Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 01-27-2008, 06:46 PM   #1
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Voila! Strange noises from stereo fixed!
This thread references: http://www.airforums.com/forums/f450...reo-36282.html.
After much fruitless discussion and trying a number of solutions, here is a success.
Strange noises are gone from the stereo and subwoofer on my 2007 Safari.
Some noises went away after I installed two noise filters on the power for the subwoofer and stereo (such as pump noise),
but the best result was a ground loop isolator on the subwoofer input.
No noise, even at very low volume.
My dealer mechanic recommended that, and even sent me one gratis.
You can get them at Radio Shack, about $20.
Seems grounding is not the Airstream's strong suite, even though it is
100% aluminium .
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 01-27-2008, 07:00 PM   #2
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
That's great news! I'll pick one up and give it a try. It will probably be April before I get to install it.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 01-27-2008, 07:01 PM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
That's great news Hank. Don't suppose you can post any pictures of location and access and product, can you? I am on a par with using giant color coded fold-out posters with graphics to plug in my electronics.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 01-27-2008, 07:56 PM   #4
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I though about doing that but I was waiting until after the warrenty expires. I was hoping to put a filter on the converter output to stop it all.
$20? I am sure we can get them chaeper at an electronics supplier.
Michelle TAC MT-0
Sarah, Snowball
Old 01-28-2008, 06:11 PM   #5
hshovic's Avatar
Bozeman , Montana
Images: 20
The install was easy (but then everything is unless you don't know how...
I plugged it into the stereo output that goes to the subwoofer (on mine, it's labeled "subwoofer mono" and is an rca jack connection. I then stuffed it back in there with all the other spaghetti, and screwed down the lid. No power necessary. I taped off the other input, because I did not use stereo.
However, it turned from 45 deg. to blowing snow and -4 today so I will take some pictures, but it won't be soon (ran out of propane to keep my fingees warm).
I don't think the converter does this subwoofer noise. It's a ground loop within the stereo output...
Hank
Old 01-28-2008, 06:52 PM   #6
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
hshovic,
Found this little magical device...
RadioShack.com - Car: Accessories: Car A/V accessories: Ground Loop Isolator
Boy if this works.. I owe you a beer or two!
Airstream should buy you an Airstream full of beer for solving THEIR problem! Could even offer you a high paying job in their electrical department!
Can't wait to try this out in the spring!
campadk is offline   Reply With Quote
Old 02-04-2008, 06:14 PM   #7
1999 30' Excella 1000
rio rancho , New Mexico
Thumbs up noise
thanks for the info. i'll buy two. i kinda feel bad ,as i just sent back my airstream survey. most of the survey was about the stereo/dvd. how a company like airstream could not test this system ,is not possible. my dealer got great reviews but he also was at a loss to fix the stereo. he showed me other owners letters of complaint about new system. if this works i am sure he will send you a medal.
airmac is offline   Reply With Quote
Old 02-07-2008, 11:01 AM   #8
edleeseng's Avatar
1972 Argosy 20
1976 28' Argosy 28
Indianapolis , Indiana
I've used isolation transformers (ground loop eliminators) on television remote trucks and pa systems for years. They have often been a lifesaver! One thing to note is that if you are using them for the part of your system which produces the mid or high frequencies, you may notice a very slight reduction in high frequency clarity. It's usually very slight and well worth getting rid of hum. For the sub, you shouldn't notice anything. By the way, they also make them for video. If you're looking for a less expensive audio unit, do a Google search for ScoscheES-034.
edleeseng is offline   Reply With Quote
Strange noises from the stereo? hshovic Audio, Video & TV 60 07-12-2009 08:45 PM
speaking of tranny noises... Chuck Tow Vehicles 12 05-02-2007 11:24 AM
Here is Something Quite Strange dmreilly10000 General Motorhome Topics 19 12-16-2006 01:56 PM
Not trying to be noises ,But Angel73 Insurance & Claims 0 05-28-2006 11:21 PM
