I bought a wall mount off from e-bay. It will allow me to hang my TV, and Pull it out and turn it different ways. The mount that screws into the wall ways a couple of pounds and has two screws. The flat screen TV I have is 19lbs. I will be hanging it on the wall next to the refrigerator over my credenza. I have a 1973 Overlander. I was going to take a square piece of wood to attach the wall mount to so all the weight would not be distributed in one area. My question is can the wall handle around 21 lbs of wall mount and TV? When I am driving I will have velcor holding the TV very tight against the wall so it does not move.
We have a 22" flat panel hanging on that very wall in our Sovereign. If you want more stbility, you could go between the fridge and wall, and add another 1/4" piece where you will be hanging the tv mount.
Did you have to pull the fridge out to add the piece of plywood, or how did you get that behind the paneling. I have a 74 and much the same problem.
also where did you stash the DVD player and Satellite receiver?
Sarge
__________________ 74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
Sarge
I didn't put the piece of plywood in, it works fine without it. Our tv is an LG 22L30 tv, one the same size has ridden in that location since we got the trailer with no problems.
How big of screws did you use? It looks like the refrigerator butts up against the wall?
SIU Bound
Brian
I used 3 #10 (1/4") wood screws that came with the mount. It may not look it, but there is an inch and a half clearance between the wall and the side of the fridge. The wall itself is 1/4" thick, so you don't really need long screws.
An alternative I didn't pursue is removing the bulkhead wall, mounting the additional piece of plywood to the bulkhead wall, and reinstalling it. I've had the wall out several times, it's not really hard, just involved.
Here are a few photos. I need to cut a slot in the credenza top for all the cables to drop down through to eliminate the cluttered appearance of all the wires:
I used a piece of Mahogany that I had lying around and cut it to fit the partition between the twin bed and kitchen.
This allowed me to mount my knife holder on the kitchen side.
Here is the bedroom side. I fastened the mahogany from this side using 4 stainless steel screws and decorative washers. I then Used 2" machine bolts through the mount and all layers of wood.
It may not be the most attractive setup, but I put it together with materials that I had on hand.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529 http://northvancouvermodern.blogspot.com/ Live! Life's a banquet and most poor suckers are starving to death! - Mame Dennis
I am not going to use the screws that came with the wall mount. They are really long. They look like they are supposed to be anchored into a stud in your house. Thanks for the info. I like the idea of taking the TV down when traveling.
Yeah, the screws that come with the mounts are essentially lag bolts and are intended to be driven into a stud.
Kai & Samm
North Vancouver, BC
Canada
SIU Bound
Brian
I cut the screws off to about half-length. I sxrewed the screws ibto the wall, then unscrewed them and cut them off. Then reinsyalled the newly shortened screws.
I'm upgrading to a swivel mount this weekend, if anybody wants picture...
Yeah Terry, I'd like to see pictures of your installation this weekend.
