Old 03-10-2014, 02:01 PM   #127
kdinnar's Avatar
2017 27' Flying Cloud
2014 25' FB Flying Cloud
2013 23' FB Flying Cloud
Boothbay Harbor , Maine
Cris,
Thanks for the details on how you set up your Voyager system. I had a question about your camera mounting. First, I may be dumb,(please don't ask my wife) but what are "Gorilla Rivets".
Second, so you did drill a separate hole through the skin for the camera wire? ...and how did you make it all water tight?
Thanks for your detailed instructions.
Ken
Joyce and Ken
2017 Flying Cloud 27FB
2017 Ram 2500 Limited
kdinnar is online now   Reply With Quote
Old 03-10-2014, 02:40 PM   #128
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Originally Posted by m.hony View Post
I already have it on the truck.
I am getting another mounted on the trailer.
Thanks. Looking forward to your experiences with this, so we can RAD (rip off and duplicate)
andreasduess is offline   Reply With Quote
Old 03-10-2014, 03:36 PM   #129
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Gee! Thanks!
I really think it is gonna be awesome and y'all will like it.
The one on the truck has been on there for a year.
Rydeen makes OEM style cameras for pickups (like the blue oval with a camera in it), as well as other types of mounts and monitors.
I have a local car stereo store that when I think up something cool they make it happen.
I didn't want to drill holes in my skin, or have exposed wiring, or have a visible antenna- this system will address all these issues- basically I haven't been pleased with any options I've seen, and $800 for the Voyager is just too much in my opinion.
I hope this will blow all other options away.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 03-13-2014, 05:58 PM   #130
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
This morning I took several pictures of my Voyager Camera installation at the request of a Forums member. I emailed them directly to him. He has suggested that some others may also be interested.
Here is the series of photos. Keep in mind that my Voyager was already on New Lucy when bought her. Lucy's original owner designed and installed this mounting system. It's pretty slick in that it allows for easy mounting and removal of the camera unit. This is a real plus from a security standpoint.
Brian
ID:	207367   Click image for larger version
ID:	207369   Click image for larger version
ID:	207371   Click image for larger version
ID:	207373   Click image for larger version
SuEllyn & Brian McCabe
Old 03-14-2014, 05:31 PM   #131
jspafford's Avatar
San Diego , California
Rear view camera - another approach
I found that the best advice for designing a rear view camera system came from our esteemed AS guru dznf0g who started this thread. I purchased a system from this site:
GPS Backup Camera, Wireless Backup Camera RV truck, Pan & Tilt handheld monitor, Pan & Tilt IP Network Camera, Dancing Daisy baby monitor, usb wireless video camera
http://www.airforums.com/forums/imag...attach/jpg.gif
I chose to install the camera on the rear center marker light. Mounting it high gives a better look down the road and keeps the camera out of direct headlight glare. It uses the power from the light wires, so I turn the camera on by turning on the running lights. Your AS looks best cruising down the road with those lights on, anyway. I pulled off the lens and mounting base and stripped the wires.
I used the light base as a template to make an aluminum mount for the camera bracket. I used 1/8" aluminum sheet and cut it with a jigsaw. I mounted it on the vise to shape the curve with some gentle hammer persuasion.
http://www.airforums.com/forums/atta...1&d=1394832216
Then I lined up the camera bracket and drilled mounting holes in the new base.
I used the light's gasket under the new base to seal the connection to the trailer with some caulk. I made the connections with crimp connectors, and pushed them into the hole.
I learned the hard way - despite dznf0g's warning - that you have to seal the power connection on the back of the camera housing with caulk. My first camera soon had condensation inside and I had to replace it. 4ucam was reasonable and offered a new camera at half price with a two year warranty.
After installation it looks pretty natural up there, I think. This shows the camera with the provided stubby antenna. I later replaced that with an extended antenna.
I removed the old roof mount crank-up television antenna - never used it - and mounted an extended 2 meter antenna to the bracket with zip ties and attached the antenna cable to the camera. The antenna extends the range of the camera and is available at 4ucam, $25. http://www.4ucam.com/images/7109_ant.jpg
In the TV - our Chevy Express "Silvester," I rigged up an adapter so I could mount the monitor bracket to the dashboard. I made it out of wood, painted it black and screwed it right into the dashboard. You can also see the van's antenna line connected to the back.
The monitor can be easily removed when not in use, and the antenna line tucks out of the way. When in use the van's antenna, a duplicate to the antenna mounted on the trailer, sits on its magnetic base on the van roof, and the line runs through the side window and along the headliner seam to the dashboard. I keep the antenna secure on the roof with an adhesive cable mount stuck on the roof. The magnet works very well. The antennas make a good wireless connection. Not great, good. I have some flips and dropouts when near interference, but generally it works well. Nighttime image is very good.
I also use a wireless magnetic mount camera with this system for hitching. It's a real bonus!
842T_spec
This system costs about $320 with the hitch camera and the two extended antennas.
dznf0g's patch antennas have the advantage of internal mounting. This system is more exposed but didn't involve any interior fitting. I do recommend enhanced antennas with this system - the stubby little antennas that come with the unit just don't cut it.
I have found that the system is helpful in backing into campsites and parking spots, but the wide view is a bit distorting when judging close distances, so I find I still Get Out And Look.
So now I find it's much easier to see the cop and his pretty red light behind me.
ID:	207431   Click image for larger version
ID:	207433   Click image for larger version
ID:	207435   Click image for larger version
ID:	207439   Click image for larger version
ID:	207444   Click image for larger version
John and Lynn,
Silvia ('06 25' Safari SE FB) and Silvester ('05 Chevy Express 3500)
jspafford is offline   Reply With Quote
Old 03-16-2014, 02:51 PM   #132
2006 30' Classic
Milton , Florida
Voyager Camera System WVOS713 Installation
Originally Posted by moosetags View Post
This morning I took several pictures of my Voyager Camera installation at the request of a Forums member. I emailed them directly to him. He has suggested that some others may also be interested...
Brian
The installation of this system on the rear of a 30 ft. Classic Airstream travel trailer was relatively straight forward. The camera was mounted just below the rear window of the trailer, at a height that is about shoulder high. Power for the camera was taken from the power leads going to the tag light.
The system powered up and paired the camera to the receiver with no adjustment on my part.
I used the mounting bracket approach described by Brian (Moosetags), with no significant modifications.
The picture is clear. The camera is transmitting to the receiver over a distance of approximately 45 feet. The camera antenna looks through the rear window of the travel trailer, the front window of the travel trailer, and the rear window of the Ford F250 truck to see the antenna on the receiver.
I will do some fine tuning of the picture with respect to brightness, contrast, and color when the weather clears next week.
We leave on a 7,500 mile trip in April. I will report back on the performance of the system during this long trip.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 03-16-2014, 03:22 PM   #133
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
So just to be clear, you're using the single camera version, not the 3 camera version, yes? How is the view with 1 camera? Enough to see traffic behind you in conjunction with your mirrors? I'm having one installed at the Mothership next month and thinking single cam.
SteveSueMac is online now   Reply With Quote
Old 03-16-2014, 04:11 PM   #134
dznf0g's Avatar
Oswego , Illinois
Post # 56 shows the view behind from the road with my single camera. The cars coming around are well within mirror view by the time they disappear from camera view.
-Rich-
Old 03-16-2014, 04:47 PM   #135
moosetags's Avatar
Mine is a single camera version. I have now been towing with it for about 3,500 miles. I have found that the view behind the Airstream is so good that I no longer mount the tow mirrors on the Suburban or pull the tow mirrors out on the Silverado.
The only problem that I have had is in the rain. The way that the back end of the Airstream throws up water mist, it gets all over the camera lens. This renders it useless in the rain.
This being said, I really like having the rear view camera. It makes me feel that I know what is going on behind the Airstream.
Brian
Old 03-16-2014, 04:58 PM   #136
dznf0g's Avatar
Oswego , Illinois
Brian, that's one of the things I like about having it up high. I'll get some individual drops on the glass, but rarely, even in driving rain, does it become obscured to the point of not being able to see pretty clearly what's back there.
-Rich-
Old 03-16-2014, 06:04 PM   #137
W , New England
Thanks guys - that's helpful. Single cam it is!
Old 03-16-2014, 10:35 PM   #138
2016 30' Classic
Erie , Colorado
Just picked up our FC25 last week at Colonial. Had them install the Voyager. Outstanding way to go. Agree with the value while towing. Almost easier to check than my add on mirrors which as expected vibrate in the wind.
Found it really useful when passing to know when you have really cleared the vehicle you are passing.
Mount is under the center marker light. Tilted down so that the outside bottom edges just show the rear awning. Can't see directly to the bumper but works fine backing into a truck stop and stopping just over the curb.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 03-16-2014, 11:32 PM   #139
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
How does one keep the voyage (or any other camera that is visible to anyone) from being stolen from the back of the trailer?
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 03-17-2014, 12:36 AM   #140
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
My camera is mounted high, as others have described. You're not getting up there without a ladder or something. Also, at that height it's one of the least interesting things about a, "Wow, is that an Airstream? Do they still make those?" trailer.
I need to re-aim my camera just a little bit. The dealer-install job was good, but they aimed the camera too far down to be sure I could see the bumper. I don't see cars behind the trailer until they are very close, and it's not much help backing up. With a little adjustment, it will be perfect.
Rocinante is our 2014 International Signature 27FB
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 05:11 PM
B190 back up camera install Corgifan Sprinter and B-van Forum 3 08-07-2011 04:16 PM
'83 sofa back piece folds out yonallycamp Upholstery, Blinds, Walls & Interior Finishes 1 04-30-2011 03:59 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 07:40 PM
