Old 08-21-2007, 04:30 PM   #1
Wayward's Avatar
Cary , North Carolina
USB Input available with Audio/Video Upgrade package
Looking to feed internet radio from my laptop into the Safari's sound system, I read posts where folks added a Sony XA-300 (has USB input) to their Sony CD player, gaining additional audio inputs. For those of you with Airstream's Audio/Video upgrade package, you probably have an XA-300 already.
I found the XA-300 buried behind the access panel to the Sony headunit. For some reason, Airstream decided to not bring out the USB jack. I plugged a standard USB cable into the XA-300 and ran it out the same hole as the CD changer cable. My laptop immediately recognized it as "USB Speakers" and all I had to do is select the source on the headunit as CDC4=USB.
btw, if you've not listened to Pandora, it is worth a look. You create you own "radio stations". By asking you to seed the station with a song or artist, Pandora helps you figure out what type music you like and then keeps streaming great songs.
Pandora Radio - Listen to Free Internet Radio, Find New Music
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-02-2010, 09:34 AM   #2
Wayward's Avatar
selecting USB Speakers as Windows output sound device
It seems that when using a Windows laptop to play audio into the Sony via USB, the audio device should be selected before starting up the audio application. e.g. when using a browser to play Pandora, I select USB Speakers first, then start Firefox browser.
I found a simple application that makes switching audio output devices easier in Windows and sits in the system tray.
Quick Sound Switch
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 08-02-2010, 10:06 AM   #3
Ag&Au's Avatar
Port Orchard , Washington
Thanks For the information, I will have to mess around with that and see what I can do with it.
Regards,
Ken
Old 04-27-2013, 07:57 PM   #4
2007 31' Classic
Leavenworth , Kansas
Adding a Bluray Player?
Hello, Thanks for your post on this adapter to add other input into the stereo. I have a 2007 31' classic with the same stereo setup you described. I've considered removing the CD changer in favor of the USB line in for MP3 player and possibly a bluray player in the place where the changer currently sits. I was thinking that if I added it in that cabinet, I could plug the audio directly into the stereo-- but routing the HDMI cable to the TV might be a chore. I'm curious if anyone had tried adding a bluray player into this stereo system in this way.
Any suggestions out there?
Steve
sandtwalker is offline   Reply With Quote
Old 04-30-2013, 05:39 PM   #5
Dyoung59's Avatar
1979 25' Tradewind
New Bern , North Carolina
Can you use a regular tv or do I have to purchase a 12 volt tv for my 79Trade wind.
Dyoung59 is offline   Reply With Quote
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Photos on the Portal Page. WE NEED YOUR INPUT! Vote please! Andy R Our Community 6 10-25-2002 08:55 AM
