Old 02-20-2013, 07:06 PM   #1
Rockville Centre , New York
TV not working
My winegard booster will not light when press on and no tv reception can someone tell me. If my booster is bad thank u
Josie28 is offline   Reply With Quote
Old 02-20-2013, 07:54 PM   #2
dznf0g's Avatar
Oswego , Illinois
Possibly.
1) Check your fuses.
2) If fuse is ok, remove the amplifier from the wall and test for 12 volts at the back of it.
3) Check the ground wire with an ohmmeter to trailer skin.
4) If 12v is present and ohmmeter shows continuity, amp is probably bad.
I have a stock one which I removed when I upgraded to one that shows signal strength. If I can find it, you're welcome to it.
-Rich-
Old 02-20-2013, 09:35 PM   #3
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Originally Posted by dznf0g View Post
Possibly.
What model amplifier did you select when you upgraded yours? Does it have the same connectors in back to attach the outside cable and the second tv cable? Sounds like this would be a good upgrade if everything connects the same.
wolverine is offline   Reply With Quote
Old 02-21-2013, 06:46 AM   #4
dznf0g's Avatar
Oswego , Illinois
Hi Wolverine,
This is the one I got. It works really well...but a bit difficult to learn how to use. Not really intuitive, but does find the signal for you quickly once you get the steps down. Shop for best price...I just pulled down the first site I came across with a google search.
Sensar Pro TV Signal Meter - RVWholesalers.com RV Parts and Accessories
Edit: Yes same connections....plug and play. You do lose the 12V jack though.
-Rich-
'64 Dometic Fridge working fine...a relief! PA BAMBI II Refrigerators 0 11-10-2011 06:13 PM
RM2500 just stopped working TouringDan Refrigerators 6 09-25-2011 10:44 PM
light not working in 1962 Bambi (only 110 side) female.nomad Lights - Interior & Exterior 1 09-15-2011 12:53 PM
Electric working with battery not with 110 TX_DB Electrical - Systems, Generators, Batteries & Solar 11 04-24-2011 07:19 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
