Old 01-14-2009, 06:33 AM   #1
daisy&cowboy's Avatar
1966 24' Tradewind
orlando , Florida
we are newbies and need to hookup tv
What is the best way to do this and what about the digital conversion deal?
We have an empty 55 flying cloud.....
daisy&cowboy is offline   Reply With Quote
Old 01-14-2009, 06:38 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends of it you want modern or vintage...I have a small (19" or so) LCD that is digital ready, it will pull in stations just fine with any type of antenna. Or I can use cable or a dish. For hook up I would use coax vs the old flat wire stuff. Unless you are trying to do a 100% original restoration, in which case you need a tube TV and the flat wire.
Aaron
WBCCI #XXXX AIR #2495
Old 01-14-2009, 06:47 AM   #3
1966 24' Tradewind
orlando , Florida
modern forsure! what happens when the digital conversion happens will we get rec with the antenna? Cable? how do you get cable hookup?
Old 01-14-2009, 06:50 AM   #4
1966 24' Tradewind
orlando , Florida
Thank you for your quick response Aaron, sorry Im so excited I forgot my manners!
Old 01-14-2009, 07:08 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
As to the television situation, pick up a brand new 15" or 19" LCD flat screen that is capable of receiving a digital signal over the air. It will also work with cable or a satellite hook-up.
Brian
SuEllyn & Brian McCabe
Old 01-14-2009, 07:09 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have heard the old Skyliner antennas will work fine with digital.
My 71 had a hookup for a CB antenna. I just replaced this with a cable hookup. Otherwise you may have to pick a spot and drill a hole for a cable connecter which is riveted in to the skin.
Old 01-14-2009, 07:11 AM   #7
1966 24' Tradewind
orlando , Florida
Thank you Moose...OK so there is cable at campsites?
Old 01-14-2009, 07:14 AM   #8
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Cable is available at many campgrounds. I carry some coax and go in through the refrigerator outside door to get in the inside. Satellite is good if you are going to stay in one place for quite awhile. Do not mount the dish to the trailer. It is much better to have a movable antenna that can be positioned to look through the trees rather than having to repark your trailer when you can not get reception. Putting a batwing antenna on the trailer no longer maintains the vintage look but it works better than the clothes hanger style used on old trailers.
Old 01-14-2009, 07:30 AM   #9
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi, The tough part for me would be drilling a hole in the trailer. Is there a hole already in the skin that you can use instead of making a new one? If you use a digital conversion box you can use any TV. I used this antenna on my 67 and still haven't decided on what to do with the 60.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-14-2009, 07:55 AM   #10
cameront120's Avatar
1972 25' Tradewind
I run a television cable through the hole where the gas line enters my trailer at the water heater. I then run the cable behind the cabinets and twin bed to where my LCD TV is mounted. I figured, why drill an extra hole in my trailer?
North Vancouver, BC
Old 01-14-2009, 08:48 AM   #11
1972 25' Tradewind
Another option is to run the television cable up through the screened vent hole in the floor, behind your fridge. You can then run the cable behind the cabinetry to wherever you want it. I din't do this because I wanted the cable to come out of the trailer on the street side, which is where my water heater is.
North Vancouver, BC
Sewer hookup-what to get LI Pets Waste Systems, Tanks & Totes 64 12-31-2006 10:32 PM
Ipod Hookup Devoman Audio, Video & TV 22 11-13-2006 01:41 PM
Dual Battery hookup sectionc Electrical - Systems, Generators, Batteries & Solar 9 02-11-2006 01:41 PM
brake hookup jugluss Brakes & Brake Controllers 1 01-25-2004 01:20 PM
Is this the city water hookup? Stefrobrts 1966-68 Caravel 7 05-06-2003 10:13 AM
