11-25-2014, 04:17 PM
#261
2015 25' International
Scottsdale
Originally Posted by Wayne&Sam
I mounted it to the bottom of the cabinet, so it looks out the rear window. I pulled power off of one of the reading lamps.
This sounds like a good solution and you don't drill into the skin. Does the camera interfere with the mini blinds on the rear window?
11-25-2014, 06:40 PM
#262
2009 30' Classic
Melbourne, FL
, Searsport, ME
As the seller of the particular camera system being discussed I'd like to assist in answering any questions.
Regarding the above question: The camera does not interfere with either the mini-blind or curtains inside the rear window. Both are able to be fully opened or closed at will. The camera comes with an adjustable mount and is easily attached with wood screws underneath the rear cabinet in a manner that is aesthetically pleasing.
A question was raised regarding what components are used, i.e. camera and router. The camera is a Sharx SCNC3408 IR (infrared), weatherproof, hi-resolution (1280p x 720p), color, hi-speed (30 frames/second) communicating wirelessly to a NETGEAR N-300 router positioned in the AS front cabinet. The camera transmits to the router and the router to the iPhone 5 or 6 in the TV cab. Both the camera and router operate on 12 volt DC and draw about 1 amp each. Many, if not most, AS's have a 12v cigarette lighter style socket in the front cabinet for the router to plug into. It's likely your rear window doesn't have such an OEM-installed 12 volt socket so that needs to be installed by the purchaser or an RV dealer. It's a fairly simple DIY job.
I will be glad to answer any other questions regarding our rear view camera system. Feel free to pm me if you like.
Thanks everybody,
11-26-2014, 08:27 AM
#263
2020 Classic 33
Box Elder
, South Dakota
Wayne which app on the app store and any chance of photos on how you have the camera and router installed.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŲVPN
11-26-2014, 08:39 AM
#264
2008 25' Classic
Full Time
My Classic 25fb has a 12v cigarette socket in the dinette overhead cabinet where the radio is located. Could the Netgear router be installed there and still provide a good signal to the tow vehicle.
Can an iPad Air or Air2 be used instead of an iPhone? I only have the iPhone 4 right now. I'll probably upgrade to an iPhone 6 next year but I plan to get an iPad Air/Cellular model sooner. There are suction mounts available for iPads.
Kelvin
11-26-2014, 08:50 AM
#265
2009 30' Classic
Melbourne, FL
, Searsport, ME
I'm not Wayne, but I have pictures of the camera and router installed.
11-26-2014, 08:57 AM
#266
2009 30' Classic
Melbourne, FL
, Searsport, ME
My Classic 25fb has a 12v cigarette socket in the cabinet where the radio is located. Could the Netgear router be installed there and still provide a good signal to the tow vehicle.
Yes. That's where the router should be located.
An iPad Air2 should work. I'll be testing one in a few days and will let you know when I'm certain it works well. IMO, an iPhone is a more ideal size as it doesn't take much space, is easy to mount, and doesn't block your view as much.
11-26-2014, 09:12 AM
#267
2008 25' Classic
Full Time
What is the diameter of the mounting pad of the camera. My 25fb has a light mounted under the dinette. There may be space behind the light to mount the camera. Not sure the wife is going to like the aesthetics of the camera hanging down.
Also any vibration or camera shake noticed?
Kelvin
11-26-2014, 09:17 AM
#268
2009 30' Classic
Melbourne, FL
, Searsport, ME
Kelvin,
The mount base is 2-1/4" diameter and it comes in two sections so it may be made either 3" or 6" in length. 6" is normally needed to clear the top of the mini-blinds. It is very sturdy and the camera does not come loose when traveling. No shaking whatsoever.
#269
2020 Classic 33
Box Elder
, South Dakota
Thanks Fred. This may have been asked but any issues mounting inside? Read something about the IR doesn't work well through the glass but if the camera is at all close to the low light sensitivity of one like the Voyager I'm not sure that the IR would make any difference?
Gary
NŲVPN
11-26-2014, 09:29 AM
#270
2009 30' Classic
Melbourne, FL
, Searsport, ME
Gary,
The camera is 100% weatherproof and designed for outside security use. However, most folks mount the camera inside as it's easier even though you forfeit night vision (IR) capability. Infrared light does not penetrate glass so the only way to enable night vision is for the camera to be mounted outside. This involves drilling a 1/2" hole to run power from under the aluminum skin to the camera. Splicing to the middle rear clearance light power wire is usually what's done.
Please don't construe the above to mean the camera won't work at night. It still lets you see car headlights and streetlights same as with a real rear view mirror.
11-26-2014, 09:35 AM
#271
2008 25' Classic
Full Time
When you splice into the clearance light then you have to have your headlights turned on full time?
Does the camera draw power all the time when mounted inside and connected to 12v? Just thinking about battery drain when not hooked up.
Kelvin
11-26-2014, 09:49 AM
#272
2009 30' Classic
Melbourne, FL
, Searsport, ME
Kelvin,
Yes, if mounted using a clearance light for power you'll need to have your headlights on while driving. If this is a concern, power can be drawn from an interior 12v source.
The camera and router can be unplugged when not in use. They each draw less than 1 amp so depleting your trailer batteries is not an issue. They are only in use while you're traveling and the TV is supplying more power than they are using.
As an aside, I have one of these cameras in my home basement for security purposes and it hasn't been turned off in 2+ years. Same with my home router. I'm able to monitor whether someone should attempt to break in through the basement door. If so, I get an alarm and video to both my iPhone and PC.
11-26-2014, 11:06 AM
#273
2008 25' Classic
Full Time
Is the phone mount provided or is this and additional item that needs to be purchased?
In your top photo the camera is mounted behind the valance onto the bottom of the cabinet? The wire go off to one side. Do they reenter through the bottom of the cabinet behind the valance to access the light 12v wires?
Kelvin
11-26-2014, 11:31 AM
#274
2009 30' Classic
Melbourne, FL
, Searsport, ME
Kelvin,
This is the rear window mount provided with the camera system. There's a different one provided for exterior mounting:
Amazon.com: Panavise 845-246W Deluxe Micro Mount (Cream): Car Electronics
The camera power wire runs along the underside of the cabinet in the channel between the valance and shade to the top of the cabinet on the left so it's hidden from view. There, a 12 cigarette lighter type socket is installed. An 18-22 gauge wire runs inside that cabinet to the 12 volt light fixture. All the wires are out of sight.
The camera power wire could be run and connected directly to another 12 volt source if your trailer cabinetry or wiring differs.
11-26-2014, 12:02 PM
#275
2013 30' Classic
Greenwood
, Mississippi
Kelvin
Yes, you do have to have your headlights on all the time- or at least parking lights-
My camera gets power from the license plate light.
My truck's headlights turn off with 2 clicks of the key fob whenever we get out at a rest area. If you click the key fob once, the headlights will go off in a few seconds.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
11-26-2014, 04:19 PM
#276
2014 25' Flying Cloud
Cuddebackville
, New York
In my installation I just ran the camera wire inside the cabinet then into the cavity to splice into the reading light. The camera power wire has a plug on it to disconnect when boondocking.
2019 Ford Expedition Platinum
11-27-2014, 04:45 PM
#277
2015 23' International
Lake Forest Park
Fred Stokes,
Your camera system looks very interesting. I am wondering about the front placement of the Netgear router. It might be cool to power that from running lights to avoid power draw when boondocking - and avoid necessity to unplug or turn it off. Could it be mounted low, under the dinette bench? (I am assuming, perhaps wrongly, that running lights wire is routed there?).
Charlie
11-27-2014, 05:05 PM
#278
Scottsdale
Originally Posted by lcurrie
My system isn't exactly the same but I have my camera mounted inside the back window. I screwed the mount into the top of the frame. It's positioned to be centered at the back of the Airstream. I was able to run my cable down the window frame and into the storage compartment in the back.
I would say that the biggest drawback is that the window causes a glare on the camera when driving in the dark. I think if I ever change the location, I'll try to mount it near the license plate to see if that works. My very last choice would be to mount it up high on the back outside, putting holes in the skin.
In my setup, I really only need my camera to cover a limited area behind me. While it's nice to have a full, clear view, for me it isn't worth putting holes in the skin since a lot of the same areas are covered by my mirrors.
Lynn
Lynn,
what system do you have?
11-27-2014, 05:11 PM
#279
2009 30' Classic
Melbourne, FL
, Searsport, ME
Charlie,
You only use the camera system while traveling. The router and camera are easily unplugged when boondocking so no current is required. The router and camera combined only draw 2 amps. Your TV will supply more than enough to power them both while traveling plus a few extra amps to charge your battery.
The router is usually placed inside a front cabinet out of view and has no problem transmitting to your iPhone through the cabinet and aluminum shell.
Here's a picture of my router placement:
11-27-2014, 05:25 PM
#280
Lake Forest Park
Originally Posted by acstokes
Charlie,
Understood. I am just thinking if I put the router under the front bench it would be out of the way, not taking up normal storage spce, and I would not need to remeber to unplug it. The issue is would wireless transmission to iPhone or iPad in TV still work satisfactorily. Seem like it is worth a try.
Charlie
