Old 09-28-2014, 03:38 PM   #1
ILOVESALLY's Avatar
2007 25' Safari SS SE
Sarasota , Florida
TV outlet not working.
My TV outlet is not working in my 25ft 2007 Safari. I've had no problems before with this outlet in the overhead cupboard for the TV. I've checked the fuse and it's ok. The TV works in other outlets so I know the TV is ok.
Sorry I'm a bit naive on the electrical stuff so wondering what else I can try?
LoveSally
ILOVESALLY is offline   Reply With Quote
Old 09-28-2014, 04:08 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you saying the 110 voltage electrical outlet is not working or are you saying the tv antenna connection at that location is not working?
If it is the 11o volt outlet, tv does not light at all, look again at the fuse panel.
If it is the tv antenna connection make sure the antenna amplifier light is lit on the cover plate at the main tv connection.
2004 Excursion 4x4
Old 09-28-2014, 04:17 PM   #3
ILOVESALLY's Avatar
Sarasota , Florida
110v is not working. I've checked the fuse panel 3 times
LoveSally
Old 09-28-2014, 04:23 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Check your GFCI outlet.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-28-2014, 04:41 PM   #5
ILOVESALLY's Avatar
Sarasota , Florida
It was the GFCI
Thankyou
LoveSally
Old 09-28-2014, 06:23 PM   #6
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet , Massachusetts
I have a 2005 Classic and I have an coax cable in the front and in the rear of the trailer at the TV's . I attach the coax cable in the left rear of the trailer on the outside from the camp ground but from there I cannot get a good connection at the junction in the front and the TV's won't get any reception If I bring the cable in the front door and hook up the one in the front works fine but not the one in the rear . I cannot figure out the scematic from the book because mine doesn't appear like the one shown in the book. Can anyone give me a clue as how the TV wiring is to be hooked up from a camp site ?
Don
Don.44 is offline   Reply With Quote
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
Single Outlet Not Working gmp61 Electrical - Systems, Generators, Batteries & Solar 2 05-11-2012 08:08 PM
Outlet not working Mojave Electrical - Systems, Generators, Batteries & Solar 28 10-26-2011 02:29 AM
Easy fix, or not? Black tank/outlet pipe leak Bex Waste Systems, Tanks & Totes 0 09-06-2010 02:03 PM
12 volt outlet not working M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 14 07-15-2005 10:25 AM
