04-09-2016, 06:56 PM
#381
2016 25' Flying Cloud
Jupiter
Originally Posted by Teton Stream
Received the Esicam on Monday and checked it out today. 1. It is a magnet in the base which anchors it quite firmly (upside down) on a small steel pad a mounted under the cabinet (camera is pointed out the rear window of a 20' Bambi). Ran down some fairly rough roads and the camera remained in place. 2. The signal I received in my RAM 1500 Quad Cab was with a flaw. Software allowed for me to flip the picture, take stills, and record. The signal delay was unnoticeable for me.
For the price it seems to be a very economical and easily installed solution.
I think you meant "without a flaw". How did you power the camera? Thanks.
04-10-2016, 05:43 PM
#382
TetonStreamer
2021 27' Flying Cloud
Delaplane
, Virginia
I did mean without a flaw, thank you.
The camera held power for 5.1 hours on its internal battery. (They say 7 hours in the manual but there is not a monitor.) The plan is to recharge it with 110V plug by sink, or detach and charge with 12V plug by TV.
Teton Streamer - in The Toaster
Wilson, WY 83014
04-10-2016, 06:00 PM
#383
2014 25' Flying Cloud
Cuddebackville
, New York
Hey Teton- we'll be in your neck of the woods in September when my wife is in The One Fly
2019 Ford Expedition Platinum
04-10-2016, 07:30 PM
#384
Central
, Mississippi
We will be there in early June!
04-10-2016, 07:36 PM
#385
Jupiter
I appreciate you answering these questions. Do you think the 100 degree view angle is sufficient? Are you using it with an iPhone or Android phone?
Thanks.
04-11-2016, 08:09 AM
#386
TetonStreamer
Delaplane
, Virginia
That is great, I think we will be in town. Let me know your location as we get closer to the date!
Wilson, WY 83014
04-11-2016, 08:13 AM
#387
TetonStreamer
Delaplane
, Virginia
The wide angle appears to be quite sufficient for me. The screen causes a very slight "haze" in viewing, but it is acceptable. I am using an iPhone 5S.
Wilson, WY 83014
04-26-2016, 10:03 PM
#388
1964 26' Overlander
Milton
, ON
Another option, if you have a teenager handy...
05-03-2016, 11:59 AM
#389
2022 Atlas
Homosassa
Chevrolet has come out with a camera package for Silverados. It has a rote camera that can be mounted on the trailer. Has anyone seen this setup in on a vehicle?
05-04-2016, 05:11 AM
#390
2013 30' Classic
Greenwood
, Mississippi
A guy here in the campground has a camera system that resembles the Voyager but with a much larger display screen/monitor.
Can't remember the brand-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
05-04-2016, 07:36 AM
#391
2015 30' Classic
Sherwood
, Oregon
The Ford Super Duty 2017's is said to have five cameras with the fifth dedicated as a WiFi rear view for trailer mount. I'm hoping there will be a way to add it to the 2016 without having to replace the entire Nav/screen unit.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
05-13-2016, 10:34 AM
#392
2014 30' FB FC Bunk
Hoover
, Alabama
I got a go-pro recently with wifi - plan on trying this out - had a small delay - but if going slow doable - unit is a "hero plus LCD" - 200 bucks - did not buy it for this use at all as primary purpose but I'll give a review as such for this purpose here later
05-13-2016, 10:58 AM
#393
2009 30' Classic
Melbourne, FL
, Searsport, ME
Don't forget that your smartphone has excellent quality HD imaging when used in combination with a high quality camera. Image latency doesn't have to be a problem.
05-13-2016, 11:24 AM
#394
Biloxi
, Mississippi
Just spent the last couple of hours messing with my Garmin camera. Jury rigged some power and got it working. Backwards picture is going to take some time getting used too. Problem I am having is deciding where to mount it, get power and still get the transmitter as close as possible to the front of the trailer. Really do not want to drill any holes if I do not have too. Thinking the license plate light might be a good place to tap power. It would be nice if Airstream could of left a little slack in the wiring. Not much to work with as it is.
MICHAEL
05-13-2016, 11:36 AM
#395
2013 30' Classic
Greenwood
, Mississippi
I had an upside down picture.
The only solution I could come up with was to disassemble the camera and turn it over.
TAC #MS-10
Airforums #70955
05-13-2016, 11:47 AM
#396
2015 28' Flying Cloud
Waxahachie
From what I understand while discussing this option with the dealer when ordering my 2017 F250, it's a wired camera at this point. Comes with the camera in a pkg from Ford with I think 60' of wire to run and tap in to truck. Sends feed to built in monitor. Apparently there is a lot of discussion to try to get a wireless module, but all talk at this time.
Chuck
05-13-2016, 12:04 PM
#397
2007 30' Classic S/O
Somewhere
, South Carolina
AWCHIEF,
I recently completed a Garmin bc30 install in my '07. Don't have time to get into details right now but if you'd like my install experience let me know i'll detail later.
Gary
05-14-2016, 06:27 AM
#398
Biloxi
, Mississippi
Originally Posted by GCinSC2
AWCHIEF,
Gary
Yes, please
MICHAEL
05-30-2016, 05:05 PM
#399
2015 30' Classic
Calgary
, Alberta
Has anyone been able to compare the quality/resolution of the 5" wireless Voyager to the 7" wireless Voyager? I've used the 5" version on my FC but always hoped it had better resolution. On my new trailer I would consider a 7" if it's better quality or if there's another benefit other than display size. Thx
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
05-30-2016, 08:59 PM
#400
2014 30' FB FC Bunk
Hoover
, Alabama
An update - I tried hitching with my GoPro hero plus model - mounted on the propride hitch using a simple zip tie mount (removable zip ties)
It worked great - small delay so you take your time and it worked great no problem.
I have almost nothing to compare this to.
