Old 03-20-2014, 10:20 PM   #155
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Hey, do they offer a repeater like he one available with my TPMS? That really seems to have done the trick.
Rocinante is our 2014 International Signature 27FB
Old 03-21-2014, 08:06 AM   #156
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Never thought about that- I wonder if Rydeen makes such a thing.
Does the repeater have to be located near the front of the trailer and be wired into another source of power? I'm sure it does.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-21-2014, 08:42 AM   #157
pdvasquez's Avatar
2007 25' Safari SS SE
Hico , Texas
New Model SwiftHitch
Originally Posted by lsbrodsky View Post
Swift Hitch is coming out soon with a digital version that will eliminate interference from Bluetooth and such. I understand it will retail for $279, same packaging as their SH02 model. I think it will become the "go to" magnetic mount backup camera.
Larry
I had ordered the older model SwiftHitch with dual cameras late last year from Pickup Specialties in Houston in anticipation of our "Long Long Honeymoon" when Luci and I tied the knot in NM and then participated in the AlumaFiesta in Tucson for the honeymoon in February. I had numerous problems with the dual camera set ranging from low charge life, to spotty reception.
When we returned, I took the chance of returning the unit directly to SwiftHitch with a list of issues. Not only did they return my money in full, but they sent me their new model for me to try and return if we don't like it!!
We don't have a road trip planned, but when we do we will be sure to report back.
You really have to love the customer service of both these companies!
Happy Trails,
Philip & Luci
Lazy Dude Ranch
Hico Texas
pdvasquez is offline   Reply With Quote
Old 03-21-2014, 09:44 AM   #158
m.hony's Avatar
2013 30' Classic
Except for the intermittent loss of signal I like the system I have above a portable system in so many ways.
I need to do research to see if there is a solution like a repeater to solve the issue.
It is a permanent system wired into the trailer's power- no batteries- no charging-
It is permanently mounted- nothing to do- nothing to keep up with- just get in the truck and flip a selector switch- this is so there is only one permanently monitor for several cameras/video sources-
A permanently mounted do everything system is the way to go.
TAC #MS-10
Airforums #70955
Old 03-21-2014, 05:33 PM   #159
rodsterinfl's Avatar
2006 25' Safari
Fort Myers , Florida
Images: 8
Updates on Wireless back-up cameras?
I purchased two of the systems shared here. While I am glad that others have had good service with the 4ucam I did not. Basically it worked for one trip before failing the first time. I had all three parts fail- the transmitter was first, then the camera, then the monitor. They replaced all three but the last time they would not replace the monitor. Oh, and the transmitter/license plate camera quit working too about six months old. (I continued to use the monitor looking through the blue inky looking dead spots until it completely failed). In essence, I would not recommend the system. I know that others are happy with it but I found every piece to be not worth the money. I purchased the extension kit for the 4Ucam and wired it through the trunk and interior wall of the airstream to a transmitter mounted inside the front window. For the short time it worked, the system was adequate. The extension and wiring to the camera was made of very thin wire. I would get lines through othe picture from time to time even with the transmitter at the front top of the trailer window and the monitor on my f150 dash. I chose the system to save money and was willing to live with the lines but not total failure. I threw the whole thing in the garbage except for the wire that is still running through the wallyager of the AS.
The wireless voyager system is expensive in comparison but for that I got a much more heavy duty camera with quad cabling and rubber wire covering. The system required no wiring to the camera other than a power wire that I chose to put in the center running light. I mounted mine up high. Theft would be possible but it would not be done without a ladder and a bit of time. The system has crystal clear picture and sound with no intermittent loss.
I have a swift hitch system for hitching. The signal type is similar to the 4UCam but stronger. The voyager system is digitally locked.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-21-2014, 08:34 PM   #160
Rivet Slave
Rocinante's Avatar
We're having generally good results with Voyageur as well. The signal from high up on the back of the trailer is strong and consistent, though the frame rate is a little lower than I would like. I wish I didn't need yet another monitor in the cab to see the video feed, but it definitely works.
Old 03-22-2014, 07:13 AM   #161
m.hony's Avatar
2013 30' Classic
After testing my system in the real world I am very displeased.
The constant intermittent loss of signal deems the system useless.
Huge fail.
Extreme waste of time and money.
Back to square one.
I basically wasted my time and money on something that I could honestly live without.
Wishing I could go back to Monday and just not do anything and keep my money.
Yes, it was a good idea. I just didn't get the results I was looking for.
My vote is for no rear view camera system on the trailer.
I lived without it all those years. I could continue to live without.
The frame rate is terrible when it does work. The picture is jittery and not as clear as the wired camera on the truck.
A co-worker told me the picture is clearer than the image on a Ford factory back-up camera system. That doesn't matter to me. I want a picture as clear as the truck camera.
Feeling disappointed.
TAC #MS-10
Airforums #70955
Old 03-22-2014, 07:53 AM   #162
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have the new SwiftHitch digital and it is great for backing the trailer, with the suction mount on the rear bumper lid. It is not a solution for driving down the road because of battery life, mounting method and screen size.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-22-2014, 09:27 AM   #163
m.hony's Avatar
2013 30' Classic
I bought what I bought to overcome the obstacles of battery life, mounting method, and a second monitor in the truck.
TAC #MS-10
Airforums #70955
Old 03-22-2014, 09:31 AM   #164
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
MH, if you're not happy take it back to the dealer, and have them switch it out for something that works as advertised!! (I'm assuming the dealer provided you with the equipment.)
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 03-22-2014, 11:30 AM   #165
m.hony's Avatar
2013 30' Classic
Nope.
Car stereo store.
I will be going back after a call or visit to let them know how disappointed I am.
I just wish I hadn't done it. I lived just fine without it. It is really just a novelty. It doesn't really make anything safer or easier.
Right now we are camping.
TAC #MS-10
Airforums #70955
Old 03-22-2014, 02:48 PM   #166
Bend , Oregon
Larry
What's the specific model number of the Swift Hitch digital you have?
chaeha is offline   Reply With Quote
Old 03-23-2014, 09:36 AM   #167
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
4cu camera
iPhone Android iPad WIFI car backup camera
has anyone tried this system that uses iPad/Iphone for monitor.
looks too good to be true. and an affordable price and can be powered thru a cigarette lighter, i suppose, inside the trailer...
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 03-23-2014, 12:51 PM   #168
Central , Mississippi
I tried an app that uses Bluetooth between my iPad and iPhone. It has a horrible delay and ended up being useless.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 05:11 PM
B190 back up camera install Corgifan Sprinter and B-van Forum 3 08-07-2011 04:16 PM
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 03:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 07:40 PM
