Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 06-25-2016, 06:04 AM   #1
2014 25' FB International
Collierville , Tennessee
TV to stereo fix with headphone jack
Thought this info may help someone else:
We bought a "like new" 2014 International 25FB. The TV sound was bad and cut out. It was worse through the Sony system speakers. I discovered that if I unplugged the Sony system speakers (2 RCAs), the TV sound was fine. I called Airstream and they said Samsung modifies the TV for them by adding the RCA connections directly to the internal speakers (RCA cable just dangles out the back of TV). So, I disassembled the TV to check the soldering points. They all looked good. A replacement TV was about $500! (28" TVs are normally about $200).
My solution:
Bought a cable - 1/8" mini plug to 2 RCA connectors, and a right angle adapter (for the tight space behind the TV). Connected this from the TV headphone jack to the RCAs that go to the Sony system.
Cost: $12 (Radio Shack)
The only downside is - to use TV internal speakers, I have to unplug the headphone jack (very easy with right angle adapter). However, I like the sound better through the Sony system, so I just turn it on also. It's easier to hear.
Not a perfect solution, but works great for us.
Tony B.
rosietheairstream.net
Foxtrot is offline   Reply With Quote
Headphone jacks on 2014.5 Interstate silent in one ear coder Sprinter and B-van Forum 0 11-21-2015 10:59 PM
tv headphone and a/v inputs whitevan Electronics & Connectivity 1 02-01-2015 02:42 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
external stereo / audio jack 2005 AS CCD az-streamer Audio, Video & TV 8 10-10-2009 03:07 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
