Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 02-15-2009, 10:18 AM   #1
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Wall or Ceiling Mount for LCD TV
I have a 22' CCD that I'm looking at possibly mounting an LCD TV. I've seen the factory installed model mounted on the wardrobe bulkhead over the galley counter, but that's not for me. I'd prefer to mount the TV in the back, over the under-utilized desk, so it will be close to the antenna and 12 VDC plug (See attached photos - red lines denote possible mounting points. I hope to use an inverter while Boondocking.
I'd like to mount the swing-arm bracket on the interior wall or ceiling at a structural rib, instead of the bathroom bulkhead.
Has anyone tried this type of mount?
Would it require special mounting hardware and would it be sturdy enough to support about 25#?
Thanks!
Name:	Copy of TV Mount Position 1.jpg
ID:	75511   Click image for larger version
Name:	Copy of TV Mount Position 2.jpg
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 02-15-2009, 08:07 PM   #2
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
I have a 26" flat screen lcd with a stand that I put on the top of my base cabinet next to the antenna hook up. When I travel I just unhook everything and put the tv back in the box which I put on the floor between our recliners, and it stays safe during relocation.
It fits perfectly! and no worrys if a wall mount would hold it
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 02-16-2009, 05:09 AM   #3
rseagle's Avatar
Images: 33
We currently carry a portable Toshiba 9" AC/DC color TV/DVD combo (MD9DL1). We have to set up and unhook it every time we travel and we stow it under the desk. If we could mount a swing arm with a flat panel LCD TV with a built-in DVD, it would be much easier to set up, and a 19-22" screen is better than a 9".
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 02-16-2009, 02:31 PM   #4
red
red_wheeler
red's Avatar
1972 31' Sovereign
1975 31' Sovereign
1990 34' Excella
Vidalia , Georgia
Polished Aluminum Post
We welded up a polished Aluminum post that is bolted to the top cabinet and to the base cabinet and also riveted it to the wall in our Excella. This made for a very strong support. Then we modified and bolted a standard Wal Mart flat screen mount to the support post.
A Sanyo 19 inch flat screen TV was then put on the mount. This setup allows the TV to be swiveled to whatever position we want, including swiveling around to face the dinette table.
In the bedroom a standard wall mount was used to mount another 19 inch Sanyo TV to the wall between the bathroom and the bedroom. The bolts go through the back of the medicine cabinet for wall support.
A Sony Directv receiver feeds the system
red is offline   Reply With Quote
Old 02-16-2009, 02:53 PM   #5
rseagle's Avatar
Images: 33
That's a nice set up! I don't think I have to counter/cabinet arrangement to replicate it.
I'm wondering if the swing-arm is connected directly to the structural rib, as shown in the conceptual photo, it might support a 19-22" LCD .
Name:	TV Mount Position 1 with Peerless.jpg
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 02-16-2009, 04:33 PM   #6
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I am very interested in finding out if you can do this( mount a tv to the wall or ceiling. I would guess that you couls ask someone like Inland RV they would know Good Luck
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-22-2009, 10:08 PM   #7
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
I would like to mount a small LCD TV in the front bedroom & there's a cable and power source. However no mount or holes for a set up.
The wall abutts the shower so I am not sure how you are suppose to
mount it to that wall? There does not look like any space to get in there and work.
Any suggestions or thoughts?
Thanks in advance.
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 03-22-2009, 10:27 PM   #8
Westfalia's Avatar
Some Place with a German Name , Texas
Images: 35
Send a message via AIM to Westfalia
The wall on the back of the shower is pretty securely fastened but can be removed pretty easily. There is just enough clearance on the back of that wall for fastener clearance without hitting the shower pan.
Westfalia is offline   Reply With Quote
Old 03-23-2009, 02:34 AM   #9
rseagle's Avatar
Images: 33
Here's my solution. I am supporting a 32" LCD TV w/ DVD.
Name:	32 Insignia LCD DVD 11.jpg
ID:	77300   Click image for larger version
Name:	32 Insignia LCD DVD 2.jpg
Name:	32 Insignia LCD DVD 3.jpg
ID:	77302   Click image for larger version
Name:	32 Insignia LCD DVD 6.jpg
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 03-23-2009, 08:33 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Nice job R.S. Eagle
IMHO this is much better than using a rib to support the TV. I would be very concerned that the vibration and weight of towing with a TV attached to the rib would eventually warp it. I've seen them build these things and the ribs aren't all that hefty.
When I had my 22 I did use the little desk a lot... but then you all don't put on makeup do you? I had my laptop rigged to be a TV, but had I wanted a bigger screen, I probably would have chosen to simply put it ON the desk, then pack it away when traveling. I'd have probably wanted a book or two to raise it a bit.
Paula
Old 03-23-2009, 05:42 PM   #11
rseagle's Avatar
Images: 33
Thanks Paula! This set up is as solid as a rock. No doubt I made the right decision to stay away from the aluminum. We can even use the desk now for something besides holding our old portable 9" TV. I hope to add an A/V FM transmitter to send the audio to my stereo system for "Surround Sound".
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 03-24-2009, 06:22 AM   #12
Denis4x4's Avatar
Durango , Colorado
Check out the photos in this thread on how I mounted a flat screen on the wall next to the shower enclosure
http://www.airforums.com/forums/f450...-fb-43062.html
Denis4x4 is offline   Reply With Quote
Old 03-24-2009, 09:09 AM   #13
BradS's Avatar
1957 26' Overlander
Images: 14
Great solution Bob. That is one serious TV. I like it
I am currently working on turning my desk are into a wardrobe. If it works out than I will remove my existing wardrobe and go to a queen bed.
You do nice work
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-24-2009, 02:21 PM   #14
rseagle's Avatar
Images: 33
Wow! That sounds like a serious MOD. Will you have to raise the mattress to access the water heater?
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
Old 03-24-2009, 04:43 PM   #15
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Paula makes a good point about using up desk space ... some of us only wish we had a desk (most guys ain't gonna' talk about whether we put on makeup!!!) - but it'd sure be nice for a fly tying bench rather than the folding dinette table. Maybe someday.
AirsDream is offline   Reply With Quote
Old 03-24-2009, 05:31 PM   #16
BradS's Avatar
1957 26' Overlander
Images: 14
Wow! That sounds like a serious MOD. Will you have to raise the mattress to access the water heater?[/quote]
Thats what it looks like. I only access it twice a year as it is.
WBCCI 10289
TAC MN-69
AIR 11240
Old 03-25-2009, 12:30 AM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
No Mount.
Hi, like most of the previous posters stated, I store mine in an overhead storage compartment and set it up on my Credenza. [not mounted] Before and after pictures showing television locations. The picture on the left shows my TV sitting on the original Credenza; And the picture on the right shows my TV sitting on my new Credenza. [as per remodel]
Name:	My Picture CD 429 (Large).jpg
ID:	77417   Click image for larger version
Name:	IMG_0338 (Large).JPG
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Wall mount with strap for lcd tv rochar3 Audio, Video & TV 7 03-16-2009 02:07 AM
LCD wall mount bracket bargain pricing Excella3287 Audio, Video & TV 7 04-26-2008 05:52 PM
Mount LCD TV dcbollinger Audio, Video & TV 4 07-11-2006 04:49 PM
LCD TV Mount tandemfish Argosy Motorhomes 4 01-20-2006 06:33 AM
LCD TV Mount cosmotini Audio, Video & TV 6 05-10-2005 12:30 PM
