 12 volts hooked up at this time to check.
If the yellow wires are for antenna how do I go about putting a plug back in.
As always your help is much appreciated.
Name:	wires behind fridge 2.jpg
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 12-18-2008, 03:45 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
You got it. The white (neg) and brown (pos) wires are 12v feeds to the old (long removed) booster for the antenna. The yellow/black wires are from the antenna and to the radio (most likely). I'd need to see a little better picture to confirm that one feed goes over to the radio.
www.nesa.org
Air No. 6427
Old 12-18-2008, 10:35 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
What amplifier?
Jim thanks for the information.
Does this picture tell you the needed information.
Where would I find the correct booster amplifier for this, the manual (Braund Super Skyliner) list the amplifier an P/N 14939 but of coarse I can't find one that old.
Winegard talks about an amplifier P/N RA-7596 but does not list it on there website, Barker Manufacturing has one listed at: TV Signal Amplifier
Would either of these work?
Anyone have an original they would like to sell?
Name:	Wires behind fridge 3.jpg
Bruce,
Old 12-18-2008, 11:32 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Bruce!
I am utilizing one of these amplified outlets for the antenna in my Minuet -- purchased it through Ace Fogdall RV in Cedar Falls, IA
Kevin D. Allen
AIR #827
Antenna help chuman70 Audio, Video & TV 7 11-19-2007 09:45 AM
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Need a better FM antenna silverback Audio, Video & TV 10 04-02-2006 06:38 AM
antenna on '61 heavyduty 1960 - 1964 Overlander 9 04-26-2005 02:11 PM
TV antenna davidz71 Audio, Video & TV 14 03-14-2003 08:14 PM
