Old 06-30-2016, 12:49 AM   #421
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Garmin RV 760 B-20
Hi, This morning I revamped my backup camera. With my sensor mounted inside of my left tail light housing, the signal was just too weak. I moved the sensor to my home made generator inlet and ran my camera wire through the conduit to the rear of my trailer. I wound up the extra wire and left it in my bumper storage compartment. I re-routed the camera wires down and to my generator outlet. Since there is no easy access to a running light wire, I added a two wire connector and I will just plug my backup camera into my Battery Tender lead. I now get a good signal.
ID:	265556   Click image for larger version
ID:	265558   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-30-2016, 11:44 PM   #422
2015 16' Sport
Portland , Oregon
I ended up with the Costco wired. Welded a little bracket for the wire and ran it underneath. Click image for larger version
Name:	ImageUploadedByAirstream Forums1467348257.142875.jpg
leedav is offline   Reply With Quote
Old 07-02-2016, 08:45 AM   #423
W4NT3D's Avatar
2016 27' Flying Cloud
Saint Robert , Missouri
I'm going to use my GoPro camera. It looks like it will work just fine. Will use the inverter plug under dinette table to power while driving. I will view camera from iPad in cab of TV. Click image for larger version
Name:	ImageUploadedByAirstream Forums1467467069.022433.jpg
ID:	265744Click image for larger version
Name:	ImageUploadedByAirstream Forums1467467087.535950.jpg
ID:	265745Click image for larger version
Name:	ImageUploadedByAirstream Forums1467467100.171341.jpg
ID:	265746Click image for larger version
Name:	ImageUploadedByAirstream Forums1467467111.755745.jpg
W4NT3D is offline   Reply With Quote
Old 07-14-2016, 12:46 AM   #424
Salem , Oregon
Images: 18
Hi, in the past few days I have painted the coupler ball area bright yellow so it can be seen better than the gray. I also was able to pull my trailer forward so I could adjust the back-up camera alignment lines. I re -adjusted the alignment lines because I lowered my camera's angle.
ID:	266758   Click image for larger version
ID:	266760   Click image for larger version
ID:	266762   Click image for larger version
2005 Safari 25-B
Old 07-14-2016, 09:06 AM   #425
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Robert,
Great minds think alike. I put a traffic cone out as a target too and put down a length of pvc pipe as guide. Still wish the resolution was better.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 07-14-2016, 02:05 PM   #426
teagues's Avatar
2008 20' Safari SE
Charlotte , North Carolina
Really great idea. Any paint suggestions?
teagues is offline   Reply With Quote
Old 07-14-2016, 02:24 PM   #427
teagues's Avatar
2008 20' Safari SE
Last month, a couple of pages back, I kicked out the idea of using an old, deactivated cell phone as a rear camera and another as a monitor. I ultimately decided to use both old phones as cameras. Mounted each inside the rear window, with one facing straight back (for rear-view while driving) and the other pointing as far down as I could (for backing, if needed). For the monitor, I used my current phone mounted to the dash, where I could select either or both cameras as desired.
Just back from a 5,000 round mile trip to Montana using the new "system". WOW! I cannot believe how much more fun it is to drive when you can see behind you.
Not bringing this up because I would necessarily recommend doing what I did -- you'd need to be a bit of a tinkerer, have an old phone laying around, and be willing to deal with some potential bugginess -- but it does now seem clear that we should all have some sort of rear view system.
Old 07-14-2016, 02:48 PM   #428
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Originally Posted by teagues View Post
...it does now seem clear that we should all have some sort of rear view system.
Based on our own experience, we completely agree. 😊
Rocinante is our 2014 International Signature 27FB
Old 07-14-2016, 06:19 PM   #429
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
Hey W4NT3D
I like the idea of using a GoPro and viewing with the iPad, which I use for navigation. Seem to remember that GoPro told me the image would not always be in real time. How is your experience with this set up?
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 07-14-2016, 07:16 PM   #430
dougandlori's Avatar
2004 28' Classic
Fresno , California
I installed the Garmin BC30 on my 28. The reviews were so so but I am happy with the result. I bought the extension and ran the wire inside and mounted the transmitter on the front of the propane cover. It is wired to the running light and while not high definition suits my needs for backing and checking while passing other vehicles.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 07-14-2016, 11:39 PM   #431
Salem , Oregon
Images: 18
Hi, this is what I used.
Rust-Oleum
Painter's Touch
2 X
Ultra Cover
Paint + Primer
Gloss / Sun Yellow
2005 Safari 25-B
Old 07-17-2016, 07:50 PM   #432
W4NT3D's Avatar
Originally Posted by wildwoodrver View Post
Hey W4NT3D
Wildwoodrver,
i was very pleased, I used it this weekend. I suction cupped my GoPro to the table instead of hanging from overhead storage. I plugged it in the inverter outlet under the dining table. I used a iPad mini to wifi to camera. I noticed some lag(less than a sec) at times and other times it would freeze up, but not that often. This setup works for me, I like it.
Oh, by the way, just remember the camera is facing backwards, don't freak out when it looks like there passing you on the right at 70+ mph, like me.
Old 07-17-2016, 10:25 PM   #433
Salem , Oregon
Images: 18
Hi, well today after some thought, I modified my camera bracket and mounted it in the middle of my trailer. I don't know why I didn't think of this in the first place. No holes, just two sided tape.
ID:	267114   Click image for larger version
2005 Safari 25-B
Old 07-20-2016, 11:58 AM   #434
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I had a Voyager system installed by dealer on our Airstream before we picked it up - top video. Then I recently was sent a new "not yet released" model from the manufacturer that I reviewed - bottom video. Both work great. I use the stock reverse camera on my 2013 Ford F150 Raptor to hitch up. Been very happy with the Voyager and have had no video connection issues at all in the year we have been using.
AStreamNerds is offline   Reply With Quote
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 05:11 PM
B190 back up camera install Corgifan Sprinter and B-van Forum 3 08-07-2011 04:16 PM
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 03:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 07:40 PM
