Old 03-25-2008, 05:44 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Wire Location From 1972 Manual
According to the manual the wire colors are: (CS is curbside/RS is roadside)
- CS rear is orange/black
- RS rear is gray/black
- CS front is red/black
- RS front is blue/black
Speaker distance from Station O (the first forward rib in the trailer structure) and the height from the floor in inches (xxx/xx)
25 Foot - TWIN
Rear R/S = 162/50
Rear C/S = 162/50
25 Foot - DOUBLE
Rear R/S = 154/65
Rear C/S = 174/50
29 Foot TWIN
Rear R/S = 184/50
Rear C/S = 184/50
29 Foot DOUBLE
Rear R/S = 139/60
Rear C/S = 208/50
Hope this helps you.
Old 03-25-2008, 07:42 PM   #16
1969 29' Ambassador
orange Park , Florida
Thanks Terry
Thanks Jim, Ididn't realize you wern't online when I PMed you and after I posted I e-mailed you.
Thanks Gary
All my wires are grey and may have a stripe one one of the pair for polarity reasons. They may have changed to color coding a year or two later. I will do the measuring and then try to peel the inner skin back some before i do any cutting just to see how far off the 72 vs the 69 are. Being it looks to be positioned aft of the window above bed I may not have too much trouble peeling the skin back some.I will definitely let everyone know what I find.
Thanks again to all your help
John
69AmbassFl is offline   Reply With Quote
Old 03-25-2008, 11:03 PM   #17
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
thanks guys, I'll tried running the tape measure back and that measurement for the twin comes to the middle of the goucho window (the 72 had the fridge on the curbside that year instead of the street side). I'm thinking of trying to remove the nearby electrical outlet box and look behind it, I just know how dang short those wires are and what a pain in the but it is to get them on and off the outlet.
goransons is offline   Reply With Quote
Old 03-26-2008, 08:52 AM   #18
1969 29' Ambassador
Goransons,
E-mail tech at AS. They told me on mine that the wires were 16 inches in front of wardrobe 50 inches off floor. I'm still investigating this before I do any drilling. Don't know if I will have time before I go out of town this weekend, but after I get back its on to find the wires. If I remember tonight I will measure where the wires turn to go down wall to see if it is approx the 16 inches they say. I tried the outlet box the other night and found nothing there,may have moved around in 39 years though.
Old 03-26-2008, 04:11 PM   #19
goransons's Avatar
1963 22' Safari
can you pm the email address to use?
thanks!
Old 03-27-2008, 01:07 PM   #20
goransons's Avatar
1963 22' Safari
Contacted AS tech and they gave me the following info:
We show that on the 1969 25’ T the curbside rear speaker wire can be found in the wall, 14" forward of bed window lever, 50" above floor. I hope this helps.
Tech
14" forward of the window arm is about 6" away from the outlet there, and at the same height (to center). I just killed the breaker and removed the 4 screws holding the outlet box to the inner skin, and used a long screwdriver to push the insulation out of the way, and sure enough, set of speaker wires taped to the outside skin with the same type of masking tape they taped the AC wires up with. Next just need to find a set of speakers and we're golden.
thanks for the lead on the Tech email, and thanks to everyone who helped out.
Look forward John to hearing that you've found yours as well once you get back in town.
Old 04-01-2008, 08:34 PM   #21
goransons's Avatar
1963 22' Safari
here it is
for future reference for anyone...
Speaker grill will get a coat of white I think, wife thinks it sticks out too much visually.
Name:	IMG_1714 (Small).JPG
Speaker Location Zeppelinium Audio, Video & TV 10 09-22-2012 11:57 PM
Speaker Switch & Speaker Replacement vswingfield Audio, Video & TV 17 10-01-2011 05:48 PM
69 tradewind speaker wires goransons Audio, Video & TV 0 10-24-2007 05:38 PM
New speaker placement TomW General Interior Topics 13 04-22-2005 05:44 PM
New speaker wiring wyhjr Electrical - Systems, Generators, Batteries & Solar 0 10-28-2004 05:53 PM
