Old 04-20-2004, 03:11 PM   #1
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Question Want to remove antenna.
We would like to remove the tv antenna from our Argosy. I recall seeing a post someone had done with pics about removing the antenna and a pic of the aluminum patch.. could anyone direct me to that thread.. I have searched and searched and cannot find it.. Thanks Annie
Happycampers is offline   Reply With Quote
Old 04-20-2004, 03:46 PM   #2
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Hi Annie-
Try Greg - "Gsymes" you know - the gentleman the Antenna is slated for. He can probably give you a step by step on how to remove it as he has removed his. You may even get some photos too.
The other one I think the pictures were from that poor fellow "Campcollector" who had a tree fall on his new 04 Bambi?
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 04-20-2004, 05:21 PM   #3
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Hello Annie1976!
I removed the Antenna on my 1980 Excella II and put a patch plate over the hole. I believe you may be talking about me. Here is the thread.
I used Vulkem Sealant and 3/16 pop rivets. I did not use enough rivets and also I did not use the right kind so it leaked again. I put vulkem over the madrel hole of each rivet and then used heavy aluminum tape over that. Learn from my mistakes and use olympic rivets and shave them so they shed water, and space them close like on the windows OR use big pop rivets, cover the hole with vulkem and aluminum tape over that as i finally did, it will be on the roof so no one will see it anyway.
-Jason
jjonesnc is offline   Reply With Quote
Old 04-20-2004, 05:27 PM   #4
jjonesnc's Avatar
Images: 8
old mounting plate and new plate, antenna hole in roof and, the plate installed.
Old 04-20-2004, 05:31 PM   #5
jjonesnc's Avatar
Images: 8
sorry the pics didnt load..........they are in my main thread listed above
-Jason
Old 04-20-2004, 06:42 PM   #6
1979 30' Argosy
Unhappy Thread does not load
Jason ..yes you were the one .. thanks for the info.. the thread will not display... Thanks Annie
Old 04-20-2004, 06:50 PM   #7
jjonesnc's Avatar
Images: 8
hmm lets try this again..........
http://www.airforums.com/forum...ead.php?t=9840
Interior restoration forum/repairing or replacing the floor/floor cancer documentary.
-Jason
Old 04-20-2004, 07:00 PM   #8
1979 30' Argosy
Thumbs up Thanks Jason..
I found it after I posted.. Annie
Antenna JLD Electrical - Systems, Generators, Batteries & Solar 13 08-31-2006 08:41 PM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Antenna Drive Gear CO_Don Audio, Video & TV 0 02-06-2003 04:45 PM
