Old 01-29-2019, 09:34 AM   #1
2015 19' International
olympia , Washington
Voyager Wireless Camera Power Source?
I need some advice on a power source.
I have a 19' 2015 International Serenity and decided to purchase and install a Voyager wireless backup camera. I read several threads on how to wire the camera to the rear center clearance light for a power source and decided to do just that.
Yesterday I finally got a chance to hook up my tow rig and try it out. After several attempts I could not get the monitor and camera to pair. I decided to check the wiring connection to the camera and it was intact. The camera power requirement was reviewed (12 volts) and voltage to the rear clearance checked and found to only be 5.34 volts, which is sufficient for my trailer's led lights but not the camera.
I now need a 12 volt source that can be routed to the existing camera mount (including 3/4" hole for camera wiring plug).
Any suggestions would be welcome.
aero52 is offline   Reply With Quote
Old 01-29-2019, 09:56 AM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
5.34v to the clearance light does not make sense, it should be 12v at least.
thewarden is online now   Reply With Quote
Old 01-29-2019, 11:53 AM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Call the dealer. Call the Mother Ship. The reason to use that wiring is to get to the 12 volt lighting buss. Either the 19 is odd, which is unlikely or something is not wired correctly. Our 2015 23 has a Voyager wired to that clearance light for the power source.
Now, I did not do the install, so maybe I'll ask. Saturday is the AS Dealer's customer maintenance seminar. Sounds like a good side discussion. Pat
Installing Voyager Wireless Backup Camera 25Twin Audio, Video & TV 21 07-08-2019 03:28 PM
Running Power to Voyager Rear-view camera garybair Audio, Video & TV 55 08-01-2018 07:54 PM
Voyager Rear Backup Wireless Camera System WVOS511 moosetags Airstream Classifieds 0 04-13-2018 02:31 PM
Voyager Wireless Backup Camera dmilem General Repair Forum 2 10-17-2017 06:16 AM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 07:32 PM
