Old 03-14-2016, 12:08 PM   #1
suzieleigh's Avatar
2006 31' Classic
Wendell , Massachusetts
TV with analog tuner needs replacing
Our old Sony WEGA 19" TV needs replacing as we can only watch DVD's with its analog tuner. I'd like to get at least a 24" but can't seem to figure our how to determine if the TV will have the necessary input and output jacks so we can use the original JVC CD/DVD receiver, and the built in wall speakers. This Samsung looks good but does it have what I need?
http://www.bestbuy.com/site/samsung-...&skuId=8040004
HELP PLEASE!!!
Suzieleigh
suzieleigh is offline   Reply With Quote
Old 03-14-2016, 12:47 PM   #2
2015 30' Classic
Pleasanton , California
Can you post the model number for your JVC DVD unit?
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 03-14-2016, 01:21 PM   #3
suzieleigh's Avatar
2006 31' Classic
It's a KD-ADV6160. Thanks
Old 03-14-2016, 02:01 PM   #4
2015 30' Classic
Yes, you shouldn't have any issues connecting your KD-ADV6160 to the Samsung UN24H4500AFXZA. The JVC unit has a composite video output connector that will connect to the composite video input on the Samsung. You probably already have this connection to the Sony TV.
Not knowing what audio connectors are used for the Sony Wega TV I can't be sure that your existing cables will be compatible, but certainly there should be no issue making all the audio and video connections between the Samsung TV and JVC receiver. You might have to purchase an audio cable that has a mini-stereo plug on one end and RCA male connectors on the other for the audio connection from the TV to the receiver to work properly.
Al, K6IV
Old 03-14-2016, 02:14 PM   #5
suzieleigh's Avatar
2006 31' Classic
Thanks. If there are any other TV's that would also work, I'd appreciate any further input. I love the Airforum. Thanks.
Old 03-14-2016, 02:45 PM   #6
suzieleigh's Avatar
2006 31' Classic
Hopefully this will be easy to hookup and we'll get the necessary cables. Thanks.
Old 03-15-2016, 10:44 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Should just be RCA audio/video cable- red, white, yellow-
Any TV will have RCA audio/video inputs-
May be coaxial cable input-
Any TV will have coaxial cable input-
No more S-video or optical connection-
HDMI took the place of those I think.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-15-2016, 12:00 PM   #8
2004 19' Bambi
Cincinnati , Ohio
You can keep your old TV. Just get a converter, digital receiver and plug it in.
Richard Kern is offline   Reply With Quote
Old 03-15-2016, 01:34 PM   #9
suzieleigh's Avatar
2006 31' Classic
Time for a bigger TV anyway. Thanks. 28" will fit there and same specs and price as the 24".
Old 03-15-2016, 02:38 PM   #10
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
If you haven't bought yet, check out Sharp's Aquos models. FABOULOS image quality!! Only two companies produce the flat screens for ALL brands, however, Sony, SAMSUNG, and Sharp have a range of price points. Also, get at least two HMDI ports for future technical add-ons.
Urbanologist is offline   Reply With Quote
Old 03-15-2016, 03:17 PM   #11
suzieleigh's Avatar
2006 31' Classic
Thanks. I'll check out the Sharp's. I think the Samsung has 2 HD I ports but I'll double check the specs again. Thanks.
Old 03-15-2016, 03:55 PM   #12
m.hony's Avatar
2013 30' Classic
A Samsung at a lower price point will have 2 HDMI ports and a 60Hz refresh rate.
A higher price point will have 4 HDMI ports and a 120Hz refresh rate.
TAC #MS-10
Airforums #70955
Old 04-19-2016, 07:01 PM   #13
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
we bought an AS with one old magnavox 12 volt analog tv in rear with a nice wall mount. It needs a convertor to watch digital so we decided to replace with new flat screen HDTVs. there was not one installed by dinette so we needed two units.
While looking at display models of the Insignia models a 19" it was powered by a 120 to 12v transformer.. I was think how cool is this.. don't need a convertor to watch TV off the pedestal. Actually both displays were 12v so I was thinking COOL..
We wound up buying the 19" and had to order a 24" for area on wall by dinette.
Well we got the 19 home and when we had it inside the AS taking it out of the box i noticed it had a regular 120v cord. sure enough its a 120 v and i was bummed for sure..
Well fast forward to today and the UPS man brings the 24 up. I grabbed the box and starting in up believing it was a 120v started pulling the unit out of box and noticed no wire to unit..
WELL low and behold this one was 12v input.. YYYYEEEEAAAHHHHH,,
so if you are looking to replace or upgrade check the insignia models at best buy.. (insignia is best buy house brand made with samsung and LG parts.)
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-20-2016, 07:32 AM   #14
suzieleigh's Avatar
2006 31' Classic
Thanks for the update. I believe we're going to buy a Samsung 24 or 28" that has 2 digital optical audio outputs and 1 analog audio output and for $200 it seems to be a fair deal.
Radio tuner Punch Classic Motorhomes 1 09-16-2015 08:04 PM
Analog TV antenna mount removal Savage68 All Argosy Trailers 1 08-28-2014 09:57 PM
Dish Network tuner install Jack46 Audio, Video & TV 6 08-28-2014 08:00 PM
Atwood Analog Thermostat Replacement RAG Land Yacht/Legacy Motorhomes 20 10-14-2013 12:21 PM
Digital to Analog Converter... suggestions idmtman 2006 Safari SE 4 04-06-2011 10:01 PM
