Old 07-15-2008, 06:16 PM   #15
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
This is great information. For safety sake, should the refrigerator be removed to perform this installation. On my unit, I am wondering 1) how much room is between the inner wall and the refrigerator and 2) the exterior wall over the credenza appears to be just paneling with a limited area to screw the bracket to the wall - so a board between the paneling appears necessary. Thanks for your comments.
willyd is offline   Reply With Quote
Old 07-15-2008, 06:47 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Here are the pictures. The fridge was not removed, although if it were already out, you could put another panel behind the mount to make it more rigid.
ID:	63706   Click image for larger version
ID:	63708   Click image for larger version
ID:	63710   Click image for larger version
ID:	63712   Click image for larger version
Old 07-27-2008, 06:48 PM   #17
willyd's Avatar
1993 34' Limited
Terry, thanks for the good information. Bill
Old 07-27-2008, 08:45 PM   #18
Lothlorian's Avatar
Loganville , Georgia
I have my wall mount connected to my flat screen. I used the rabbit ears because I am still trying to find the sattelite. I did not connect directly to the wall. I took a piece of 1" X 6" and connected it to the mount. I felt I would get a better mount that way.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 01-16-2010, 07:48 PM   #19
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
You know Terry I was thinking as I read these post on the TV installations. What about taking some of the expandable screws and drill holes all the way through. This way it would give some added reinforcement from the back side. Or maybe some certs on the wall screwed through a piece of back up board cut to the size of the mount. Any way just some thoughts.
Tom C.
Okiegent is offline   Reply With Quote
Old 01-24-2010, 06:00 PM   #20
Chasmorgan's Avatar
1999 23' Safari
How has your installation held up? It's been few months now. Would you recommend it again or suggest something else? Thanks for you help!!1
Chasmorgan is offline   Reply With Quote
Old 01-24-2010, 07:39 PM   #21
Lothlorian's Avatar
My installation has been great. I hid all the wires and got rid of the antenna. I do take the TV off the mount when we are traveling on the road. It is very easy because it slides in and out.
Brian
Brian & Adrienne
Old 01-24-2010, 08:51 PM   #22
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Looks like the same mount I used
I mounted it (22" Vizio) to the wall panel directly. Was concerned about the weight but it holds up fine. Holes drilled through the panel with a small nuts on the back side. I take it down for travel so it doesn't swing out.
Mounted the stereo/dvd player in the overhead bin above the TV where there is power. Antenna runs down the back side along the fridge vent and out the door of the panel.
TV swings out to face the bedroom as well.
RichHog is offline   Reply With Quote
Old 02-04-2010, 07:34 PM   #23
Mackhopp's Avatar
2005 28' International CCD
Ottawa , Ontario
I'll soon be mounting a couple 23" Samsungs onto swivel mounts - one in the 'living room', mounted on the front wall of the bathroom, the other in the bedroom, mounted on the back wall of the bathroom.
I have to admit being a bit apprehensive about the weight, but it seems that others have mounted much larger TVs than 23" (I think I remember a 32"? wow...). We're going to install a support plate of sorts on both of the bathroom walls - but what I'm mainly concerned with now is esthetics in the bathroom.
Hubby suggested plywood and painting it white which just gives me the blahs. Maybe a piece of aluminum? But that wouldn't be as strong as plywood, is that correct?
Maybe I'll hang a few lightweight picture frames in the bathroom to hide the necessary but ugly support block. I already have a towel ring in there, so I don't need another one...
[SIZE=1]Michelle & family
[COLOR=Blue] 2005 28' International CCD
Mackhopp is offline   Reply With Quote
Old 02-04-2010, 08:35 PM   #24
Central , Mississippi
On the Edge
On my '77...
Instead of mounting in the center of the wall and using the arm to collapse on itself during folding, I mounted it into the edged of the wall and actually let the lag screws go into part of the refridg' frame. An Ape could swing on the arm with out it moving! The side benefit, the television could swing all the way around the edge of the fridge, point rearward and be seen in the bedroom.
Sorry, no photos...the trailer now has new home...
I stold Terry's photo and did a markup to show where I mounted mine...
Name:	My mount.jpg
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-04-2010, 09:06 PM   #25
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I mounted a 15" LCD TV on an extendable swivel mount four years ago and it's held up great during travels.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-05-2010, 05:21 AM   #26
Mackhopp's Avatar
Ottawa , Ontario
Originally Posted by HiHoAgRV View Post
On my '77...
Hmmm. I don't have ready access to my A/S to see what I could 'jimmy' up. We almost got stuck in the snow yesterday going out to the barn where it's overwintering to get some measurements... At any rate, I'm guessing I could mount the bedroom TV in the same sort of fashion - right on the corner. But I'm not sure about the other TV. I seem to remember that the CCD wall on the 28' behind the dinette is curved where it transitions to the hallway. In that case I'd have to do a regular mount and bolster it on the other side with something - if I don't then I'd always be slightly nervous on bumpier roads that the mount or wall would fail.
If you've ever driven your Airstream to Mont Tremblant in Quebec from Ottawa, you'd know what I was talking about.
Old 02-05-2010, 07:26 AM   #27
Originally Posted by Macfrodge View Post
... I'd always be slightly nervous on bumpier roads that the mount or wall would fail....
I also added a bunge cord to hold the television up and against the wall. A hole in the interior skin under the valence was one attachment point, the refridge frame was the other.
20,000 miles and no problems!
Since I'm a photo thief on this thead...how about another one...stolen and marked up
Name:	TV Mount 2.jpg
Old 02-05-2010, 07:32 AM   #28
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
LOL, no worries! You did such a good job with the photoshop, it's looks real.
1958 Overlander
4CU 1st VP
New Flat Screen TV Bracket Airhog1 Commercial Listings 36 02-20-2013 05:45 AM
flat screen tv Judy Barde Audio, Video & TV 18 10-11-2010 09:06 AM
Wall mount with strap for lcd tv rochar3 Audio, Video & TV 7 03-16-2009 02:07 AM
Flat Screen Television Circuit JmesDean Electrical - Systems, Generators, Batteries & Solar 4 07-08-2004 11:58 AM
Thoughts on flat screen tv yukionna Off Topic Forum 15 09-16-2003 08:40 AM
