Old 05-10-2014, 01:08 PM   #197
2014 28' Flying Cloud
Springfield , Illinois
Originally Posted by rodsterinfl View Post
The Voyager wireless works well.
I just ordered a voyager camera. I'm intrigued with the light fixture, did you make that or can you order from dealer/ factory?
SchuHouse is offline   Reply With Quote
Old 07-04-2014, 05:31 PM   #198
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
SchuHouse is offline Report Post
Sorry it took me 2 months to answer. I made it. it was a simple process of taking a new light fixture, drilling a hole and having a correctly sized rubber grommet to fit in the hole THEN feeding the wiring through to the power. Everything fit like a glove. The rest was cutting and soldering and attaching as a replacement for the original. I cringed at drilling into the trailer to mount the camera but it works and serves the purpose.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-05-2014, 06:37 PM   #199
2006 30' Classic
Milton , Florida
Voyager Report
Originally Posted by nickmeloy View Post
I will report back at the end of our 7,500 mile trip on such items as rain effects, headlight effects, etc.
We have been on the road for about 10 weeks and around 8,500 miles. Overall, I am satisfied with the Voyager wireless camera setup.
We have not driven at night, so I cannot comment on the effect of headlight glare on the picture.
The few times that it rained while we were driving, there was some degradation of the quality of the picture. It was still usable, but just not as clear as when not raining. I attribute this to the dirty mist that gets on the camera lens. When it dries, the image improves. Wiping the lens face, after the rain stops, restores the image to its original quality.
The camera and the receiver connect every time.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 08-05-2014, 12:12 PM   #200
DarrellT's Avatar
Longview , Texas
I often thought it would be beneficial to have a wrap around camera system (for security reasons) mounted discreetly around the perimeter of the AS with a monitor inside so I could check on 'bumps in the night' without going outside.
Sound like with an additional monitor in the AS this would be easy!?
D
DarrellT is offline   Reply With Quote
Old 08-05-2014, 06:55 PM   #201
millertimeUS's Avatar
1976 25' Tradewind
Originally Posted by acstokes View Post
A friend and I are almost ready to market a wireless rear view camera system that uses your iPhone as a monitor. It can be had with either a weatherproof external IR camera (for viewing in dark backup situations) or a less expensive camera for mounting inside the AS rear window. iPhone reception is excellent up to about 50'. The iPhone will still receive messages and calls as usual and can be quickly removed from the window/dash mounting bracket when needed.
Just thought I'd give a heads up to those of you who may be interested. Will be much less expensive and at least equal in quality to systems that use a dedicated monitor (e.g. Voyager).
Ever thought of opening up for initial buyers on Kickstarter?
Matt
millertimeUS is offline   Reply With Quote
Old 08-05-2014, 07:04 PM   #202
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
This is a ridiculously bad question - but can you run the Voyager's wireless receiver screen (on 12v cigarette lighter adapter) from a 12v receptacle inside the trailer while also on shore power?
There could be times when having the camera and audio on inside the trailer could be a helpful thing.
If this is a wicked stoopid question - be gentle :-)
SteveSueMac is online now   Reply With Quote
Old 08-05-2014, 09:21 PM   #203
Living Riveted
2014 19' Flying Cloud
Carnegie , Pennsylvania
Has anyone tried using a GoPro camera and the smartphone app that lets you view what the camera is seeing? I have a GoPro so I'm going to try it out. If it works, you might as well get a GoPro because you can do so much more with it than a backup camera.
Arnoldjeff is offline   Reply With Quote
Old 08-06-2014, 04:20 AM   #204
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a Rydeen wireless camera with a transmitter mounted behind the headboard powered by the license plate light. The receiver is mounted in the truck behind the stereo in the dash.
I discovered the other day after I had put my Reflectix in the windows that I get "no signal".
I had to remove the Reflectix from the front window.
Also, I can't pile the pillows up on the bed.
I went with this installation so I wouldn't have to drill mounting holes in the aluminum.
The Voyager is a less finicky installation because the transmitter is mounted up high on the exterior of the trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-06-2014, 10:17 AM   #205
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I am waiting for a product that is wireless - I can flexibly mount it where I want as needed and use iPhone as the monitor
I thought about make shifting a mount for my wife's phone and face timing and trying it that way
I like the go pro idea - has people used an iPhone video feature on that? Sounds cool - would love to have one - very spendy device but if for backup and other use - that would be neat
PharmGeek is offline   Reply With Quote
Old 08-06-2014, 10:25 AM   #206
Durango , Colorado
Have you seen this website before. It is a wireless system that works over wifi to your iPhone/ipad. Range looks to be around 100+ feet and it is listed at $125. Plus it has enhanced night vision. I haven't tried it yet but it looks great.
iPhone Android iPad WIFI car backup camera
RVDreamer is offline   Reply With Quote
Old 08-06-2014, 10:58 AM   #207
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Very very interesting
Eliminating wires and using wifi instead will be awesome I bet
I want two of these now - one for the TV and one for the AS
I'm foggy on how to get the power over to the unit - but probably is simple enough
I may call that company today and ask some questions
Old 08-06-2014, 11:10 AM   #208
Durango , Colorado
I was thinking that you would probably have to install the wifi module up near the propane tanks and hook the power directly to the battery bank.
Then a wire would have to be run under the trailer back to the license bracket for the camera.
Seems like it wouldn't be too big of deal. The advantage would be better reception in TV. While you would still have to contend with some wiring. You would be wireless to the iPhone or iPad head module and be able to place anywhere in the TV.
A second camera or third camera might be nice to mount on the right and left sides of the trailer for views along the side as well as from behind.
Old 08-06-2014, 12:02 PM   #209
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Updates on Wireless back-up cameras?
Go pro is tempting as well - no install - can move from TV to TT as needed for backing and hitching - but more than double price
Old 08-06-2014, 12:53 PM   #210
Durango , Colorado
The only concern I have with GoPro is how the live camera performs. This camera is primarily designed to record video and photos to MicroSD card. I know there is a fast preview mode but I wonder what the lag time is. If the lag time is 1 sec or more that would be too much to use as a live camera for backup.
Also seems like you would be constantly charging batteries since the battery life is about 1.5 hours.
I just found this on another site about the GoPro live video delay.
"It seems to vary from 2 to 4 seconds going by reports on this forum and elsewhere.On my phone the delay was about 2 seconds.
The preview is not a full time video stream but short bursts of video."
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
B190 back up camera install Corgifan Sprinter and B-van Forum 3 08-07-2011 03:16 PM
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 02:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 06:40 PM
