Old 03-09-2010, 12:04 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Video back up camera
I want to install a back up camera in the rear of may stream to use backing but also when traveling.
The camera I have is a Peak. The manufacturer does not recommend it be left on but used intermitantly. I want to rig a switch in my truck to turn the camera on and off.
The camera is usually used in the same vehicle as the monitor and rigged to the back up lights. The camera is connected to a transmitter which sends a wireless signal to the monitor which will be on my truck dash. I have a factory extension cord so I can have the tranmitter in the front of the trailer and the camera in the rear. The manufacturer says this arrangement should work. The On/off switch I am proposing would send 12v power to the transmitter.
Suggestions?
Old 03-09-2010, 12:59 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Does your stream currently have back-up lights? If not, then you could use the back-up/aux pin in the 7-way connector as your 12 volt switched line. If you do have back-up lights already, then an option would be to go to a 9-way connector between the trailer and the tv.
Chris
Old 07-24-2010, 07:01 AM   #3
2010 25' FB International CCD
Leesburg , Virginia
I'm doing something similar. I have a TRENDnet SecurView wireless internet surveillance camera, model TV-IP110W, mounted to the inside ledge of the rear window with Velcro. It is plugged in to the inverter circuit below the dinette. Whenever the inverter is switched on, the camera comes on. I have a Linksys wireless router on the sofa midway along the trailer. It, too, is plugged into the inverter circuit and comes on whenever the inverter is switched on. The router is set up as a local net with security on. I have my iPod Touch in the cab of the TV plugged in to a charger and on all the time. It is connected via the Linksys wifi to the camera and displays a continuous picture outside the rear of the trailer. It is full-color and real-time. The image is a bit jerky, but is effective for backing up and for monitoring traffic behind me.
The last thing I do when we leave a campsite is to turn on the inverter, which then automatically activates the camera and router. Presto! Rear-view camera and no wiring between trailer and TV.
2010 25' International Serenity
2010 Toyota Sequoia
WBCCI 2515, TAC VA-9
Leesburg, VA
ChrisRiddick is offline   Reply With Quote
Old 07-24-2010, 07:10 AM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Chris- I like your idea. Do you know if there is a 12v camera and router to avoid using the inverter?
Old 07-24-2010, 01:47 PM   #5
Tinsel Loaf's Avatar
Check out my posts on cameras. One for the hitch and one in the back window of the AIRSTREAM.
Tinsel Loaf is offline   Reply With Quote
Old 07-24-2010, 05:23 PM   #6
Leesburg , Virginia
The Linksys actually has its own transformer delivering 5V DC. Just need a converter from 12V to 5V. The Linksys transformer delivers 12V DC @ 500mA. That should be doable from the battery circuit, too.
Great idea - eliminate the inverter completely. I'll have to test that out.
2010 Toyota Sequoia
Leesburg, VA
Old 07-24-2010, 05:39 PM   #7
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
My new 2011 F350 will be here soon and it has a back-up camera built in to the rear view mirror. The camera lens is mounted in the rear tailgate which is removable. Than means to me, that there is a connector between the tailgate and the chassis wiring harness. Has anyone investigated buying another lens and extension cable that would plug in to the existing harness? That way I could mount the lens on the AS and connect to the chassis harness.
hhendrix is offline   Reply With Quote
back-up camera anyone? richard lane Audio, Video & TV 19 11-06-2008 06:25 AM
Rear View Video Trailer Camera Mount Location chaimemet Towing, Tow Vehicles & Hitches 10 02-07-2008 08:15 PM
back up camera nursematt 2006 - 2010 Classic (all lengths) 7 04-18-2007 09:20 PM
Back up camera Will Ackerman Electrical - Systems, Generators, Batteries & Solar 27 01-03-2005 07:40 PM
Back-up camera dbyar General Motorhome Topics 1 04-06-2003 10:54 AM
